Uniqueness of Solution for $\Delta u=0$ in a Ball with Boundary Condition $\phi$
  • MHB
  • Thread starter evinda
  • Tags
    Uniqueness
In summary, the conversation discusses the uniqueness of a solution to a problem involving the Laplace equation and a given boundary condition. It is proven through the use of a theorem and the definition of a function P. The conversation also delves into the properties of the integral and the continuity of the given function. Further explanations are provided for the properties and the reasoning behind them.
evinda
MHB
3,836
Hello! (Wave)
Let $(\star)\left\{\begin{matrix}
\Delta u=0 & \text{ in } B_R \\
u|_{\partial{B_R}}=\phi &
\end{matrix}\right.$.
Theorem: If $\phi \in C^0(\partial{B_R})$ then there is a unique solution of the problem $(\star)$ and $u(x)=\frac{R^2-|x|^2}{w_n R} \int_{\partial{B_R}} \frac{\phi(\xi) dS}{|x- \xi|^n}$.
Proof: if $x_0 \in \partial{B_R}$ then it has to hold that $\lim_{x \to x_0 } u(x)=\phi(x_0)$.
$P(x, \xi)=\frac{R^2-|x|^2}{w_n R |x-\xi|^n}$
It holds that $\int_{\partial{B_R}} P(x, \xi) dS=1$.
$$\left| u(x)- \phi(x_0)\right|=\left| \int_{\partial{B_R}} P(x, \xi) (\phi(\xi)-\phi(x_0)) dS\right| \leq \int_{\partial{B_R}} P(x, \xi) |\phi(\xi)-\phi(x_0)| dS= \int_{|\xi-x_0| \leq \delta} P(x, \xi)|\phi(\xi)-\phi(x_0)| dS+\int_{|\xi-x_0| > \delta} P(x, \xi)|\phi(\xi)-\phi(x_0)| dS $$
Let $I_1=\int_{|\xi-x_0| \leq \delta} P(x, \xi)|\phi(\xi)-\phi(x_0)| dS$ and $I_2=\int_{|\xi-x_0| > \delta} P(x, \xi)|\phi(\xi)-\phi(x_0)| dS$.
$\forall \epsilon >0 \exists \delta>0$ so that if $|\xi-x_0| \leq \delta$ then $|I_1|< \frac{\epsilon}{2}$.
$I_2 \leq 2M \frac{R^2-|x|^2}{w_n R \delta^n} \int_{|\xi-x_0|=R} dS=2M \frac{R^2-|x|^2}{\delta^n} R^{n-2} \leq \frac{\epsilon}{2}$ if $x$ is near to $ x_0 $.
So we have the following: $\forall \epsilon>0 \exists \delta>0$ such that $|u(x)-\phi(x_0)| \leq \epsilon \Leftrightarrow \lim_{x \to x_0} u(x)=\phi(x_0)$.
First of all, why does it hold that $\left| u(x)- \phi(x_0)\right|=\left| \int_{\partial{B_R}} P(x, \xi) (\phi(\xi)-\phi(x_0)) dS\right| $ and not $\left| u(x)- \phi(x_0)\right|=\left| \int_{\partial{B_R}} ( P(x, \xi) \phi(\xi)-\phi(x_0) ) dS\right|$ ?Also why does it hold that $\int_{\partial{B_R}} P(x, \xi) |\phi(\xi)-\phi(x_0)| dS= \int_{|\xi-x_0| \leq \delta} P(x, \xi)|\phi(\xi)-\phi(x_0)| dS+\int_{|\xi-x_0| > \delta} P(x, \xi)|\phi(\xi)-\phi(x_0)| dS$ ?
Could you also explain to me how we get the inequalities for $I_1$ and $I_2$ ?
Hey evinda! (Smile)
Isn't:
$$\int_{\partial{B_R}} \phi(x_0)dS = w_nR^{n-1}\phi(x_0) \ne \phi(x_0)$$
(Wondering)
While:
$$\phi(x_0) = u(x_0) = \int_{\partial{B_R}} P(x_0,\xi) \phi(x_0)dS
We can split up the domain of an integral into 2 subsets that combine together to the domain.
