Uniform Circular Motion - Find Force
In summary, the conversation discusses the Bohr model of the hydrogen atom and finding the force and centripetal acceleration of an electron in a circular orbit. The formula for centripetal acceleration is m(v^2/r), and in part (a), the mass of the electron is needed to find the force. The mass of an electron is typically given as 9.11 x 10^-31 kg. In part (b), the formula is used without the mass because it is not given, but should be included if it is provided in other problems.
webren
34
Hello,
The first part of the problem confuses me, but I have solved the second part.
"In the Bohr model of the hydrogen atom, the speed of the electron is approximately 2.20 x 10^6 m/s. Find (a) the force acting on the electron as it revolves in a circular orbit of radius 0.530 x 10^-10 m and (b) find the centripetal acceleration of the electron."
I don't understand how to find part (a).
In finding part (b), I used the formula for centripetal acceleration which is m(v^2/r). This is kind of confusing because there isn't a mass given, so it seems like the book just disregards the mass and simply divides the velocity(squared) by the radius. In other problems when a mass is given, they will throw the mass in the forumla like I have stated above. Is this the correct approach of going about these kind of problems? If a mass isn't given, leave it out, but if it is, use it in the above forumla?
So for part (b), my answer came out to be 9.13 x 10^22 N, and the book agrees.
Any help in solving part (a) and possibly explaining my question regarding part (b) would be appreciated. Thank you.
The centripetal accelaration is [tex]\frac{v^2}{r}[/tex]. When you want to find the (centripetal) force you multiply it with the electron's mass. This is F = ma in the radial direction.
Ah, okay. That makes sense. Thanks for clearing that up, neutrino.
So in part (a), they are asking for the centripetal force, but to do that we need the electron's mass. If we don't know its mass, how is it possible to find the centripetal force?
Generally, the electron's mass is "a given" ~ 9.11 10e-31 Kg. This is known as the electron's rest mass.
Understood. Thanks.
FAQ: Uniform Circular Motion - Find Force
What is uniform circular motion?
Uniform circular motion is a type of motion in which an object moves in a circle at a constant speed. This means that the magnitude of the velocity remains constant, but the direction of the velocity changes as the object moves around the circle.
How do you calculate the centripetal force in uniform circular motion?
The centripetal force in uniform circular motion is calculated using the equation Fc = mv^2/r, where Fc is the centripetal force, m is the mass of the object, v is the speed of the object, and r is the radius of the circle.
What is the relationship between centripetal force and acceleration in uniform circular motion?
The centripetal force and acceleration in uniform circular motion are directly proportional. This means that as the centripetal force increases, the acceleration also increases. This is because the centripetal force is responsible for changing the direction of the velocity, which results in acceleration.
How does the direction of the centripetal force relate to the motion of the object in uniform circular motion?
The centripetal force is always directed towards the center of the circle in uniform circular motion. This is because the force is required to constantly pull the object towards the center and keep it moving in a circular path.
Can an object in uniform circular motion have a constant speed and changing acceleration?
Yes, an object in uniform circular motion can have a constant speed and changing acceleration. This is because the object is always changing direction, which means it is constantly accelerating towards the center of the circle. However, the magnitude of the velocity remains constant, resulting in a constant speed.
