Understanding Trigonometric Substitution
In summary, when using trigonometric substitution in calculus, you are supposed to use x=a⋅arcsec Θ for the substitution if the domain of Θ is {0≤Θ<π/2} ∪ {π/2<Θ≤π}. If the domain is {0≤Θ<π/2} ∪ {π≤Θ<3π/2}, there are issues which don't make sense to me.
Astro
48
When using trigonometric substitution in calculus you're supposed to always keep in mind the domain of the angle. In the case of √(x2-a2) (where "a" is a number >0) you use x=a⋅arcsec Θ for the substitution.
For trigonometric substitution, textbooks state that the domain of Θ must be {0≤Θ<π/2} ∪ {π/2<Θ≤π} when using the x=a⋅arcsec Θ substitution. Some textbooks alternatively give the allowable domain as {0≤Θ<π/2} ∪ {π≤Θ<3π/2} instead. In either case, there are issues which don't seem to make sense to me.
Please see the attached PDF file for my questions.
Thank you.
  • 2015 DEC 5__QUESTIONS.pdf
Thank you.
Question1: The presence of ##\sqrt{x^2 - a^2}## in the integrand leads to the substitution ##x = a\sec(\theta)##, as you know. For the square root expression to be real, it must be true that ##x^2 \ge a^2##, or equivalently, ##x \ge a## or ##x \le -a##.
In the unit circle, with x representing the hypotenuse of a reference triangle, and a representing the horizontal base, a can be positive or negative, but we always have ##|a| \le x##. So in the context of the unit circle, I don't see that ##x \le -a## can occur.
Question : The usual domain for the one-to-one cosine function (denoted Cos(x) instead of cos(x)) is ##[0, \pi]##. This is essentially the same domain as for the one-to-one secant function (denoted Sec(x)), except that ##\pi/2## is removed, so the two disjoint sets would be the range for the arcsec function. I don't know why they would pick the interval ##[\pi, 3\pi/2]## to be part of the range.
Thank you for trying to answer my two questions. Below is my reply.
You say that in the context of the unit circle x ≤ -a cannot occur and I agree. However, since that's true, then why does the textbook say that
"If x ≤ -a , then π/2 < Θ = sec-1x/a = arccos a/x ≤ π, and tan Θ ≤ 0." ?
(See the PDF I originaly posted for a scan of that part of the textbook and a drawn depiction of the unit circle).
Does anyone else know why?
In the PDF they don't refer to the unit circle, and are just looking at the algebra of the expression ##\sqrt{x^2 - a^2} = a\sqrt{\sec^2(\theta) - 1}##. The expression on the right is real if ##\sec(\theta) \ge 1## or if ##\sec(\theta) \le -1##. The first inequality is satisfied for ##\theta \in [0, \pi/2)##, and the second is satisfied for ##\theta \in (\pi/2, \pi]##, meaning that ##\theta## is in the second quadrant, which is where ##\tan(\theta) \le 0##.
I think the simplest answer is that someone writing a textbook is free to pick whatever intervals they want, as long as they choose them in a way that makes the Cosine function one-to-one. As I said before, the usual domain for this function is ##[0, \pi]##, but someone could also opt for ##[0, \pi/2) \cup [\pi, 3\pi/2)##.
Thank you.
the unit circle diagram has the radius as x .why is that?? shouldn't it have radius one
and shouldn't the adjacent be(in your pdf diagram) a/x.
then secθ=1/(a/x)=x/a??
and concerning your second question ,choosing any interval is ok as longas the function remains bijective for inverse to exist
for ex cotangent can be defined as follows
(π,2π)
even though it is usually taken as(0,pi)
My comment was in reference to the diagram in the PDF. The circle is identified as a unit circle, so the radius should be 1 (not x) as you point out.
(π,2π)
Regarding my first question:
(π,2π)
You're right; I shouldn't have said unit circle.
The reason the radius in the circle is x and not 1 is because:
--- By definition: cos θ=ajd/hyp and sec θ = 1/cos θ. Since cos θ=ajd/hyp, therefore sec θ=hyp/ajd.
--- Also, by definition, θ=arcsec hyp/adj
--- In the question x=a secθ and therefore rearranging we get θ=x/a . Let's assume the triangle is in the 2nd quadrant. Therefore, the adjacent side (in this case "a") is less than 1.
