Understanding what a stagnation point is in compressible flow
In summary, a stagnation point is a point in a flow field where the velocity of the fluid is zero in all directions. It can occur at a boundary or within the flow field itself, and is often found at the leading edge of objects like aircraft wings or at the tip of a Pitot tube. In inviscid flow, the velocity normal to a boundary must be zero everywhere, while in viscous flow, it becomes more difficult to define due to the presence of viscosity.
Urmi Roy
753
Suppose we have a flow of a fluid and let it flow (in x direction) into a stationary wall..the x velocity becomes zero...is this an example of stagnation point?
If not, please cite an example of when that is true.
Hello, Urmi, your example is correct.
You get a stagnation point when the local velocity in one direction is zero.
Of course, it cannot be zero in all directions or there would be a build up of fluid at that point!
So the fluid approaching the wall at right angles 'stagnates' at the face of the wall and turns (exits) parallel to the wall.
Streamlines can terminate at a stagnation point.
Other examples would be the leading (front) edge of an aircraft wing and
the central point of a pitot tube inlet.
go well
But in that case, the velocity of the fluid there isn't exactly zero (it might have a y direction velocity)...moreover, why don't we usually consider the fact that there might be back-flow in the x direction...like in a pitot tube, the fluid might smash into the vertical face and bounce back? We're indirectly assuming that the interaction is inelastic...
For inviscid flow I would define a stagnation point as where the velocity is zero. Forget about the idea of "in one direction".
The velocity at every point in any flow field is zero in one direction (actually, in an infinite number of directions, in 3D flow) - namely, the direcition(s) perpendicular to the velocity vector!
For inviscid flow, the velocity normal to a boundary must be zero everywhere, otherwise the fluiid would be flowing through the boundary. So on a boundary you could define a stagnation point as zero velociity along the boundary. But you can have stagnation points that are NOT on boundaries, if you ignore turbulence.
The notion of a stagnation point gets much harder to pin down for viscous flow, because the velocity is zero everywhere at the flow boundary. But informally, you can say the stagnation point is "where it would be if there were no viscosity".
Right...so its kinda directional..I'm concentrating on the inviscid flow, since that's what we have in our curriculum...it doesn't have to have zero velocity along all directions...along anyone direction of interest will do...
No. A stagnation point is zero in all directions. Think about a sphere moving through a fluid. There will be a point on the sphere where the local surface normal is parallel to the movement direction where the flow will come to a complete stop locally.
If you did it with a flat plate, you could have a jet impinging on the flat plate as you describe. Now look at the flat plat directly and imagine plotting all the velocity vectors along the surface. At some point near the center, there will be one point that is a singularity. In fact, it will be a 2-D source. That point is the stagnation point and has zero velocity in all directions.
This is absolutely false. The concept or stagnation conditions is built on the flow at a given point being brought to rest isentropically. That means brought to rest in all directions. If it is still moving in any direction, you end up with all sorts of calculation errors.
This is not true in general, but in cases where this does happen, we are now talking about a 3-D flow and you will get a stagnation line where the fluid has zero velocity in all directions. This is the same concept as the stagnation line in an unswept wing where the flow along the leading edge line has zero velocity.
Can and do terminate at stagnation points. In fact, this is the only place a streamline can terminate.
Again, at the leading edge of an unswept aircraft wing, you have a stagnation line where the flow does, in fact, move with zero velocity in all directions. For a swept wing, there is no stagnation point. Instead we have what is called an attachment line, which is the analogue of the stagnation line, only the fluid is not actually stagnant so it is not a stagnation point or line.
For a Pitot tube, the flow velocity is zero in all directions at the tip.
Listen to AlephZero, guys. He knows his stuff.
Not directional at all. It has to have zero velocity in all directions.
Hello, Urmi, fluid mechanics can get very mathematical very easily.
There are two approaches to stagnation points. One is engineering one via Bernoulli and Momentum balance. The other is purely mathematical via potential theory or similar.
I am guessing that you are taking the engineering approach?
The difficulty in saying that the fluid velocity is precisely zero is as I have already said.
