MHB Union of Disjoint Sets with at Most k Sets - Algorithm
  • Thread starter Thread starter evinda
    Sets
The discussion revolves around implementing disjoint sets with union operations using a hash table and double hashing techniques. The focus is on merging two trees corresponding to nodes, utilizing path compression and height reduction methods. The proposed algorithm, `pointer Union(S,T)`, merges two trees by comparing their sizes and adjusting parent pointers accordingly. The challenge presented is how to adapt this merging algorithm within the context of a hash table, which stores keys and pointers to the nodes of the trees. The conversation seeks to clarify the integration of the union operation with the hash table structure while maintaining the efficiency of the disjoint set operations.
evinda
MHB
Hello! (Smirk)Consider an implementation of disjoint sets with union, where there can be at most $k$ disjoint sets.
The implementation uses a hash table $A[0.. \text{ max }-1]$ at which there are stored keys based on the method ordered double hashing.
Let $h1$ and $h2$ be the primary and the secondary hash function, respectively. $A$ contains the keys of the nodes of all of the above trees and also a pointer to the corresponding node for each of them.
I want to write an algorithm that takes as parameters the keys of two nodes and merges the upper trees to which the nodes belong (the nodes can belong to any upper trees, even at the same in which case it appears an appropriate message). At merging, we have to apply techniques of path compression and height reduction.How could we do this? (Thinking)
Technology news on Phys.org
This is the algorithm that merges two up trees, applying the technique of path compression:
Code:
pointer Union(S,T){
  if (S==NULL or T==NULL) return;
  if (S->count>=T->count){
      S->count=S->count+T->count;
      T->parent=S;
      return S;
  else {
      T->count=T->count+S->count;
      S->parent=T;
      return T;
What do we have to do in this case, where we have a hash table? (Thinking)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
