MHB Union of Monoids: Is $(G\cup H,\cdot)$ A Monoid?
  • Thread starter Thread starter eddybob123
    Union
The discussion centers on whether the union of two monoids, $(G \cup H, \cdot)$, can itself be a monoid under a defined operation $\cdot$. Participants present counterexamples demonstrating that without a defined identity element for $\cdot$, $(G \cup H, \cdot)$ fails to satisfy monoid properties. The conversation highlights that while $\cdot$ may be associative and distributive over $+$ in both $G$ and $H$, it does not guarantee closure in the union. Additionally, the complexities of algebraic operations and their closure properties in unions are emphasized, indicating that the union may not retain the monoid structure. Overall, the consensus suggests that $(G \cup H, \cdot)$ does not necessarily form a monoid without careful consideration of the operations involved.
eddybob123
Suppose that $(G,+)$ and $(H,+)$ are both monoids and that the operation $\cdot$ is closed, associative, and distributive over $+$ in $G$ and $H$. My question then is whether or not $(G\cup H,\cdot)$ is necessarily a monoid. I have evidence to suggest that it might, though I cannot prove it.
Hi eddybob123! :)
Suppose we pick $G=\{g\}$, $H=\{h\}$, and the following operation tables.
[TABLE="class: grid"]
[TR]
[TD]+[/TD]
[TD]g[/TD]
[TD]h[/TD]
[/TR]
[TR]
[TD]g[/TD]
[TD]g[/TD]
[TD]g[/TD]
[/TR]
[TR]
[TD]h[/TD]
[TD]h[/TD]
[TD]h[/TD]
[/TR]
[/TABLE]
[TR]
[TD]⋅[/TD]
[TD]g[/TD]
[TD]h[/TD]
[/TR]
[TR]
[TD]g[/TD]
[TD]g[/TD]
[TD]h[/TD]
[/TR]
[TR]
[TD]h[/TD]
[TD]g[/TD]
[TD]h[/TD]
[/TR]
[/TABLE]
Then G∪H is closed for + and ⋅.
Furthermore, both operations are associative and also distributive.
However, there is no unit element for ⋅.
Therefore, (G∪H, ⋅) does not have to be a monoid (proof by counterexample).
Then is it a semigroup?
Then we first need to examine your assertion:
I do not know how to interpret this.
Is ⋅ closed over G and also closed over H? But not necessarily over G∪H?
If so, then it is not closed over G∪H, since g⋅h would not have to be defined.
So I guess I should assume you mean that ⋅ is closed over G∪H?
And then also assume that ⋅ is associative over G∪H?
If so, then (G∪H,⋅) is trivially a semi-group, since its required properties were just stated.
The operations $+$ and $\cdot$ are intended to be less abstract. Yes, $+$ need not be closed over $G\cup H$, but is it required $\cdot$ is closed over it?
In your first post of this thread, it seems as though you have misunderstood my question. Obviously, there is only one non-isomorphic monoid of order one, and that is the trivial one. If you take the union of two trivial monoids, you obtain another trivial monoid, but with a different operation.
Ok, how about this: if $G$ and $H$ are monoids both under the operation $+$, then determine whether or not $(G\cup H\cup \{e\},\cdot)$ is necessarily a monoid. $e$ is the identity of $\cdot$.
I seem to be misunderstanding.:confused:
If ⋅ is well-defined (i.e. closed) over G∪H∪{e}, is associative, and has an identity e, then (G∪H∪{e},⋅) satisfies all conditions for a monoid.
In other words, then there is no need for an operation + or for distributivity.
I am not assuming any of those things. If an operation is distributive and associative, then isn't it automatically closed? This is what forms rings from abelian groups.
Take $G = H = \mathbb{N}\setminus \{0\}$ with operation usual multiplication and $\cdot$ the usual addition. $\left (\mathbb{N}\setminus \{0\}, \cdot \right)$ is not a monoid.
Yes. (Edited)
To form rings, you need 1 set that has + and $\cdot$ defined on it.
Not 2 different sets.
Huh? :confused:
This is a monoid (closed, associative, identity element) - just not a group, since not all elements have an inverse.
mathbalarka said:
$\cdot$ is closed, associative and distributive over $+$, right?
Since $G$ and $H$ has the same operator $+$, the base set of one is necessarily the subset of the other, hence this trivially follows.
Huh? :confused:
Where did you get that $G$ and $H$ have the same operator $+$?