In a fluid in motion fluid is always moving along the streamlines. In particular it is always moving along any streamline that leads to a 'stagnation point'.
So what happens to this fluid when it reaches a stagnation point?
And how does the next element of fluid arrive if the train (last element) is still in the station?
Clearly the first train (element) must leave the station (stagnation point) before the next can arrive.
But to leave the station it must have a velocity in some direction.
As an engineer we can blithely ignore this dilemma by saying that the fluid element spend only an infinitesimal time at the stagnation point at zero velocity, and then moves off with some velocity.
We can say that the approaching streamline splits at the stagnation point and apply Bernoulli along this compound streamline so that we can calculate the stagnation pressure as I'm sure your course has shown. So perhaps I should have said the velocity is zero along the streamline at a stagnation point - it's just that your streamline was in the x direction.
No the fluid does not 'bounce back' from a pitot tube. If you consider the fluid element impacting on the stationary wall, no the collision is not elastic. Momentum is converted to a measurable force applied to the wall. So when you consider the momentum balance (in the x direction) there is momentum available in the direction of fluid motion, the wall is stationary so contributes zero momentum, and there is no momentum source in the reverse direction, so no 'bounce back' can occur.
If you wish we can explore this idea further.
There is one case where the point actually has zero velocity in all directions. This is the centre point of a body of fluid rotating in a cylinder. The streamlines are concentric circles and the SP the centre. This also illustrates an alternative definition of the SP – A point where the direction of the streamline is indeterminate.
Studiot, that simply isn't true. If you want to illustrate it, take a piece of sheet metal and spread oil (or some other viscous fluid) on it quite thin and then have a blower blow down on it. There will be a spot in the middle where you can clearly see the stagnation point. That is about as non-mathematical as you can get.
The problem is that you are explaining a fluid as if it is a constant stream of particles along a streamline. That isn't how it works. In real life, the molecules are not only undergoing the bulk motion of the fluid, but also their own Brownian motion as well. Fluid mechanics, as a branch of continuum mechanics, only deals with the bulk motion of the fluid. For that reason, you most certainly can have a stagnation point, even in an "engineering" sense. Of course individual molecules will never quite stop there because even if a molecule did follow that infinitely thin stagnation streamline, its own Brownian motion would be enough for it to whiz right off of that streamline and therefore onto a streamline that diverges from that point. Still, if you look at all the molecules, they will fly off of this point in random directions, meaning the vector sum of their velocities is zero. Zero velocity in the bulk fluid equals stagnation point.
What isn't true?
I think we are talking about the same mathematical models but with a slightly different viewpoint.
What isn't true is the idea that a stagnation point need not have zero velocity in every direction. All stagnation points have zero velocity in every direction. All of them. That is the definition of a stagnation point. That is the only way the mathematics work out. That is the only way the physics work out. There are several analogous concepts such as the stagnation line (an infinite array of stagnation points) or attachment lines (which don't actually exhibit stagnation conditions because they aren't stagnant), but to be a stagnation point, the velocity must be zero in all directions.
Post #8 is an excellent "physical" description of why "trains don't pile up" at the stagnation point, and if one wanted to add a more mathematical description in the fluid picture (where you have a density and velocity at every point), one could make the point that "trains piling up at the station" require the density to increase with time. The fluid continuity equation tells us when density will pile up (in steady state)-- it is when the velocity field has a negative divergence. But the divergence of a velocity field talks about how the velocity is changing with position, not what the velocity is at one position-- so we cannot state that the velocity being zero somewhere implies that trains will pile up. We only need a velocity field that has zero divergence-- such a field can still have zeroes in its velocity, consider for example a 2D flow that satisfies dvx/dx = - dvy/dy via vx=-x and vy=y. This has v=0 at the origin, and streamlines along the x-axis that lead right to the origin, yet no trains pile up.
We should probably also mention that we are talking about steady-state flows so there is some kind of fixed boundary that v is being measured relative to, giving meaning to a v=0 point. Otherwise we can always enter an arbitrary frame and make any point a v=0 point, but if the boundaries are moving in that frame, the flow won't appear to be steady in that frame.