Compare for instance:
$$\int_0^1 f(x)dx = \int_0^\delta f(x)dx + \int_\delta^1 f(x)dx$$
Note that we're still constrained to $\partial{B_R}$. (Nerd)
Let's start with $I_1$.
$$|I_1|=\left|\int_{|\xi-x_0| \leq \delta} P(x, \xi)|\phi(\xi)-\phi(x_0)| dS\right| \\
\le \sup_{|\xi-x_0| \leq \delta} |P(x,\xi)| \cdot \sup_{|\xi-x_0| \leq \delta} |\phi(\xi)-\phi(x_0)| \cdot \int_{\partial{B_R}}dS \\
\le M \cdot \epsilon' \cdot w_nR^{n-1} = \frac\epsilon 2
where $\epsilon'$ is introduced since $\phi$ is given to be continuous.
So given an $\epsilon$ we can find an $\epsilon'$ and from the continuity of $\phi$, we can find the appropriate $\delta$.
Note that we can only guarantee the bound on $|P(x, \xi)|$ if $x\notin \partial{B_R}$, which is given since $x\in B_R$. (Thinking)
I like Serena said:
Isn't:
(Wondering)
While:
Oh yes, right... (Nod)
Ok...
I see.
Don't we have from the continuity of $\phi$ that $\forall \epsilon'>0 \exists \delta>0$ such that if $|\xi-x_0| \leq \delta$ then $|\phi(\xi)-\phi(x_0)| \leq \epsilon'$ and then we set $\epsilon=2M \epsilon' w_n R^{n-1}$ ? Or am I wrong? (Thinking)
How can find the appropriate $\delta$?
Could you explain to me further why $|P(x, \xi)|$ is only bounded if $x\notin \partial{B_R}$?
We just did. (Thinking)
For any $\epsilon>0$ we define $\epsilon'=\frac{\epsilon}{2M w_n R^{n-1}}$.
From the continuity of $\phi$ we know that for this $\epsilon'>0$ we can find a $\delta>0$, such that if $|\xi-x_0| <\delta$ then $|\phi(\xi)-\phi(x_0)| < \epsilon'$.
It follows that for this same $\delta$ we now also have $|I_1|<\frac\epsilon 2$.
Because $P(x,\xi)=\frac{R^2-|x|^2}{w_nR |x-\xi|^n}$, which is not defined if $x=\xi$.
But that can't be because $x$ is an element of the interior of the ball, and $\xi$ is on the boundary of the ball. (Nerd)
From the continuity of $\phi$ we know that for this $\epsilon'>0$ we can find a $\delta>0$, such that if $|\xi-x_0| <\delta$ then $|\phi(\xi)-\phi(x_0)| \leq \epsilon'$.
I understand.
Do we assume that $x$ is an element of the interior of the ball, and $\xi$ is on the boundary of the ball? Or how do we know it? (Worried)
I thought that we would have at the boundary $|\xi-x|=R$. So do we have $|\xi-x|=0$ ?
The given formula for $u(x)$ has an integral in it that is not defined if $x$ is on the boundary.
That's because it has $|x-\xi|$ in the denominator, which would become zero when $\xi=x$ ($\xi$ is always a point on the boundary).
Therefore we have to conclude that $x$ is intended to be a point in the interior of the ball. (Thinking)
$x$ is an arbitrary point inside $B_R$, which is the ball with center $0$ and radius $R$, while $\xi$ is a point on the boundary.
So we have $|\xi - 0|=R$ and $0<|\xi-x|<2R$. (Thinking)
I see.
