Union/Intersection of fractions or percentages
  • MHB
  • Thread starter tmt1
  • Tags
    Fractions
In summary: D. So $P(D) = \frac{80}{100} $ OR $P(D) = 35/60$.To solve this question I need to find$$\frac{P(D \cap H)}{P(D)}$$ OR$$\frac{P(D \cap H)}{35/60}$$ So I need to find $P(D \cap H). So how would I find the intersection of these 2? Just take the smaller of 2 numbers, so 20/35?Then I would get $20/35$ which is $5/10$ which seems to be correct.
tmt1
234
In a few exercises, I've needed to get the union or intersection of fractions or percentages.
I'm not confident I fully understand.
If I need the intersection of $A = 0.75$ and $ B = 0.5$, do I just take the larger number and subtract the smaller number? So the $ A \cap B$ would be $0.25$? And the union would just be the larger number i.e. $A$ or $0.75$?
And I suppose the same must be true for fractions.
Is this correct? Seems too easy.
Mathematics news on Phys.org
Hi tmt!
Since you've posted in probability and statistics, are we talking about the intersection and union of chance events?
And the resulting probabilities? (Wondering)
If so, then the product rule states that if events $A$ and $B$ are independent, that then $P(A\cap B)=P(A)P(B)$.
So it would be the product, not the subtraction. If they're not independent, it becomes more complicated.
And the sum rule states that if events $A$ and $B$ are mutually exclusive, that then $P(A\cup B)=P(A)+P(B)$.
So it would be the sum, and not the larger number.
However, we can already see in this case that the sum would be greater than $1$, which is not possible for probabilities, so $A$ and $B$ are definitely not mutually exclusive. In that case we need the general sum rule $P(A\cup B)=P(A)+P(B)-P(A\cap B)$.
I like Serena said:
Hi tmt!
Thanks that is very helpful.
What if it's something thinking more like if $P(A) = 0.75$ and $P(B) = 0.5 $, what is $P(A | B)$?
I need to do $\frac{P(A\cap B)}{P(B)}$ which is $\frac{P(A\cap B)}{0.5}$, so what is $P(A\cap B)$? Is it simply the larger number minus the smaller number so $0.25$? Or would it be $P(A) + P(B) - 1$ which is also $0.25$?
That is unknown.
If A and B are independent, then $P(A \mid B) = P(A)$.
If they are dependent, then $P(A \mid B)$ can be anything between $0$ and $1$.
If A and B are dependent we have insufficient information to find $P(A\cap B)$.
If they are independent we have $P(A\cap B)=P(A)P(B)$.
I like Serena said:
That is unknown.
If they are dependent, then $P(A \mid B)$ can be anything between $0$ and $P(A)$.
Ok, I have 2 examples.
I have a fair coin and a two-headed coin. I choose one of them with equal probability and I flip it. Given that I flipped a heads, what is the probability that I chose the two-headed coin?
Let the event of flipping heads be H. So $P(H) = \frac{3}{4} $ OR $P(H) = 0.75$.
Let the event of picking a coin with 2 heads be 2-HC. So $P(2-HC) = 0.5$. To solve this question I need to find
$$\frac{P(H \cap 2-HC)}{P(H)}$$
OR
$$\frac{P(H \cap 2-HC)}{0.75}$$
So I need to find $P(H \cap 2-HC)$. So how would I find the intersection of these 2? Just take the smaller of 2 numbers, so 0.5?
Then I would get $0.5/ 0.75$ which is $2/3$ which seems to be correct.
The other example I have is:
80% of the customers at a pub order drinks and 35% order food. Assuming that there are no customers who order neither food nor drinks, what is the probability that a customer who orders drinks will also order food?
So let the event of the customers ordering drinks be D. Therefore, $P(D) = 0.8$. Let the event of customers ordering food be F. So, $S(F) = 0.35$.
I need to find
$$\frac{P(F \cap D)}{P(D)}$$ Or
$$\frac{P(F \cap D)}{0.8}$$
So what is $P(F \cap D)$?
The smaller of the 2 numbers? That would be $0.35$ which is incorrect.
I suppose it could be $F + D - 1$ or $0.15$ and this would yield the correct answer.
But is I try this formula in my first example, $P(H \cap 2-HC)$ would equal $0.25$ which would yield the wrong answer.
Furthermore, what about 2 probabilities that don't equal more than 1, than this formula ($A + B -1 $) wouldn't work at all.
Not quite.
We have 4 possible outcomes that are equally likely: (H, fair), (T, fair), (H1, 2-HC), (H2, 2-HC).
Only 2 of them match with $(H \cap 2-HC)$.
So the probability is:
$$P(H \cap 2-HC) = \frac{\text{# favorable}}{\text{# total}}= \frac 24=0.5$$
As a result we get indeed that:
$$P(2-HC \mid H)=\frac{0.5}{0.75}=\frac 23$$
I need to find
Let's see, 80% order drinks, and everyone has to order something.
That means that 20% order food, but not a drink.
Consequently 15% orders both drink and food.
It looks like this:
[TIKZ]
\filldraw[gray!20!white]
(-3,2) node[below right] {0\%} rectangle (3,-2);
\begin{scope}[blend group=soft light]
\filldraw[orange!50!white]
(-1,0) circle (1.5);
\filldraw[olive!40!white]
(1,0) circle (1.5);
\end{scope}
\draw
\draw
(-1,0) node
{65\%}
(-1,1.5) node {80\%};
\draw
(1,0) node
{20\%}
(1,1.5) node {35\%};
\draw
node at (0,0) {15\%};
[/TIKZ]​
ok thanks
FAQ: Union/Intersection of fractions or percentages
What is the difference between union and intersection of fractions or percentages?
The union of two fractions or percentages is the combination of all the numbers that are present in either fraction or percentage. On the other hand, the intersection of two fractions or percentages is the common numbers that are present in both fractions or percentages.
How do you find the union of fractions or percentages?
To find the union of fractions or percentages, you need to first convert them into decimal form. Then, combine all the decimal numbers and convert the result back to fraction or percentage form, if necessary.
How do you find the intersection of fractions or percentages?
To find the intersection of fractions or percentages, you need to first convert them into decimal form. Then, find the common decimal numbers and convert the result back to fraction or percentage form, if necessary.
Can the union or intersection of fractions or percentages be greater than 1?
Yes, the union or intersection of fractions or percentages can be greater than 1. This occurs when the fractions or percentages being combined have common numbers that are greater than 1.
Are there any real-world applications of union and intersection of fractions or percentages?
Yes, there are various real-world applications of union and intersection of fractions or percentages. For example, in statistics, the union of two sets of data can help identify the common characteristics between them, while the intersection can help find the unique characteristics of each set. In finance, the union of different investment portfolios can help create a diversified investment strategy, while the intersection can help identify the common stocks in different portfolios.
