Unital rings, homomorphisms, etc
The discussion revolves around the uniqueness of a homomorphism in the context of unital rings and their properties. The user has successfully completed the first problem and is working on the second, which involves showing that a homomorphism psi exists from RxS/~ to T that satisfies specific conditions. To establish uniqueness, it is essential to demonstrate that each step in defining psi leaves no alternative choices that meet the required criteria. The conversation highlights the importance of constructing a diagram of the involved homomorphisms and understanding how the mappings relate to each other. Ultimately, the uniqueness of psi hinges on showing that psi(1/s) can only be defined in one way, leading to the conclusion that psi(r/s) is uniquely determined.
calvino
I've already completed 1), but it's necessary for one to know it for question 2). I'm pretty sure that I've found my homomorphism in 2, but I don't know whether or not is unique. How do I show a homomorphism is unique in this case?
Problem 1: Let R be a commutative unital ring, and let S be a multiplicative submonoid of R. Define an equivalence relation ~ on R x S by (a,s)~(b,t) if there is r in S with rat = rbs. Let a/s denote the ~-equivalence class of (a,s). Show that with
a/s + b/t = (at+bs)/st and (a/s)(b/t) = ab/st
one can make RxS/~ into a commutative, unital ring, and that j(a) = a/1 defines a homomorphism j of unital rings from R into RxS/~ that maps S into the group of invertible elements of RxS/~
Problem 2 (=continuation of Problem 1): Let R and S be as above, and let phi: R --> T be a homomorphism that maps S into the group of invertible elements of the commutative unital ring T. Show that there is unique homomorphism psi: RxS/~ ---> T of unital rings with psi.j = phi.
The condition psi(j(r))=phi(r) tells you that psi(r/1)=phi(r). What must psi(1/s) be?
i understand how to define the function (i think). Am i suppose to see it's uniqueness, naturally?
How did you find the homomorphism? What steps did you take? At each step, can you argue that there is no other choice you could have made that would still leave you with a function satisfying the necessary conditions? If so, you have uniqueness.
can we use the fundamental theorm of homomorphisms?
i didn't. i simple constructed a diagram of the homomorphisms involved and showed that since psi.j is in a sense doing the same things as phi is, then they method is unique.
I have no idea what "since psi.j is in a sense doing the same things as phi is, then they method is unique" means. Like I was saying before, psi(r/1)=phi(r). Can you show you only have one choice for psi(1/s)? Then psi(r/s)=psi(r/1)psi(1/s) is unique.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
