Uniformly charged ring on the axis
In summary: CIn summary, the electric field on the axis of a uniformly charged ring has a magnitude of 360 kN/C at a point 6.2 cm from the center and 150 kN/C at a point 19 cm from the center. The ring has a radius of 8.8 cm and a total charge of 800 nC.
SlyCedix
The electric field on the axis of a uniformly charged ring has magnitude 360 kN/C at a point 6.2 cm from the ring center. The magnitude 19 cm from the center is 150 kN/C ; in both cases the field points away from the ring.
1. Find the ring's radius.
2. Find the ring's charge.
E=kxQ/(x2 + a2)3/2
360000 = kQ(.062)/(.0622+a2)3/2
150000 = kQ(.19)/(.192+a2)3/2
360/150 = (.062/.19) * ((.0622+a2)/(.192+a2))3/2
(360/150 * .19/.062)2/3 = (.0622+a2)/(.192+a2)
(360/150 * .19/.062)2/3 * (.192+a2)= .0622+a2
(360/150 * .19/.062)2/3 * (.192) - .0622 = a2 - (360/150 * .19/.062)2/3 * a2)
-0.00247871714 = -2.7819469745 a^2
a = sqrt(0.00247871714/2.7819469) = .030 m = 3.0 cm
Which turned out to be incorrect, and with an incorrect radius, I've got nothing to go off of for charge
E=kxQ/(x2 + a2)3/2
150000 = kQ(.19)/(.0192+a2)3/2
360/150 = (.062/.19) * ((.0622+a2)/(.0192+a2))3/2
(360/150 * .19/.062)2/3 = (.0622+a2)/(.0192+a2)
(360/150 * .19/.062)2/3 * (.0192+a2)= .0622+a2
(360/150 * .19/.062)2/3 * (.0192) - .0622 = a2 - (360/150 * .19/.062)2/3 * a2)
Hello @SlyCedix . Welcome to PF.It's just a little Algebra mistake.
What do you get when you divide ##\displaystyle \ \frac{kQ (0.062)} {(0.062^2+a^2)^{3/2}} \ ## by ##\displaystyle \ \frac{kQ (0.19)} {(0.19^2+a^2)^{3/2}} \ ##?
Wow, I cannot believe I missed that.
So the revised eq would be:
$$\frac{360}{150} = \frac{.062}{.19} * (\frac{(.19^2+a^2)}{(.062^2+a^2)})^\frac{3}{2}$$
$$(\frac{360}{150} * .\frac{.062}{.19})^\frac{2}{3} = \frac{(.19^2+a^2)}{(.062^2+a^2)}$$
$$(\frac{360}{150} * \frac{.062}{.19})^\frac{2}{3}* (.062^2+a^2)= .19^2+a^2$$
$$(\frac{360}{150} * \frac{.062}{.19})^\frac{2}{3} * .062^2 - .19^2 = a^2 - (\frac{360}{150} * \frac{.062}{.19})^\frac{2}{3} a^2$$
$$0.033212 = -2.7819469745 a^2$$
~~But that would mean a is non real, despite there being a real answer.~~
Scratch that, put it in my calculator wrong, it's actually
$$-0.02156 = -2.7819469745 a^2$$
Which is still wrong, but closer
You made a similar mistake as previously, when going from the first to the second line .
That was it, thanks, answer was 8.8cm
Likes SammyS
Good.
What total charge did you get ?
800 nC
Likes SammyS
Related to Uniformly charged ring on the axis
1. What is a uniformly charged ring on the axis?
A uniformly charged ring on the axis is a hypothetical model used in physics to represent a ring-shaped object with a uniform distribution of electric charge along its circumference, aligned with the axis that passes through its center.
2. How is the electric field calculated for a uniformly charged ring on the axis?
The electric field at any point along the axis of a uniformly charged ring can be calculated using the equation E = kQx / (x^2 + R^2)^(3/2), where k is the Coulomb's constant, Q is the total charge of the ring, x is the distance from the center of the ring to the point of interest, and R is the radius of the ring.
3. What is the direction of the electric field for a uniformly charged ring on the axis?
The direction of the electric field at any point along the axis of a uniformly charged ring is always parallel to the axis and pointing away from the ring if the charge is positive, and towards the ring if the charge is negative.
4. How does the electric field vary with distance from a uniformly charged ring on the axis?
The electric field strength decreases with increasing distance from a uniformly charged ring on the axis. This decrease follows an inverse square law, meaning that the electric field strength is inversely proportional to the square of the distance from the center of the ring.
5. What is the relationship between the electric potential and electric field for a uniformly charged ring on the axis?
The electric potential at any point along the axis of a uniformly charged ring is directly proportional to the electric field strength at that point. This relationship can be expressed as V = kQ / (x^2 + R^2)^(1/2), where V is the electric potential and k, Q, x, and R have the same definitions as in question 2.
