Unit Circle Chord Probability: POTW #180 Sept. 7, 2015
  • MHB
  • Thread starter anemone
  • Tags
    2015
In summary, the Unit Circle Chord Probability is a mathematical concept used to determine the likelihood of a randomly selected chord on a unit circle falling within a certain range of lengths. It is calculated by finding the ratio of the chord length to the radius, and has significance in understanding the distribution of chords on a circle. It is closely related to the Pythagorean Theorem and can also be applied to other shapes, though the formula may differ.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Two points are picked at random on the unit circle $x^2+y^2=1$. What is the probability that the chord joining the two points has length at least 1?
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution:):
1. MarkFL
2. lfdahl
Solution from MarkFL:
By symmetry, let us only consider the upper half of the circle. WLOG, let one of the points be at (1,0). We find the angle subtended at the origin of the point whose chord has a length of 1 to be \(\displaystyle \frac{\pi}{3}\). Hence the probability of the chord having a length of at least 1 must be:
\(\displaystyle P(x)=\frac{2}{3}\)
FAQ: Unit Circle Chord Probability: POTW #180 Sept. 7, 2015
What is the Unit Circle Chord Probability?
The Unit Circle Chord Probability is a mathematical concept used to determine the likelihood of a randomly selected chord on a unit circle falling within a certain range of lengths. It is often used in geometry and trigonometry to solve problems involving circles and angles.
How is the Unit Circle Chord Probability calculated?
To calculate the Unit Circle Chord Probability, you need to first determine the length of the chord and the radius of the circle. Then, you can use the formula P = 2r/s, where P is the probability, r is the radius, and s is the length of the chord. This formula assumes that the chord is randomly selected.
What is the significance of the Unit Circle Chord Probability?
The Unit Circle Chord Probability is important in understanding the distribution of chords on a circle. It allows us to make predictions about the likelihood of a chord having a certain length, which can be useful in real-world scenarios involving circles and angles.
How is the Unit Circle Chord Probability related to the Pythagorean Theorem?
The Pythagorean Theorem states that in a right triangle, the square of the length of the hypotenuse (the side opposite the right angle) is equal to the sum of the squares of the other two sides. In a unit circle, this theorem can be used to calculate the length of a chord. This makes the Unit Circle Chord Probability closely related to the Pythagorean Theorem.
Can the Unit Circle Chord Probability be applied to other shapes besides circles?
Yes, the concept of chord probability can be applied to other shapes, such as ellipses or parabolas. However, the formula for calculating it may differ depending on the shape. For circles, the formula is simplified due to the symmetry of the shape.
