MHB Uniform Convergence of $Y(x)$ in $(0,1]$
Also sprach Zarathustra
Hello!A little problem:With the given series,$$Y(x)= \sum_{n=1}^{\infty}(-1)^n\frac{x^n\ln^nx}{n!} $$ ,why $Y(x)$ is Uniformly converges for all $x\in(0,1]$ ?Ok, I know that $Y(x)$ is u.c by M-test:
$$\max{|x\ln{x}|}=\frac{1}{e}$$
And,
$$ \sum_{n=0}^{\infty}\frac{(\frac{1}{e})^n}{n!} $$
Is converges! But why only in $(0,1]$ ?
Thank you!
We need some clarifications. First, we talk about uniform convergence on a set, not only at one point (in this case, it's pointwise convergence). Where do you take the $\max$?
On positive $\mathbb{R}$ .
In this case, the $\max$ is infinite. But if you take it on $(0,1]$, you will notice that the series is normally convergent on $(0,1]$.
Normally convergence is not enough for this problem that I have, I need integrate that sum,- I must first prove the U.C. on (0,1].
I'll rephrase my question: is that the only interval,(0,1], that Y(x) U.N in ?
You have the normal (hence uniform) convergence on each interval of the form $(0,a]$, $a>0$.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
