Unit Conversions: kJ/mol to kJ/litre
  • Thread starter Thread starter clintyip
    Unit
To convert 4163 kJ/mol of energy from a substance with a molar mass of 86.14 g/mol to kJ/L, the density of the substance (0.6548 g/mL) must be used. The conversion begins by multiplying 4163 kJ/mol by the conversion factor of 1 mol/86.14 g, resulting in 4163 kJ/86.14 g. This value is then multiplied by the density to yield 31.64 kJ/mL. To convert to kJ/L, this result is multiplied by 1000, giving 31645.4 kJ/L, although this value is inconsistent with the known heat of combustion for hexane, which is 29.3 kJ/L. The discrepancy suggests a possible misunderstanding regarding the units, potentially indicating a need to consider megajoules per liter instead.
clintyip
Let's say I have 4163 kJ/mol of energy coming from a substance with molar mass 86.14g/mol. How would I convert the 4163 kJ/mol of energy to kJ/litre?
Thanks.
Thanks.
You'll need to also know the density (g/L) of the substance.
The density of this substance is 0.6548 g/mL.
your answer wants kJ on top, so you start with 4163 kJ/mol .
You multiply by a number that has moles on top , so they cancel.
but now there's something else on the bottom,
so you multiply by a number that has grams on top . then you're done.
But I don't have a number with mols on top o_o
Conversion factor
\frac {86.14 g} {1 mol}
can be reversed to
\frac {1 mol} {86.14 g}
The idea is that conversion factor equals 1, switching nominator and denominator doesn't change the value, although it moves units.
Borek said:
Conversion factor
can be reversed to
That means, I can multiply 4163kj/mol by 1/86.14g, which then I get 4163kJ/86.14g.
Then I multiply this number by the density. So 4163kJ/86.14g x 0.6578g/mL
which equals to 31.64 kJ/mL
Is that right?
To be precise by 1 mol/86.14g, but I guess it is just a typo.
Is that right?
OK so far, but you are not there yet - you need to convert it to kJ/L. But that's the simplest part.
Don't I just multiply it by 1000? So I get 31645.4 kJ/L.
But the thing is, this substance is Hexane, and according to Wikipedia, it has a heat of combustion of 29.3 kJ/L. The two numbers aren't even remotely close.
Yes.
Obviously what they mean is MJ/L, otherwise their numbers are not consistent. As much as I like wikipedia, it is hardly a definite source.