I like Serena said:
$x$ is an arbitrary point inside $B_R$, which is the ball with center $0$ and radius $R$, while $\xi$ is a point on the boundary.So we have $|\xi - 0|=R$ and $0<|\xi-x|<2R$. (Thinking)
Ok. So we have
$$\sup_{|\xi-x_0| \leq \delta} |P(x,\xi)|=\sup_{|\xi-x_0| \leq \delta} \left| \frac{R^2-|x|^2}{w_n R |x-\xi|^n} \right|=\frac{R}{w_n} \sup_{|\xi-x_0| \leq \delta} \frac{1}{|x-\xi|^n}$$
Since $|x-\xi|>0$ we have that $\frac{1}{|x-\xi|^n} \to 0$ while $n \to +\infty$ and so $\sup_{|\xi-x_0| \leq \delta} |P(x,\xi)| \to 0$ and so it is bounded. Right? (Thinking)
evinda said:
Ok. So we have
Erm... shouldn't we pick $n$ to be some unknown constant? I thought it wasn't supposed to go to infinity. Or is it? (Wondering)
We do have that there is some $\epsilon > 0$ such that $|x-\xi|>\epsilon >0$.
That's because $x$ is supposed to be inside the ball, while $\xi$ is supposed to be on the boundary of the ball.
Isn't therefore:
$$\sup_{|\xi-x_0| \leq \delta} \frac{1}{|x-\xi|^n} < \frac{1}{\epsilon^n}$$
(Wondering)
Oh yes, you are right.
Isn't therefore:
(Wondering)
I see... But $\frac{1}{\epsilon^n}$ isn't bounded for any $\epsilon>0$. So how can we show that $\sup_{|\xi-x_0| \leq \delta} |P(x,\xi)|$ is bounded? (Thinking)
Not for any $\epsilon>0$... (Thinking)
For any given $x$ in the inside of the ball there exists an $\epsilon>0$ such that for each $\xi$ on the boundary with $|\xi - x_0|\le\delta$ we have $|\xi - x|>\epsilon$.
So for every given $x$ in the inside of the ball $\sup_{|\xi-x_0| \leq \delta} |P(x,\xi)|$ is bounded. (Thinking)
Ah I see... (Nod)
Can you also explain to me how we get the inequality for $I_2$ ? (Thinking)
evinda said:
Ah I see... (Nod)
We can write:
$$|I_2|=\left|\int_{\xi \in \partial B_R,\ |\xi-x_0| > \delta} P(x, \xi)|\phi(\xi)-\phi(x_0)| dS\right| \\
\le \sup_{\xi \in \partial B_R,\ |\xi-x_0| > \delta} |P(x, \xi)| \cdot \sup_{\xi \in \partial B_R,\ |\xi-x_0| > \delta} |\phi(\xi)-\phi(x_0)| \cdot \left|\int_{\xi \in \partial B_R,\ |\xi-x_0| > \delta}dS\right|
How might we continue? (Wondering)
How can we get a relation for the integral $\int_{\xi \in \partial B_R,\ |\xi-x_0| > \delta}dS$ ?
Also we have that $\int_{\partial{B_R}} P(x,\xi) ds_{\xi}=1$. Does this imply that $\int_{|\xi-x_0|> \delta, \xi \in \partial{B_R}} P(x,\xi)ds=1$ ? (Thinking)
Don't we have that:
$$\int_{\xi \in \partial B_R,\ |\xi-x_0| > \delta}dS \le \int_{\xi \in \partial B_R}dS = w_n R^{n-1}$$
(Wondering)Btw, I don't understand yet why it's supposed to hold that $\int_{\partial{B_R}} P(x,\xi) ds_{\xi}=1$.
Do you?
Is it somewhere in your notes?
Anyway, if it holds, then, since $P(x,\xi) > 0$, we have:
$$\int_{|\xi-x_0|> \delta, \xi \in \partial{B_R}} P(x,\xi)ds \le \int_{\partial{B_R}} P(x,\xi) ds_{\xi} = 1$$
It seems we don't need it though. (Thinking)
I like Serena said:
Don't we have that:
(Wondering)
Oh yes, right.
Do you?
