Understanding the Work Energy Theorem for a Spring
In summary: The right-hand side of the equation is the kinetic energy at x1, which is the same as the total energy.
mrpolar
Hi,
I looked around for hours but it seems like I'm the only one who finds it confusing.
I understand the concept of potential energy and work, but have a problem with the equations.
Here is what I don't understand:
The work energy theorem states that K2-K1=W.
W = ∫Fdx from evaluated between x2 and 1.
The Force done by a spring is -kx, so when only the spring acts on the body the equation should be:
K2-K1=-½kx22 + ½kx12
K2+½kx22=K1+½kx12
But now, since W=-U(x) (potential energy) the equation turns out to be:
K2-½kx22=K1-½kx12
For the total energy balance (kinetic + potential). But the lectures and examples I saw, and also the logical thing as I understand it, is that the equation should be K2+½kx22=K1+½kx12 for the kinetic + potential energy balance.
Why do I get the signs wrong?
Here's an example for a question which made me really confused:
http://oyc.yale.edu/physics/phys-200/lecture-5#ch3 (minute 40:30).
In short, a mass is hanged from a spring attached the ceiling, so the mass has 2 forces acting on it: gravity and the spring.
In order to find the kinetic energy - potential energy equation, we have ΔKinetic_Energy = the negative of the work (-∫Fdx) of the total forces.
Now I know that gravity acts downwards, so the force is -mg, and the spring's force is always -kx, so the equation should look something like this:
K2-K1 = -∫F(gravity)dx - ∫F(spring)dx evaluated between x2 and 1. The negative signs before integrals is because we want to find the potential energy which is the negative of the work done.
K2-K1 = -∫-mgdx - ∫-kxdx = ∫mgdx + ∫kxdx
K2-K1 = mgx2 +½kx22 - mgx1 +½kx12
K2-mgx2-½kx22 = K1-mgx1-½kx12
which is the total energy equation.
In class, they had the potential energy signs all opposite like this: K2+mgx2+½kx22 = K1+mgx1+½kx12 which of course looks more sensible and logical.
The problem is that I can't see where I got the maths wrong. I follow the rules of and get it all messed up time and time again.
Please, help me out here, this is driving me nuts!
Ben.
Why do you integrate from x2 to x1 when calculating the work?
Hi, thanks for replying.
I evaluate the overall work done between the starting point (x1) to the end point (x2), so I integrate from x2 to x1 (the value at x2 minus the value at x1 gives me the work done between). I got something wrong?
Yes, you need to integrate from x1 to x2.
When I say that I integrate from x2 to x1 I mean that I set x2 as the upper bound and x1 as the lower bound of the integral.
You mean to set x1 as the upper bound and x2 as the lower bound in order to calculate the work?
I thoughts you do it in order to find the potential energy (hence the minus sign before the integral which is the same as reversing the integration order).
Then you use the words in an unusual way. Integral from a to b means that a is the lover limit and b is the upper limit.
See here, for example:
http://tutorial.math.lamar.edu/Classes/CalcI/DefnofDefiniteIntegral.aspx
Regrading your "problem", you use the definition of potential energy improperly.
What you get after integration and regrouping the terms is the right conservation of energy equation. The potential energy at x1 is 1/2kx1^2, given that the zero potential energy is at x=0.
The definition of potential energy tells you that the work is the negative of the change in potential energy.
So the change in PE from x1 to x2 is the negative of the work from x1 to x2, This is
Δ PE=1/2k*x2^2-1/2k*x1^2
So if you want to use conservation of energy rather than work-energy theorem, you have
ΔKE+ΔPE=0
which will give you again the correct equation
KE1+1/2k*x1^2=KE2+1/2k*x2^2
Hi, thank you again, you are really helpful. Sorry the wrong terminology.
So, if I got it right, for a mass hanged by a spring from a ceiling,
ΣF =-mg-kx (the spring's equalibrium = 0 potential energy, so gravity can take values of minus potential energy whenever the mass is beneath the equalibrium. is it ok?)
ΔKE = ΔW = ∫-mg-kx dx = -mgx2 -½kx22 + mg1 + ½kx12
KE2 + mgx2 + ½kx22 = KE1 + mg1 + ½kx12
First question: those equations are right? will work in any x point I define no matter if the mass is going up or down, beanth or above equalibrium, right?
My second question, I know that this equation is essentially KE2 + PE2 = KE1 + PE1[/SUB
but the righthand side of the equation is the kinetic energy at x1 plus the x1 part of the work equation, not the potential energy (I didn't multiply that part by (-1) the same as I did to the x2 part of the ΔW by moving it to the right-hand side of the equation). What's going on here?
Thanks in advance.
Yes, it is the potential energy. As it is the "x1 part" of the work-energy equation.
Your W is -ΔPE =-(PE2-PE1)=-PE2 +PE1.
So the x1 part is PE1. And the x2 part is PE2.
But it's no point to go keep going between work-energy and conservation of energy. Decide which one you want to use and stay with it for the given problem.
Thank you so much for helping me out here. I finally 100% got it.
Time to figure out conservation of energy in 2 dimensions :P
Thanks again.
Related to Understanding the Work Energy Theorem for a Spring
1. What is the Work Energy Theorem for a Spring?
The Work Energy Theorem for a Spring states that the work done by an external force on a spring is equal to the change in potential energy of the spring. This means that the work done to compress or stretch a spring is stored as potential energy in the spring.
2. How is the Work Energy Theorem applied to a spring?
To apply the Work Energy Theorem to a spring, you need to calculate the work done by the external force on the spring and the change in potential energy of the spring. The work done can be calculated using the equation W = Fd, where F is the applied force and d is the displacement of the spring. The change in potential energy can be calculated using the equation U = 1/2kx2, where k is the spring constant and x is the displacement of the spring from its equilibrium position.
3. What is the relationship between the force and displacement in a spring?
The relationship between the force and displacement in a spring is described by Hooke's Law, which states that the force applied to a spring is directly proportional to the displacement of the spring from its equilibrium position. This relationship can be represented by the equation F = -kx, where k is the spring constant and x is the displacement of the spring.
4. Can the Work Energy Theorem be applied to a spring that is not ideal?
Yes, the Work Energy Theorem can still be applied to a spring that is not ideal. However, the spring constant may vary and the energy may be dissipated due to factors such as friction. In this case, the work done and change in potential energy will not be equal, but the Work Energy Theorem can still be used to calculate the net energy transfer.
5. What are some real-life examples of the Work Energy Theorem for a spring?
Some real-life examples of the Work Energy Theorem for a spring include a trampoline, a pogo stick, and a car suspension system. In all of these cases, an external force is applied to the spring, causing it to compress or stretch and store potential energy. When the force is removed, the potential energy is released and the spring returns to its equilibrium position.
