Uniformly charged rod concept question
In summary, the formula for the electric field at a point to the left or right of a bisected uniformly charged rod would be the integral from one end number to the other end number of k*dq/r^2, with additional components determined using cos and sin functions.
StephenDoty
265
If a uniformly charged rod is bisected in the middle the limits of integration would be (-L/2) to (L/2)? Thus the formula would be the integral from (-L/2) to (L/2) of k*dq/r^2. Now of course there might be an angle so cos(theta) and sin(theta) would need to be added.
If the point at which we are trying to find the electric field at is either to the left or right of the bisecting line, would the limits of integration be one end number to the other end number? like if a rod extended from (0,0) to (6,0), the limits of integration would be 0 to 6 for a point to the left or right of the bisecting line? Thus the formula would be the integral from the left or bottom to the right or top of k*dq/r^2. Of course the components would need to be foun using cos and sin.
But do I have the concept of the limits of integration correct?
Thanks.
Stephen
Yes, you have the concept of the limits of integration correct. The limits of integration for a point to the left or right of the bisecting line would indeed be from one end number to the other end number. As you mentioned, cos and sin functions would need to be added to account for any angle that may exist.
Yes, you have the concept of limits of integration correct. When dealing with a uniformly charged rod, the limits of integration represent the length of the rod, which is from (-L/2) to (L/2) when bisected in the middle. This means that the electric field at any point along the rod can be calculated by integrating from the left or bottom end to the right or top end, depending on the position of the point in question. The use of cos and sin is necessary to take into account any angle that may exist between the point and the rod. Overall, your understanding of the concept and formula for calculating the electric field is correct.
Related to Uniformly charged rod concept question
1. What is a uniformly charged rod?
A uniformly charged rod is a theoretical concept in physics that represents a rod with a constant charge distributed evenly along its length. In other words, if you were to divide the rod into smaller sections, each section would have the same amount of charge.
2. How is the charge distributed along a uniformly charged rod?
The charge is distributed evenly along the length of the rod, meaning that every point on the rod has the same amount of charge per unit length.
3. What is the equation for the electric field of a uniformly charged rod?
The electric field at a distance r from the center of a uniformly charged rod with length L and total charge Q can be calculated using the equation E = (kQ/L)r, where k is the Coulomb's constant (9x10^9 Nm^2/C^2).
4. How does the electric field change as you move away from a uniformly charged rod?
The electric field decreases as you move away from the rod, following an inverse square law. This means that the electric field is strongest close to the rod and decreases as the distance from the rod increases.
5. Can a uniformly charged rod have a negative charge?
Yes, a uniformly charged rod can have a negative charge. When we say "uniformly charged," we are referring to the distribution of charge along the rod, not the polarity of the charge. So a uniformly charged rod can have either a positive or negative charge, as long as it is distributed evenly.
