goedelite
- 36
This question arises from Chapter ONE, section 2, ex. 7 (d) and (e) of "Introduction to Topology" by Gamelin and Greene.
Xbar may be regarded as the completion of a metric space X by identifying each X with the constant sequence {x,x,...}. Show that when Y is the completion of X, then the inclusion map X -> Y extends to an isometry of Xbar onto Y. In the present context, S is the set of Cauchy sequences in X. Xbar is the set of equivalence classes of S, classes which in the limit have a vanishing metric: lim d(s_k, t_k) = 0 <-> {s} eq {t}.
It should be noted that the completion Y of X means that Y is a complete space means that Cauchy sequences in Y have a limit AND X is dense in Y.
A hint is offered: Define a map of Xbar into Y by sending the equivalence class of {s_k} to the lim{s_K). The authors then state that this (the mapping) is an isometry of Xbar onto Y.
Isometry of Xbar onto Y: rho(sbar,tbar) = d(s,t)
1. My effort is first to understand what the authors write. For example, though the sequences in S have the Cauchy property, nowhere is it stated that the space X is complete. If X is the space of reals, then we know it is complete. All that is given about X is that it is a metric space. The metric has a range in R, but we don't know that X is in R.
2. A subset of Xbar, the constant sequences, may be identified with the points of X. All of the sequence of Xbar may be identified with their limits, but not all the sequences of Xbar have limits (see 1.) Thus, I do not see that the map of X into Y is defined. If X were a complete space, then one could have a mapping into but not onto, because each point of Y could come from more than one sequence of Xbar. Every point of Y would come from every sequence contained in an equivalence class; they all would have the same limit, y.
I believe if I understood the above two points clearly, which I apparently do not, then I would see the isometry. I gather that the uniqueness means that any other mapping would produce an isometry.
