Uniform Circular Motion of a tire
In summary, the question asks for the speed of a car based on the frequency of a point on the outer rim of its tire in uniform circular motion. The given frequency is 28 Hz and the diameter of the tire is 40 cm. Using the formula V=2 pi r f, the calculated velocity is 126.669 km/hr. However, there may have been a miscalculation or typo in the book or from the teacher, as this answer is different from what is expected.
Muneerah
A point on the outer rim of a tire on a moving
vehicle exhibits uniform circular motion with
a frequency of 28 Hz. The diameter of the tire
is 40 cm.
How fast is the car moving?
Answer in units of km/hr.
V=2 pi r f
The first thing I did was finding the frequency in terms of hrs, and I got 100800 revelotions per hr. Then I found converted the radius to km so I got .0002 km. Then I found the velocity which is, 2 pi r f = 126.669 km/hr. My answer is wrong, I don't know what it is that I did wrong so if you can please help. Thank you
is 40 cm.
V=2 pi r f
I'm getting the same answer. If I had to guess, your book/teacher probably miscalculated or had a typo.
Hello,
It seems that you have made a small mistake in your calculation. When converting the radius to km, you should have gotten 0.0004 km instead of 0.0002 km. This is because the diameter of the tire is given to be 40 cm, which is equivalent to 0.4 m. When converting to km, you need to divide by 1000, so you should get 0.0004 km.
Using this corrected value for the radius, your final answer for the velocity should be 253.338 km/hr.
I hope this helps. Keep up the good work!
FAQ: Uniform Circular Motion of a tire
What is uniform circular motion?
Uniform circular motion is the movement of an object in a circular path at a constant speed.
How does a tire exhibit uniform circular motion?
A tire exhibits uniform circular motion when it rotates around its axis at a constant speed while maintaining its distance from the center of rotation.
What is the relationship between the speed of the tire and its radius?
The speed of the tire is directly proportional to its radius. This means that as the radius increases, the speed also increases, and vice versa.
How is centripetal force involved in uniform circular motion of a tire?
In uniform circular motion, the centripetal force is responsible for keeping the tire moving in a circular path by constantly pulling it towards the center of rotation.
What factors affect the uniform circular motion of a tire?
The factors that affect the uniform circular motion of a tire include its speed, radius, and the amount of centripetal force acting on it. The friction between the tire and the surface it is moving on can also affect its motion.
