Unit conversion meters Newtons years seconds
In summary, unit conversion is the process of converting a value from one unit of measurement to another, often done for convenience or comparison. Meters (m) is the unit for length in the metric system, while Newtons (N) is the unit for force and Seconds (s) is the unit for time. To convert between meters and feet, multiply the number of meters by 3.28 or divide the number of feet by 3.28.
jones123
Hi,
I need to convert a value of 12*10-16 m7 N-3 y-1 to the units of kPa-3 m2 s-1. Can anyone help me?
where: m = meters, N = Newton, y = year, s = seconds.
Thanks!
##1\, Pa = 1 Nm^{-2}## so you will get into trouble with the meters. What a year is depends on your definition. As year is no SI unit, there is no unique amount of seconds to convert it to. If that isn't sufficient for you, then re-post this in our homework section and show us some effort.
Thread closed.
FAQ: Unit conversion meters Newtons years seconds
What is unit conversion?
Unit conversion is the process of converting a value from one unit of measurement to another. This is often done to make measurements more convenient or to compare measurements from different systems.
What is the unit for length in the metric system?
Meters (m) is the unit for length in the metric system. It is equivalent to approximately 3.28 feet.
What is the unit for force in the metric system?
Newtons (N) is the unit for force in the metric system. It is defined as the force required to accelerate a mass of 1 kilogram at a rate of 1 meter per second squared.
What is the unit for time in the metric system?
Seconds (s) is the unit for time in the metric system. It is defined as the duration of 9,192,631,770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the cesium-133 atom.
How do you convert between meters and feet?
To convert meters to feet, multiply the number of meters by 3.28. To convert feet to meters, divide the number of feet by 3.28.
10K