Also, the OP mentions compressible flow, so if that is really intended, then it is not even necessary for the divergence of the velocity to be zero. However, you have to decide if you are going to allow infinite densities at the stagnation points in your model. If not, then a steady flow must be effectively incompressible at any stagnation point, because advection could not be present to compensate for the piling up due to a nonzero divergence there. In that case, it seems to me that questions about stagnation points that refer to compressible flows are not any different from those restricted to incompressible flows.
Since you don't like trains let me rephrase in more erudite terms.
Let there be a stagnation point S with a streamline terminating or splitting at S, depending upon the text you read.
Now consider an element of fluid on the streamline leading to S, a distance δs away from S.
The velocity of this element is v, directly towards S along the streamline, by definition.
Where does this element go in time δt = δs/v?
Secondly consider another element, distance δs' along the exit streamline from S.
Where has this element come from?
What text says a streamline splits at a stagnation point? That is a mathematical impossibility. Streamlines don't cross, touch or split.
The issue here is that you don't have streams of fluid packets just following along streamlines. Instead, the whole fluid is a continuum and the streamlines are a way of representing the velocity field. Like I mentioned previously, if you had some hypothetical particle of fluid sitting on a streamline, it's own Brownian motion would take it off that streamline. Of course, looking at a fluid in this sense breaks the continuum assumption so the concept of a streamline doesn't even make sense. That is why you won't have fluid "piling up" but can still have a stagnation point in the sense of a continuum.
In a compressible flow, you actually do get a bit of the piling up effect you speak of because the fluid does indeed compress as it approaches that stagnation point, eventually reaching stagnation conditions.
The problem is not with the metaphor, it is with the physics. Streamlines can point to a stagnation point without any piling up, i.e., any need for density to increase with time. I just gave a simple example of that.
Well, let's consider the simple example I just gave, where v along the x-axis is equal to -x. So in time dt=ds/v=-ds/x, the parcel finds itself ds/x closed to the stagnation point. Let us now calculate how long it will take to reach the stagnation point: t = integral over dx of 1/v, which is integral over dx of -1/x from s to 0. I'm sure you see that integral is infinite, so the train never reaches the station.
Certainly not from S, because again in the simple example I gave, it would take the element an infinite time to get from S to the point you have in mind.
So now I have two responders avoiding the issue in different ways. No offence meant to either.
Would the professors of Mechanical and Aeronautical Engineering at Glasgow University (Duncan) and Queen Mary College, University of London (Young) do you for a quote from p 60 of their book?
The method consists of combining the motions due to sources and sinks with the uniform stream. There is then at least one stagnation point where the fluid is at rest. The particular streamline which passes through the stagnation point divides in two there, as shown in Fig 2.2.1 and is called a dividing streamline.
Of course, Ken G (post#14) has shown the mathematical difficulty with this method as has boneh3ad with his (her?) comment about a singularity. In fact the mathematical model just can't hack it. Returning to the real 3D world, in what dimension would the singularity appear?
I am sure we are describing the same model but it is not perfect and capable of interpretation. Except that brownian or other random motion is not admitted in the strict continuum model.
Like I said, the reason the math works is because the streamlines represent the velocity field. In that velocity field, the velocity at a stagnation point is exactly zero. Individual molecules are not covered under traditional fluid mechanics because they are not a continuum. You don't see fluid piling up infinitely because the random motion of particles prevents any single particle or stream of particles from just following a streamline. That is borne out by reality without violating any of the math that describes stagnation points and streamlines.
Furthermore, even in a real flow where the fluid has to go somewhere, the vector sum of all of those particles leaving from the stagnation point is zero. Plain and simple, a stagnation point has zero velocity in all directions, and this does, in reality, happen.
So do you still disagree with the good Professors?
Ken,
Yes I understand your model which basically says that the closer you approach S the slower the fluid flows (v = -x with S at x=0).
However this is not an artifical flow not a real world one.
What happens when we use Urmis real world example and v = a constant, say χ?
