Uniform Circular Motion; bead on a string.
In summary, the string exerts a force on the bead that is inversely proportional to the distance between the points of attachment.
ourheroine
1. Homework Statement
An 100g bead is free to slide along an 80cm long piece of string ABC. The ends of the string are attached to a vertical pole at A and C, which are 40cm apart. When the pole is rotated, AB becomes horizontal.
a) find the tension in the string
b) find the speed of the bead at B.
in the diagram, A is the point the string is attached at the bottom of the pole, B is where the bead is (horizontally in line with A), and C is where the string is attached at the top of the pole (40cm up from A).
2. Relevant equations
F=ma, a=v^2/r
3. The attempt at a solution
For a free body diagram I have drawn the forces acting on the bead; the weight of the bead (mg) acting vertically downwards, the y component of Ftens acting upwards on the bead, and the x component of Ftens acting horizontally towards the pole.
I have figured that since the bead rotates in a horizontal plane that mg = Ftensy
therefore: (0.1kg)(9.8N) = 0.98N = Ftensy
I have also figured by the ole 3-4-5 rule that the horizontal part of the string (aka the radius) is 30cm and that the hypotenuse of the triangle is 50cm. Via trig, the angle at point C is 36.9o and the angle at point B (aka the bead) is 53.1o.
I am stuck now, as I think the next step should be to figure out the radial acceleration via the net force, but I am unsure as to how to figure out the value for Ftensx...which, if Ftensy = mg (but in opposition), would be Fnet...?
Note: I did find a couple of posts on this in the archive but was still unclear after reading through them, so any help is much appreciated!
Hi ourheroine, welcome to PF!
I have a question. If I am visualizing your set up correctly, then I understand that the segment of the string labelled AB is horizontal and therefore its tension contributes to the centripetal force. But isn't there also a horizontal component to the tension in the other segment of the string (BC) i.e. the hypotenuse of the triangle? After all, it is pulling both upward and (radially) inward.
Hi ourheroine, welcome to PF.
If T is the tension in the string segment BC, then T*sinθ balances mg and T*cosθ adds to the centripetal force. Write down two equations and solve for T and v.
What about the tension in segment AB? It does nothing?
Thanks for the welcome! :)
Checking to see how far off I am...I'm getting a tension of 2.0N in the (total) string?
I get less than that. Can you post your calculation steps?
Sure thing!
Ftens*sin(theta) = mg
Ftens = (0.1kg)(9.8N) / sin53.1o
Ftens = 1.2255N
So this would be the tension exerted by the portion of the rope BC
Ftens*cos(theta) = Ftensx
1.2255N*cos53.1o = Ftensx
0.7358 = Ftensx
I'm assuming where I went wrong in all this is because, under theory of the string's portion AB exerting force on the bead, I then added Ftensx to Ftens...:S Which really doesn't make a whole lot of sense but shouldn't that portion of the string do some pulling too??
ourheroine said:
Sure thing!
Ftens = 1.2255N
Yeah, that was my result as well. I was confused because I thought that what you meant was that you calculated *this* to be 2.0 N.
Yeah, if we assume that the tension in AB is the same as the tension in BC (and I'm not sure if that is correct), then it seems to me that AB pulls inward as well. Do you know for sure that this leads to the wrong answer?
EDIT: because if it is right, then you have all of the info you need for part b. You know F (centripetal) and you know r, therefore you can solve for v.
Sorry! I should have been more clear with my calculations straight off :)
I don't actually have the answer for this problem, so I can't say whether or not I am approaching this the right way...from my imagination of this system I think maybe that since AB is taut (horizontal) it is pulling inwards...and my thinking is that it pulls inwards the same amount as FtensBCx pulls inwards because both are horizontal tension exerted over the same distance on the same object by the same type of string...?
No, I think that what you said in post #7 is correct. I.e. the whole string is at tension T. Therefore, AB pulls inward with force T, and BC pulls inward with force Tcos(theta). These two combined comprise the centripetal force. The more I think about it, the more that seems to make sense.
Sorry, just to clarify;
Whole string tension = TensBC + Tens AB
tensile force of AB = Tcos(theta)
tensile force of BC = T
(if T= 1.2255N and Tcos(53.1o) is 0.7358N, then the tension in the entire string is 2.0N)
Centripedal force = TensBCx + Tens AB
tensile force of BCx = Tcos(theta)
(so the centripedal force = 2(0.7358N) = 1.5N)
Bead is free to move in the string. It moves in a curved path. Component of weight moves it down along tangent to the curve. Component of centripetal force moves it up along the tangent to the curve. The component of weight and the component of centripetal force contribute to the tension in BC.
In equilibrium position mg*sinθ = (m*v^2/R)*cosθ
And tension in BC = mg*cosθ + (m*v^2/R)*sinθ
If the bead slows down it falls. If the bead moves fast it rises up.
I am unclear as to why we are taking the components of weight and centripetal force here, have you chosen the +y axis along BC?
If I work backwards from isolating velocity I get a net force of 1.6321N, which I don't understand in terms of my beginning free body diagram using AB along the x-axis, with mg and FtensBCy along the y axis. :\
When the bead is at rest, it hangs vertically downwards. In that position tension in each segment of the string is equal and it is equal to mg/2. As the bead starts moving in the circular orbit, the centripetal force causes to move up. The tensions in the strings are caused by the weight and the centripetal force. So to find the tension in the string you have to take the components of these two forces.
In the horizontal position of AB, there is no tension in AB due to weight. In this position tension is due to centripetal force.
Related to Uniform Circular Motion; bead on a string.
1. What is uniform circular motion?
Uniform circular motion is a type of motion in which an object moves in a circular path at a constant speed. This means that the object covers the same distance in the same amount of time, regardless of where it is on the circle.
2. How is uniform circular motion different from regular circular motion?
In regular circular motion, the object's speed may change as it moves along the circular path. However, in uniform circular motion, the object maintains a constant speed throughout the entire circular path.
3. What is the role of centripetal force in uniform circular motion?
Centripetal force is the force that pulls an object towards the center of the circular path. In uniform circular motion, this force is responsible for keeping the object moving in a circular path.
4. Can an object in uniform circular motion have a changing velocity?
Yes, an object in uniform circular motion can have a changing velocity. This is because velocity is a vector quantity that takes into account both speed and direction. In uniform circular motion, the direction of the object's velocity is constantly changing, even though its speed remains constant.
5. What are some real-life examples of uniform circular motion?
Some common examples of uniform circular motion include the motion of a satellite around a planet, the rotation of a Ferris wheel, and the motion of a ball on a string being swung in a circular path.