We have that if $u \in C^2(B_R(0)) \cap C^1(\overline{B_R}(0))$ is harmonic in $B_R(0)$, then the following formula holds:
$u(x)=\frac{R^2-|x|^2}{w_n R} \int_{\partial{B_R}} \frac{u}{|x-\xi|^n} ds_{\xi}$.
For $u=1$ we get that $\int_{\partial{B_R}} P(x,\xi) ds_{\xi}=1$.
So then we have $\int_{|\xi-x_0|> \delta, \xi \in \partial{B_R}} P(x,\xi) |\phi(\xi)-\phi(x_0)| dS \leq \sup_{\xi \in \partial{B_R}, |\xi-x_0|> \delta} |\phi(\xi)-\phi(x_0)| \int_{|\xi-x_0|>\delta, \xi \in \partial{B_R}} P(x, \xi) dS \leq 2M \int_{\partial{B_R}} P(x,\xi) dS=2M $So we have to pick $4M$ as $\epsilon$ ?
Ok! (Happy)
I don't think so. We cannot make $4M$ as small as we want to.
Shouldn't we pick $\xi$ sufficiently close to $x_0$ for the proof?
That is, $|\xi-x_0|<\delta$? (Wondering)
I like Serena said:
Ok! (Happy)
We pick $|x-x_0|$ to be sufficiently small.
I think that I understood the inequality of my notes.
Since $\phi$ is bounded, there is a $M>0$ such that $|\phi| \leq M$.
So $\int_{|\xi-x_0|> \delta, \xi \in \partial{B_R}} P(x,\xi) |\phi(\xi)-\phi(x_0)| ds \leq 2M \int_{|\xi-x_0|>\delta, \xi \in \partial{B_R}} \frac{R^2-|x|^2}{w_n R |x-\xi|^n} ds < 2M \frac{R^2-|x|^2}{R} \frac{1}{\delta^n} R^{n-1}, \text{ since } |\xi-x_0|> \delta$.
Since $|x-x_0|$ is sufficiently small , $|x| \to |x_0|=|R|$ and so $\frac{R^2-|x|^2}{R} \frac{1}{\delta^n} R^{n-1} \to 0$ and so it is $\leq \frac{\epsilon}{2}$.
Oh yes. :eek:
Good! (Happy)
FAQ: Uniqueness of Solution for $\Delta u=0$ in a Ball with Boundary Condition $\phi$
What does the equation $\Delta u=0$ represent?
The equation $\Delta u=0$ represents Laplace's equation, which is a partial differential equation commonly used in mathematical physics to model steady-state systems with no sources or sinks of energy.
What does the term "uniqueness of solution" mean?
"Uniqueness of solution" means that there is only one possible solution to the given equation that satisfies all of the specified conditions. In the case of $\Delta u=0$ in a ball with boundary condition $\phi$, this means that there is only one possible solution for the function $u(x,y,z)$ that satisfies Laplace's equation and the given boundary condition $\phi$ within the defined ball.
Why is uniqueness of solution important in this context?
In the context of Laplace's equation in a ball with a given boundary condition, uniqueness of solution is important because it ensures that there is only one possible solution for the system. This means that the solution is well-defined and can be used to accurately model and predict the behavior of the system.
How is uniqueness of solution determined for $\Delta u=0$ in a ball with boundary condition $\phi$?
Uniqueness of solution for $\Delta u=0$ in a ball with boundary condition $\phi$ is typically determined using mathematical proofs and techniques, such as the maximum principle and the method of Green's functions. These methods can show that a unique solution exists and can also help to find the specific form of the solution.
Are there any situations where uniqueness of solution may not hold for $\Delta u=0$ in a ball with boundary condition $\phi$?
Yes, there can be situations where uniqueness of solution may not hold. For example, if the boundary condition $\phi$ is not well-defined or if the given ball contains sources or sinks of energy, then uniqueness of solution may not hold. In these cases, additional conditions or techniques may be needed to determine a unique solution.