Are you suggesting that the jet does not strike (ie never reaches ) the wall?
Without seeing the figure they reference, I don't want to draw conclusions. It may just be semantics and I don't own a copy of that book and I don't want to overstep without actually reading through what they claim. I can't say that I have ever come across an author who has claimed anything other than streamlines splitting is impossible. It may be that Duncan and Young are treating the stagnation streamline as a special case, but I really just can't infer their meaning without seeing what they did.
Studiot said:
What happens when we use Urmis real world example and v = a contstant, say χ?
While I agree that the flow posited by Ken G is not necessarily a real flow, I also should point out that the flow that you suggest here does not allow for a wall to exist without specifying that [itex]v=x[/itex] online in the free stream. If that is the case, then his flow changes fundamentally in its description as well if you want to only include the free stream.
From a potential flow standpoint, flow impinging on a flat plate can be described by
[tex]F = Az^{2}[/tex]
Where [itex]F[/itex] is the complex potential, [itex]A[/itex] is a constant scaling parameter (generally assumed to be real, i.e. flow is irrotational), and [itex]z = x + iy[/itex].
F=
Does this not form a flow pattern with streamlines of rectangular hyperbolae about the stagnation point Z0?
And do the axes not form meeting or crossing streamlines, outward on x and inward on iy?
Fluids are always artificial, indeed physics is always artificial, that's not any kind of objection to doing it.
That example is not a solution to any of the relevant equations. What actually happens is the flow goes through a shock, and still has a zero to the velocity.
Yes. What actually happens is that the jet strikes itself, once a shock sets up. Or, if we take the incompressible limit instead, the flow still strikes itself-- it generates an internal pressure gradient that stops the flow. Either way, the fluid velocity at the wall is zero, in all directions (in the 1D idealization). In a more real situation, there would be a point of symmetry that would be the stagnation point, where the velocity is zero. It all depends on the problem being idealized, and the physics being used.
It does form the hyperbolas you cite. If you replace one half-plane with a solid object you have impinging flow.
The axes don't meet or cross. In fact, the streamlines that overlap the axes either end at the stagnation point or start at the stagnation point of [itex]z=0[/itex].
all directions?
In a 1D model there is only one direction!
Are you seriously suggesting that if I direct a firehose at a wall and turn it on I will not wet the wall?
Have you a copy of Acheson?
If you are interested a pm with an email capable of receiving scans gets you a copy of section 2.8 (7pages) of Duncan, Thom and Young, which is too much to post here.
Studiot said:
all directions?
Obviously. So in 1D, all directions is that one direction. In 2D, there are two directions, and v is zero in both of those at a stagnation point. And so on.
Wetting the wall happens in the transient phase, this thread is about steady-state velocity flows where concepts like stagnation point apply. Wetting also has nothing to do with the velocity at the wall not being zero. This is just getting silly. Do you, or do you not, realize that the criterion for a "train pileup" at a stagnation point is that the divergence of the steady-state velocity field is nonzero? And do you, or do you not, realize that the divergence can be zero and have the velocity there also be zero? Put them together: no train pileup there, zero velocity in all directions there, no problem at all.
I included the above quote because it makes a good point about the mistake of associating bulk properties with particle flow. I wanted to added a third mechanistic option to describe a stagnation point not included in either the mathematical or engineering perspective to further illustrate the point. Mathematically what we generally deal with is phase space, where the flow is not defined strictly by particles movements but momentum through the particles. Much like waves propagating through a fluid without ever actually transporting the fluid particles any significant distance.
From a mechanistic perspective we can rewrite the ideal equation of state, by way of the mean free path and time, as [itex]PV \propto T \mapsto \ell_c/t_c \propto v_c[/itex]. This remains an ensemble, but constructed from interactions rather than absolute densities based on positions and momentums. In a laminar flow particle densities can increase while the interaction density decreases.