That being said, Mark44 said:
This makes sense; I understand that. However, I'm still having trouble understanding this geometrically with the context of a trigonometric circle (regardless of whether it's a unit circle or not). After all, as soon as we use trig substitution, don't we have to consider the variables geometrically as well, even though initially there isn't any need? (See attached JPEG image.)
Regarding my second question:
That makes sense about the function being one-to-one.
In your latest drawing, in case 2, there are several things that I think are incorrect.
1. Your angle ##\theta## is not in the right place. You show it as an acute angle in your reference triangle. It should instead be the angle from the positive x-axis to the ray that extends out to the circle. Keep in mind that ##\theta## is in the second quadrant, so ##\pi/2 < \theta < \pi##.
2. In case 2, you say that ##x \le -a##. This will never happen once you make x the length of the hypotenuse of the right triangle, which is by convention nonnegative.
3. In that same picture, you show the horizontal leg being -a. It should be a, where a is itself negative. Then ##\theta = arcsec(x/a)##. Since x > 0 and a < 0, x/a < 0 and arcsec(x/a) results in an angle in the 2nd quadrant.
Ah, yes, I see that now.
Actually, this is what the textbook says (see Page 1 of the attachment in my first post for the scan of that part of the textbook). This is why I'm confused and the gist of my Question #1. The textbook says "If x ≤ -a , then π/2 < Θ = sec-1x/a = arccos a/x ≤ π, and tan Θ ≤ 0." I agree that as the hypotenuse, x cannot be less than 0 but then why is the textbook allowed to say this? Although x≥a and x≤-a makes sense in the context of √(a2-x2), as soon as we use trig substitution, don't we have to consider the variables geometrically as well, even though initially there isn't any need?
You say that "a is itself negative". I'm guessing this is by convention in trigonometry? I think I understand but I find this a bit confusing since the x-axis in the 2nd quadrant is -ve.
As I said earlier, I believe they're looking at this relationship purely from an algebra perspective. Once you bring in the geometry, you're placing additional constraints on any variables.
I don't think so.
No. You don't make a variable negative by merely tacking a minus sign on its front. For example, if a < 0, then -a > 0.
Ok, so like you said, when the textbook talks about x≤-a, it's only looking at this relationship purely from an algebra perspective. Fair enough; that makes sense.
Perhaps I should rephrase my question:
Although the textbook is only looking at the x≤-a relationship purely from an algebraic perspective, in the same sentence, the textbook also says that when x≤-a then π/2<θ≤π. If the textbook is only looking at the values of "x" and "a" algebraically, then how does the textbook arrive to the conclusion that when x≤-a, that θ is in Quadrant #2? In other words, why would it mix up two concepts in the same sentence?
Going back to your original substitution, you have ##\sec(\theta) = \frac x a##. Assuming that x > 0, if a > 0, ##\theta## is in the first or fourth quadrant. If a < 0 (and x is still pos.), ##\theta## will be in the second or third quadrant. For the secant function to be one-to-one, we need to restrict the angle to, say, just the first and second quadrants.
Related to Understanding Trigonometric Substitution
1. What is trigonometric substitution and when is it used?
Trigonometric substitution is a technique used in calculus to simplify integrals involving expressions with radicals or variables raised to even powers. It involves substituting trigonometric functions for these variables in order to simplify the integral and make it easier to solve.
2. How is trigonometric substitution different from other methods of integration?
Trigonometric substitution is different from other methods of integration because it specifically targets integrals with expressions involving radicals or even powers. Other methods, such as u-substitution or integration by parts, may not be as effective in simplifying these types of integrals.
3. What are the common trigonometric substitutions used in integration?
The most common trigonometric substitutions used in integration are:
  • For expressions with sqrt(a^2 - x^2), the substitution x = a sin(theta) is used.
  • For expressions with sqrt(a^2 + x^2), the substitution x = a tan(theta) is used.
  • For expressions with sqrt(x^2 - a^2), the substitution x = a sec(theta) is used.
4. How do I know when to use trigonometric substitution?
You should use trigonometric substitution when you encounter an integral with expressions involving radicals or even powers. Look for patterns, such as the ones mentioned in question 3, and determine which substitution will help simplify the integral the most.
5. Are there any common mistakes to watch out for when using trigonometric substitution?
Yes, some common mistakes to watch out for when using trigonometric substitution include:
  • Misidentifying the correct substitution to use for a given integral.
  • Forgetting to substitute the limits of integration when evaluating the integral.
  • Forgetting to convert the final answer back to the original variable.
  • Calculus
