Uniform Distribution Probability
In summary, if you want to know the probability of a wait time greater than 6 minutes, you can use the binomial distribution to approximate the density, and then use the normal approximation.
hahaha158
80
The wait time (after a scheduled arrival time) in minutes for a train to arrive is Uniformly distributed over the interval [0,12]. You observe the wait time for the next 95 trains to arrive. Assume wait times are independent.
Part a) What is the approximate probability (to 2 decimal places) that the sum of the 95 wait times you observed is between 536 and 637?
Part b) What is the approximate probability (to 2 decimal places) that the average of the 95 wait times exceeds 6 minutes?
Part c) Find the probability (to 2 decimal places) that 92 or more of the 95 wait times exceed 1 minute. Please carry answers to at least 6 decimal places in intermediate steps.
Part d) Use the Normal approximation to the Binomial distribution (with continuity correction) to find the probability (to 2 decimal places) that 56 or more of the 95 wait times recorded exceed 5 minutes.
I know that for part c and d I need to use binomial distribution, however I am unsure of what to do for part a and b
What I tried for a was ((637/95)-(536/95))/12 and for b I thought I could just do 7/12 since it is uniformly distributed, but neither are correct. Can anyone tell me if there is a certain formula to follow? Or what I am doing wrong? Thanks[/B]
In part (a) you are dealing with the random sum ##S = \sum_{i=1}^{95} W_i##, where the individual wait times ##W_1, W_2, \dots, W_{95}## are an independent sample from the distribution ##\text{Unif}(0,12)##. You are being asked to find ##P(536 \leq S \leq 637)##, or maybe ##P(536 < S < 637)##---it is not clear which.
In principle you can locate formulas for the probability density of a sum of 95 independent uniform random variables, but the formula is nasty and difficult to use, unless you compute intermediate results to hundreds of decimal places of accuracy. So, the only sensible approach is to use a good approximation to the density of ##S##, and I would bet that your textbook and/or course notes have useful suggestions about that.
In part (b) you are dealing with ##S/95##, and want ##P(S/95 > 6)##. Again, you will need to use an approximation to the exact distribution.
With a reasonably large sample, your uniform distribution will start normalizing, so the average should tend to 6 minutes. Thus, you would expect a fairly high probability that the total time would be close to 6x95=570 mins.
As Ray said, check for a formula in your text that might help you approximate the cumulative probability in that range.
6 minutes is your midpoint. The probability is equal on both sides -- regardless of how many observations.
With the binomial distribution, you have p and 1-p raised to powers based on how many observations you see of each.
92 or more exceed 1 min means that p=prob(x>1) , and 1-p = prob(x<1).
Remember when you take the normal approximation, you will need to adjust for the fact that you have while integer data for frequency. Usually that means you include .5 below the cutoff for > problems and .5 above for < problems.
FAQ: Uniform Distribution Probability
1. What is a uniform distribution probability?
A uniform distribution probability is a probability distribution in which all outcomes have an equal chance of occurring. This means that the probability of any particular outcome is the same as any other outcome. It is often used to model situations where all outcomes are equally likely, such as rolling a fair die or drawing a card from a shuffled deck.
2. How is a uniform distribution probability graphed?
A uniform distribution probability is graphed as a straight horizontal line. The height of the line represents the probability of each outcome, and the line is the same height for all outcomes since they all have the same probability.
3. What is the formula for calculating a uniform distribution probability?
The formula for calculating a uniform distribution probability is: P(x) = 1 / n, where P(x) is the probability of a particular outcome and n is the total number of outcomes. This formula assumes that all outcomes have an equal chance of occurring.
4. How does a uniform distribution probability differ from other probability distributions?
A uniform distribution probability differs from other probability distributions in that all outcomes have an equal chance of occurring, whereas other distributions may have different probabilities for each outcome. Additionally, a uniform distribution probability is a continuous distribution, meaning that it can take on any value within a certain range, whereas other distributions may be discrete, meaning they can only take on certain values.
5. What real-world situations can be modeled using a uniform distribution probability?
A uniform distribution probability can be used to model a wide variety of real-world situations, such as the likelihood of a randomly selected person being left-handed, the chance of a randomly selected card being a heart in a shuffled deck, or the probability of rolling a certain number on a fair die. It is also commonly used in statistics and data analysis to represent a random sample from a larger population.