And even if they do, that does not mean one is a subset of the other.
Consider for instance $G=2\mathbb Z$ and $G=3\mathbb Z$ (the multiples of 2 respectively 3).
I like Serena said:
Then ⋅ is not closed on G∪H, but it is associative and distributive on G∪H.
$\cdot$ is associative and distributive on $G$ and $H$, but not on $G\cup H$. How can you define associativity on the elements $a, b, c \in G \cup H$ whereas $a \cdot b$ or $b \cdot c$ are not even defined ( assuming $a, c \in G$ and $b \in H$).
I like Serena said:
This is a monoid
There is no identity, so not.
I like Serena said:
Where did you get that G and H have the same operator +?
I am assuming they are the semigroups instead of the base sets of the semigroups of OP. (Which I think contrary of yours).
Yes, I agree. Well, in my defense, I was working on several things at once and as well as answering to this post.
So, basically, Eddy asks whether or not an operation $\cdot$ can be chosen such that union of two near-semirings (one of the operation being $\cdot$) is always a semigroup. I believe this fails for many cases, although I don't have an example right now in my mind to show.
You are right. I retract my statement. (I can do that, can't I?)
I have removed it from my previous comment.
With regular multiplication, the identity is 1, which is part of the set...
Huh?
Obviously I am missing something here, but (G,+) and (H,+) are stated to be monoids.
What else can G and H be other than sets?
No problem.
:D How often this happens! You mistook the notation by the property in their my post. If you read carefully, you'll see that I have defined $\cdot$ to be the usual addition.
I like Serena said:
Obviously I am missing something here, but (G,+) and (H,+) are stated to be monoids. What else can G and H be other than sets?
It is a matter of notational inconsistency we are having here. I am simply abbreviating $(G, +)$ and $(H, +)$ as $G$ and $H$.
So what you're saying is... addition is distributive over multiplication. (Bandit)
I'm not sure where you are going with this.
To see what I mean, let $F(A)$ be the free semigroup on the set $\{A\}$ and $F(B)$ be the free semigroup on the set $\{B\}$.
Clearly both semigroups are sub-semigroups of $F(A,B)$. The problem is that $F(A) \cup F(B)$ is not, and adding the empty word to this union doesn't change this, we still have a problem with the product $AB$, for example. This problem exists even though we can embed both semi-groups in the semi-ring $\Bbb N[F(A,B)]$, where your proposed closure and distributive properties both hold for $G = \Bbb N[F(A)]$ and $H = \Bbb N[F(B)]$.
In general, algebraic operations perform poorly with respect to unions (because of closure issues). The union generally isn't "big enough" to be the join in the lattice of substructures.
If you are already stipulating that $G \cup H$ is already closed and associative under $\cdot$, there is nothing to prove, we can always create a monoid by "adjoining a 0", and defining:
$x \cdot 0 = 0 \cdot x = x$ for all $x \in G \cup H$.
IF the semi-groups $G,H$ are part of a larger structure that already HAS a multiplicative identity, $e$, then we can run into problems:
Consider $\Bbb N \times \Bbb N$ with the operations:
$(a,b) + (a',b') = (a+a',b+b')$
$(a,b) \cdot (a',b') = (aa',bb')$
Now we can form a monoid from the union of $G = \{(k,k):k \in \Bbb N\}$ and $H = \{(k,0): k \in \Bbb N\}$, taking the unit to be that of $G$.
The problem is, $H$ is not a sub-monoid of $G \cup H$, that is, the inclusion mapping is no longer a monoid homomorphism, because the identity of $H$ is $(1,0)$ which does not map to the identity $(1,1)$ of $G \cup H$.
If, in the example above, we instead took $G = \{(0,k): k \in \Bbb N\}$, then we again get that $G \cup H$ is a semigroup, and we also have that $G \cup H \cup (1,1)$ is a monoid, but now neither of $G,H$ is a submonoid of $G \cup H \cup (1,1)$.
That is, even though the semi-groups structures of $G,H$ are compatible with the semi-group structure of $G \cup H$, the monoid structures are not. Depending on your point of view, this is either a minor inconvenience, or a fatal flaw.
I suspect less trivial examples could be formed with $\text{End}_F(F^n)$ under matrix multiplication, but alas I don't have the time at the moment to look for some.
  • · Replies 26 ·
  • · Replies 16 ·
