Underwater acoustic unit conversion
In summary, converting decibels (dB) to pascals (Pa) in underwater acoustics can be done using the formula: Pa = 10^(dB/20). dB re 1 μPa and dB re 1 μPa^2/Hz are both units of sound pressure level (SPL) used in underwater acoustics, with the latter being a more precise measurement. Meters per second (m/s) can be converted to knots (kt) using the formula: kt = m/s * 1.94384. The reference sound speed used in underwater acoustic unit conversions is typically 1500 m/s. Different units of underwater acoustic measurements can be converted using the appropriate conversion factor.
nauman
91
Hi all
I have acoustic noise level value in dB vs 1 dyne/sq cm e.g. -10 db vs 1 dyne / sq cm. I need to convert it into dB ref 1upa unit. How i will convert it?
Thanks & Regards
FAQ: Underwater acoustic unit conversion
How do you convert between decibels (dB) and sound pressure level (SPL)?
To convert between decibels and sound pressure level, you can use the formula: SPL = 20 * log10(P/P0), where P is the sound pressure and P0 is the reference pressure of 20 micropascals. This formula assumes a linear relationship between dB and SPL, which is only accurate for small changes in sound pressure. For larger changes, a more complex formula that accounts for the non-linear nature of sound perception is needed.
What is the difference between underwater acoustic units and standard acoustic units?
Underwater acoustic units are used to measure and describe sound in water, while standard acoustic units are used for sound in air. The main difference between the two is the reference pressure used. Underwater acoustic units use a reference pressure of 1 microbar, while standard acoustic units use a reference pressure of 20 micropascals.
How do you convert between underwater acoustic units and standard acoustic units?
To convert between underwater acoustic units and standard acoustic units, you can use the formula: SPL (underwater) = SPL (standard) + 26.4 dB. This formula takes into account the difference in reference pressures and allows for easy comparison between sound levels in air and water.
What is the relationship between sound speed and temperature in water?
Sound speed in water is directly proportional to temperature. As water temperature increases, so does the speed of sound. The exact relationship is dependent on salinity and pressure, but as a general rule, sound speed increases by approximately 1.5 m/s for every 1 degree Celsius increase in temperature.
How do you convert between sound speed in water and sound speed in air?
To convert between sound speed in water and sound speed in air, you can use the formula: c (water) = c (air) * (sqrt(rho (water) / rho (air))), where c is the speed of sound and rho is the density of the medium. This formula takes into account the difference in density between air and water and allows for easy conversion between the two mediums.