In terms of a stagnation point the momentum flow can be viewed directly from Newton's third law. You have a point where the momentum has stalled. Think of a stationary single particle here as an over idealization (actually it is bouncing back and forth in essentially the same small region defined by [itex]\ell_c[/itex]). Another higher energy particle comes along and collides with it. Now the stalled particle takes off, as defined by Brownian motion, but the particle that collided with it is now the stagnant particle at that location. The initial particle is now free to disperse the momentum beyond the stagnation boundary without destroying the boundary.
The stagnation boundary works just like the middle bearings of a Newton's Cradle in an otherwise continuous flow of particles. Just imagine a Newton's Cradle in which the deflected ball never returns, yet other balls keep coming from the other direction.
An interesting viewpoint, my_wan.
I see what you mean about Newton's Cradle, although that whole system is about solids and depends upon the properties of solids.
However similar reasoning, tailored to fluid properties, can be used to explain the jet impact upon the wall rather well.
Solids and fluids are less disjoint than most would suspect, particularly in the dynamics of the particles. Yes bulk fluid properties can be used to explain the jet impact on the wall rather well, but those ideas break down when you start thinking about infinitesimally small streams of particles moving along a streamline because in reality, that is not how the fluid particles act. Streamlines are a mathematical tool describing the velocity field of the bulk fluid, not a general physical reality.
Also I don't have Atcheson either. I've got Karamcheti; Katz; Munson, Young, and Okiishi; White; Abbott and von Doenhoff; and several Anderson books. That is an ever-growing collection as well, with Lamb and Batchelor both in the pipeline at some point.
What you are saying is correct, but on a side note I could point out that it is not at all clear there is any such thing as a "general physical reality" in the first place. The concept of what is "physical" is part of the discipline of "physics", which always makes all kinds of idealizaions and generalizations, like "fluids" and "streamlines", but also like "particles". The different idealizations have different levels of complexity and precision, but there are no fundamental distinctions there, it's all just choices we make to do physics. That's what I always think whenever I hear someone say "but that's just an idealization, it's not what is really happening."
This discussion has digressed. Urmi, as a budding mechanical engineer, is seeking a thoroughly workmanlike answer and understanding to some aspects of fluid flow. This is to be encouraged.
So let us take his real world example and examine it in the light of a mathematical model, realising that we cannot expect the model to reflect all aspects of reality perfectly.
The real world flow comprises a steam of fluid striking a plate or wall at right angles to the flow. We are not considering gravitational effects in this analysis.
The real flow has the appearance of a coordinated stream that moves with uniform velocity until it encounters the plate, whereon it curves round and spreads out with radial symmetry about a centreline and flows at sensibly right angles to its original direction. If the flow increased eventually this pattern deteriorates into something less regular. We are only concerned with the regular pattern. This looks rather like a broom or mop with the handle forming the incoming stream, the socket the impact zone and the head the plate or wall. I have shown this in fig1.
Our model must therefore provide sensibly parallel incoming flow lines that curve tightly in the socket zone and continue at right angles to the original. Because these flow lines are real world they must be continuous and have a well defined direction at all points. This point is very important and I will refer to it again later. I have drawn this model in fig 2.
Bone has offered a mathematical solution from complex analysis, which I have sketched at Fig3 and again at fig4. Because of radial symmetry we can cut down a dimension to two as shown and also note that we only need half of the solution as in fig4.
We can see that this solution offers generally continuous sweeping flow lines, nearly parallel to the incoming axis as in HJ, sweeping round tightly turning parallel to the other axis as required. So all is nearly all well and good using these to model our flow.
But there is a difficulty.
The solution also contains straight lines AD and BC along the axes, meeting at right angles at S in a sharp corner. These are continuous everywhere and have a defined derivative nearly everywhere. But as S the derivative is indeterminate or undefined.
Engineers can blithely ignore this by saying that the volume (thickness) of AD and BC is zero. Therefore the mass of the fluid along these lines being density times volume is also zero and the contribution to the momentum exchange between the wall and the fluid is therefore zero along these lines. So it doesn’t matter that our model doesn’t quite match at this point. It is usable. If we cunningly apply Bernoulli or the Momentum Balance along AS we find this difficulty cancels out and we can calculate a useful value for the stagnation pressure or force at S.
