Uniform circular motion with constant upward velocity.
In summary: The spiral motion is due to a combination of a uniform circular motion and a constant upward velocity.
Toranc3
189
It is common to see birds of prey rising upward on thermals. The paths they take may be spiral-like. You can model the spiral motion as uniform circular motion combined with a constant upward velocity. Assume a bird completes a circle of radius 6.00m every 5.00s and rises vertically at a rate of 3.00m/s
1. Find the speed of the bird relative to the ground.
2. Find the magnitude of the bird's acceleration.
3. Find the direction of the bird's acceleration.
4. Find the angle between the bird's velocity vector and the horizontal.
Velocity tanget=(2*∏*R)/T
Acceleration radial= (4*∏^(2)*R)/T^(2)
V tan. = (2*pi*6m)/5s = 7.53m/s
V= sqrt[ (3m/s)^(2) + (7.53m/s)^(2) ] = 8.11m/s
2:
A rad= (4*pi^(2)*6m)/25s^(2)=9.47m/s^(2)
Atan is zero because of uniform circular motion. The bird is going up at a constant veloctiy so acceleration going up is zero right. Does gravity still have an effect?
3: I am stuck in the direction part.
4: tan(θ) = 3m/s over 7.53m/s= 22 degress from the horizontal.
Is my work right so far and what about part 3? Thanks!
You don't need to consider gravity here. It's a question about the actual movement of the bird, regardless of the forces that lead to it.
You computed a radial acceleration, and decided, correctly, that there was no other acceleration. So haven't you determined the direction?
Everything else looks right.
Well I know that it would be inward. Since the other component atan is 0 then the direction would be 0 degrees?
I had another question. Where would you put you axis at? I did this problem using 2 dimensions.
Sorry, which axis?
haruspex said:
Sorry, which axis?
Where would you make your origin for this problem? This problem can be done by using 3 dimensions or 2 dimensions right?
It's very much a 3D question. A natural choice would be cylindrical polar, with the z axis vertical. But you could also use Cartesian, centred on where the bird is at the instant being considered, with x as the radius and y as the horizontal projection of the tangent, say.
[url=http://www.freeimagehosting.net/oewmb][PLAIN]http://www.freeimagehosting.net/t/oewmb.jpg[/url][/PLAIN]
is this picture good?
The path is a helix (not, as the OP stated, a spiral).
Related to Uniform circular motion with constant upward velocity.
1. What is uniform circular motion with constant upward velocity?
Uniform circular motion with constant upward velocity is a type of motion in which an object moves in a circular path at a constant speed while also moving upwards at a constant rate.
2. What are the key components of uniform circular motion with constant upward velocity?
The key components of uniform circular motion with constant upward velocity include a circular path, a constant speed, and a constant upward velocity.
3. How is uniform circular motion with constant upward velocity different from regular circular motion?
In regular circular motion, the speed of the object may vary as it moves along the circular path. However, in uniform circular motion with constant upward velocity, the speed is constant throughout the motion.
4. What are some real-life examples of uniform circular motion with constant upward velocity?
Some examples include a roller coaster moving along a loop, a satellite orbiting Earth, and a Ferris wheel.
5. What are the applications of studying uniform circular motion with constant upward velocity?
Studying this type of motion can help us understand the behavior of objects in circular motion, such as the forces acting on them. It also has practical applications in fields such as engineering and astronomy.
