Uniform Distribution, Absolute Value
In summary, the randomly distributed X has a CDF of 1/2 on the interval [0,1) and 1/4 on the interval [1,3).
IniquiTrance
190
Find the CDF of |X|, given that X is a random variable, uniformly distributed over (-1,3).
Is |X| uniformly distributed? If yes, over what interval?
I found so far that:
Setting Y=|X|
Then: Y [tex]\in[/tex] (1,3)
[tex]F_{Y}(y)=P\left\{Y\leq y\right\}=P\left\{-y\leq X\leq y \right\}= F_{X}(y)-F_{X}(-y)[/tex]
This sums up to:
[tex]F_{Y}(y)= \frac{1}{2}y[/tex]
and differentiating gives the PDF of Y:
[tex]f_{Y}(y)= \frac{1}{2}[/tex]
So it seems Y IS uniformly distributed on (1,3).
My question is, since Y is on a different interval than X, and X is 0 for values less than -1, isn't this the case:
[tex]F_{X}(-y)=0[/tex] for Y [tex]\in[/tex] (1,3)?
If so, then the term disappears in the calculation above, and Y's PDF would be [tex]\frac{1}{4}[/tex]
But tehn this is not even a valid PDF, since integrating over (1,3) doesn't equal 1!
Any ideas?
Thanks!
Hi IniquiTrance! :smile:
Setting Y=|X|
Noooo :redface:
So if X is 0, what is Y?
You have written that the density of Y at 0 is zero.
Ahhh! Big doors always turn on small hinges! :blushing:
So, I guess I should approach it piecewise.
On (1,3), X and Y share the same PDF, viz., [tex]\frac{1}{4}[/tex].
Ad it's on (0,1) that:
Is this right?
And Y does not have a uniform distribution, since it does not have a PDF = [tex]\frac{1}{b-a}[/tex] on either sub-interval.
Well, to be uniform it would have to have a constant density function over the entire interval, not just some subinterval. But the rest is okay.
(just got up :zzz: …)
But does it have a uniform distribution on either sub-interval separately?
(and don't forget that the question asked for the CDF)
Hmm, doesn't a uniform distribution have to have a PDF given by:
[tex]
\frac{1}{b-a}
[/tex]
I know that on the two subintervals, the PDF's are constants: 1/2 on [0,1), and 1/4 on [1,3). But neither integrates to 1 over the subinterval.
Can they still be uniform distributions notwithstanding the above?
Well, it's an odd way of putting it, that I've not come across before, but in view of the wording of the question …
… I'm confused as to what answer is expected. :redface:
Right, I stil can't decide. From researching up to the 30th page of a google search, it seems that the criterion for a uniform distribution is that its PDF = [tex]
\frac{1}{b-a}
[/tex]
over (a,b).
I still couldn't find anything attacking the question directly, of given the PDF doesn't equal that quotient, but is constant over a subinterval, is it still uniformly distributed there?
IniquiTrance said:
… I still couldn't find anything attacking the question directly, of given the PDF doesn't equal that quotient, but is constant over a subinterval, is it still uniformly distributed there?
Well, I'd say it is :smile:, but I've no idea what the official answer would be. :redface:
It seems like it should since the idea is that the probability of the variable occurring in some interval is dependent only on the length of the interval, whenever the PDF is constant, which is the unique feature of uniform distributions.
Thanks very much for your help! :biggrin:
Related to Uniform Distribution, Absolute Value
1. What is a uniform distribution?
A uniform distribution is a type of probability distribution where all possible outcomes have equal chances of occurring. In other words, each value in the distribution has an equal probability of being selected.
2. How is a uniform distribution represented mathematically?
A uniform distribution is represented by the symbol U(a,b), where a and b are the minimum and maximum values in the distribution. This means that all values between a and b have equal probabilities of occurring.
3. What is the difference between a discrete and continuous uniform distribution?
In a discrete uniform distribution, the possible outcomes are countable and finite, such as rolling a fair dice. In a continuous uniform distribution, the possible outcomes are infinite and uncountable, such as the height of a randomly selected person.
4. What is the absolute value of a number?
The absolute value of a number is its distance from 0 on a number line. It is always a positive value, regardless of the sign of the original number.
5. How is the absolute value related to uniform distribution?
In a uniform distribution, the absolute value is used to ensure that all values have an equal probability of occurring. This is achieved by taking the absolute value of the difference between the maximum and minimum values in the distribution.