But there is a further twist, introduced by my_wan. And this is Physics rather than Maths.
What is the mechanism by which momentum in the AD direction can be turned into momentum in the SB and SC direction?
Well the momentum directed in the AD direction appears as a (pressure) force on the wall.
The wall reacts in accordance with Newton’s third law on the fluid in the DA direction, sustaining this pressure.
So the fluid at S and in the nearby region G is under hydrostatic pressure.
But in a fluid hydrostatic pressure at a point is the same in all directions.
This is not opposed in the SB and SC directions so fluid flows outwards in these directions.
So in this sense it is like the central ball in Newton’s cradle, but using fluid properties to change the direction of momentum, a feat not achievable by the solid balls in the cradle.
So this is a physical interpretation of what is a stagnation point.
Go well
  • #31
That wasn't even the original question. The original question was whether the flow velocity had to be zero in all directions for it to be a stagnation point. It does.
  • #32
Studiot said:
The real flow has the appearance of a coordinated stream that moves with uniform velocity until it encounters the plate, whereon it curves round and spreads out with radial symmetry about a centreline and flows at sensibly right angles to its original direction. The solution also contains straight lines AD and BC along the axes, meeting at right angles at S in a sharp corner. These are continuous everywhere and have a defined derivative nearly everywhere. But as S the derivative is indeterminate or undefined.
No, that is not correct. The derivative is well defined there, because the entire flow (in the fluid description we are using) is determined by a velocity field. At the stagnation point (in compressible or incompressible flows), the velocity field is zero (in all directions, as boneh3ad and others stressed), and also has zero divergence. Not undefined divergence, zero divergence. This is also why it takes an infinite time to reach the stagnation point, and why there is no "train pile up" there, and no mathematical difficulties for the idealized fluid model.
Momentum in one direction is never "turned into" momentum in another direction. Momentum is a vector, and its components obey the laws of physics entirely independently of each other. To stop a momentum toward the wall, you need a force away from the wall. To start a momentum along the wall, you need a force along the wall. Pressure forces do all this just fine, even at stagnation points. There are no mathematical difficulties presented by stagnation points in the fluid description, and Newton's laws encounter no singularities there. I do not see why you are framing any of this as "twists" or "wrinkles", it is all basic fluid mechanics. But the diagrams and the scenario you are describing may indeed be useful to the OPer, if they simply read past all the intimations of dire singularities here!
Related to Understanding what a stagnation point is in compressible flow
1. What is a stagnation point in compressible flow?
A stagnation point in compressible flow is a point in the flow field where the velocity of the fluid is reduced to zero. This can occur when the fluid is forced to change direction suddenly, such as when flowing around a curved surface or through a narrow channel.
2. How does a stagnation point affect the flow of a compressible fluid?
A stagnation point can have a significant impact on the flow of a compressible fluid. At the stagnation point, the fluid's velocity is reduced to zero, causing an increase in pressure and temperature. This can lead to changes in the fluid's density and affect the overall flow behavior.
3. What factors influence the location of a stagnation point in compressible flow?
The location of a stagnation point in compressible flow is influenced by several factors, including the shape and size of the object in the flow, the fluid's velocity and density, and the fluid's viscosity. Additionally, the angle of attack and the Mach number of the flow can also affect the location of the stagnation point.
4. How is a stagnation point calculated in compressible flow?
The location of a stagnation point can be calculated using the Bernoulli's equation, which relates the pressure, velocity, and density of a compressible fluid. By setting the velocity to zero at the stagnation point and solving for the pressure, the location of the stagnation point can be determined.
5. What are the practical applications of understanding stagnation points in compressible flow?
Understanding stagnation points in compressible flow is essential in various practical applications, such as aerodynamics, aircraft design, and gas turbine engines. It also plays a crucial role in understanding the behavior of fluids in pipes, nozzles, and other flow systems. By understanding stagnation points, engineers can optimize designs and improve the performance of various systems.
  • Classical Physics
  • Mechanical Engineering
  • Classical Physics
