natasha13100
- 58
√ω
A uniform rod of mass 1.2 kg and length 1.2 m is pivoted in the horizontal position as shown (black point). The rod is at rest and then released. The acceleration due to gravity is g = 9.8 m/s2.
Part 1. Find the rotational inertia of the rod relative to the axis perpendicular to the screen and passing through the pivot point (in kgm2).
Part 2. As the rod swings downward, its angular speed velocity and the magnitude of its angular acceleration, respectively are (increasing, decreasing, staying the same) and (increasing, decreasing, staying the same).
Part 3. What is the angular speed (in rad/s) of the rod as it passes through the vertical position (when end marked B is at the bottom)?
Part 4. What is the linear speed of the bottom end of the rod (marked B) when it passes the vertical position?(in m/s)
Icm=1/12ml2
Ip=Icm+md2
Ug=mgh
Ui+Ki+Wnoncon=Uf+Kf
Ktrans=1/2mv2
Krot=1/2Iω2
t=Frsinθ
K=Ktrans+Krot
v=ωR
Picture/FBD is attached.
Part 1
Ip=1/12m(l)2+m(l/4)2=1/12*1.2*1.22+1.2*.32=.252
Part 2
increasing and decreasing
Part 3
0=1/2mv2+1/2Iω2+mgh where h=-l/4(distance from pivot to cm which will be directly below pivot when the rod is at the bottom of its swing)
mgh=1/2mv2+1/2Iω2=mgh=1/2mω2R2+1/2Iω2=1/2mω2R2+1/2Iω2
1.2(9.8)(.3)=(1/2(1.2)(.3)2+1/2*.252)ω2=(.18)ω2
ω=√(3.528/.18)=4.42718872424
I am not sure if this is correct, but I used l/4 (distance from pivot to center of mass) as R.
Part 4
mgh=1/2mv2+1/2Iω2
2mgh=mv2+Iv2/R2
2(1.2)(9.8)(.3)=(1.2+.252/.32)v2
v=√(7.056/4)=1.32815661727
or v=ωR2=4.42718872424(.3)^2=0.398446985181
Since these two values for v don't match up, I think I'm doing something wrong.
Icm=1/12ml2
Ip=Icm+md2
Ug=mgh
Ui+Ki+Wnoncon=Uf+Kf
Ktrans=1/2mv2
Krot=1/2Iω2
t=Frsinθ
K=Ktrans+Krot
v=ωR
Part 1
Part 2
Part 3
Part 4
mgh=1/2mv2+1/2Iω2
2mgh=mv2+Iv2/R2
