Unitary Matrices and Their Entry Values Proof
In summary, the homework statement asks for a way to make a unitary matrix equal the identity matrix. The attempted solution states that one can use the summation formula for the components of a complex number to calculate that the sum of the numbers squared must equal one.
RJLiberator
63
Show that |A_ij| ≤ 1 for every entry A_ij of a Unitary Matrix A.
A matrix is unitary when A^†*A=I
Where † is the hermitian operator, meaning you Transpose and take the complex conjugate
and I = the identity matrix
I'm having a hard time starting this one out.
It seems to make sense to me, as we need to find a way to make them equal the identity matrix.
So we have something like:
[Aij*T][Aij]
[Aji*][Aij]
I'm not quite sure where to go in any direction, how I can get the necessary conditions applied to this proof.
Any point of guidance may help.
The index notation for an identity matrix ##I## is ##I_{ij} = \delta_{ij}##. So, for a unitary matrix ##A##, ##A_{ij}A_{kj}^* = \delta_{ik}##, what can you conclude from this relation?
Likes RJLiberator
Write the entries of the resultant matrix ##I = A^\dagger A## as ##\delta_{ij} = \sum_k \left[A^\dagger\right]_{ik}\cdot \left[A\right]_{kj}##.
Here I used that ##\left[ I\right]_{ij} = \delta_{ij}##.
Now you want to get rid of the hermitian conjugation, using what you said already.
Does that help?
Edit: Oops too slow
Likes RJLiberator
Well, let's see.
So we have the notation for the identity matrix.
We use the summation formula for the components.
We can apply the definition of the hermitian conjugation to the sum.
We see the sum of [A_ki*][A_kj] = the delta element of the identity matrix.
Since we are looking at the ij'th component, the delta element = 0.
Sum[[A_ki*][A_kj]] = 0
(A_kj)*=0 ??
You want to look at the elements ##\delta_{ii}=1##.
The zeroes (##\delta_{ij}\text{ with } i\neq j##) are quite useless in this case.
Likes RJLiberator
hm, I see.
Akj*=1
HM.
This reminds me of the form e^(-itheta) to represent a complex number.
Since A_kj is the kj'th element of the matrix, it is a number, a complex number that can be represented by e^(-itheta) in this case due to conjugation.
This means Akj*=1=cos(x)-isin(x)
Since we have no imaginary number here, sin(x)=0, and cos(x) is bounded by 1.
Is this the correct way to go about this proof? Albeit, needs a bit of polishing?
What you get is the following expression
##1 = \sum_k a^*_{ki}\cdot a_{ki} = \sum_k |a_{ki}|^2##
Here I used that the modulus squared of a complex number is ##c## is given by ##|c|^2 = c^* c##.
So we know that sum above equals one and that the numbers are non-negative.
Can you finish this reasoning?
Likes RJLiberator
Hm, what's throwing me off is the indexing. How did it become _ki for both of them? I can see the transpose definition made a_ik into a_ki, but why is the other index going from a_kj to a_ki?
If ##1 = \sum_k |a_{ki}|^2##
Then it's clear to see that a sum of numbers, squared must equal 1, must mean that the components of the sum add up to one or are less than one.
consider it is all non-negative components.
Because we are looking at elements on the diagonal.
We started from ##\delta_{ii}##. Naturally this should be adopted in the sum as well.
The conclusion is right by the way.
Likes RJLiberator
Okay, I just wrote it down. I am starting to understand it more clearly now. It still is the most foreign one on this assignment, but let's see.
1. Write down as entries of the matrix.
2. Next, note that we are looking at the interesting elements of the matrix, the diagonals where delta is not equal to 0, but instead equal to 1 of the identity matrix.
##delta_{ii} = \sum_k a^*_{ki}\cdot a_{ki} ##
3. Note that delta_ii = 1 and that we can apply a property of complex conjugates so that we see the absolute value of the square of the a_ki'th component.
4. Now I use reasoning to simply state that, Hey, we are adding together components here, and then taking the square, and this must equal one, so the components must be less than or equal to 1.
Walouh.
A pretty smooth proof.
What threw me off was the indexing of the summation. I understand the delta summation part well. I'm still foggy on the summation process. So we are summing from k=1 to k=i? The rows? The columns?
From k=1 to k=n. Here n is the number of rows and columns our square matrix has.
With regards to the confusion, are you using the Einstein summation convention?
Because we don't use it here.
The sum-expression is how we can define matrix multiplication. You can try it for small matrices if you still think its fishy.
Likes RJLiberator
Oh, no, I am using the same summation convention as you are, I believe.
This helped me out.
I think I simply need more practice with summation definitions of matrix elements.
Thank you kindly for your helping hand here.
Related to Unitary Matrices and Their Entry Values Proof
1. What is a unitary matrix?
A unitary matrix is a square matrix where the conjugate transpose of the matrix is equal to its inverse. In other words, a unitary matrix satisfies the property U*U^T = U^T*U = I, where U* denotes the complex conjugate transpose of U, U^T denotes the transpose of U, and I is the identity matrix.
2. What are the properties of unitary matrices?
Some key properties of unitary matrices include:
  • Every unitary matrix is square and has the same number of rows and columns.
  • The determinant of a unitary matrix is a complex number with absolute value 1.
  • The product of two unitary matrices is also a unitary matrix.
  • The inverse of a unitary matrix is its conjugate transpose.
  • The eigenvalues of a unitary matrix have absolute value 1.
3. How can unitary matrices be used in quantum mechanics?
In quantum mechanics, unitary matrices are used to represent quantum operations or transformations on quantum states. These matrices are used to describe the evolution of a quantum system over time and to calculate the probabilities of different measurement outcomes. Unitary matrices also play a crucial role in quantum error correction and quantum computing algorithms.
4. How can we prove that a matrix is unitary?
To prove that a matrix is unitary, we need to show that it satisfies the definition of a unitary matrix. This means we need to show that the matrix multiplied by its conjugate transpose is equal to the identity matrix. This can be done by performing the matrix multiplication and showing that the result is indeed the identity matrix.
5. Can unitary matrices have complex entry values?
Yes, unitary matrices can have complex entry values. In fact, most unitary matrices have complex entries. This is because the conjugate transpose operation involves taking the complex conjugate of each entry in the matrix. So, even if the original matrix has only real entries, the conjugate transpose will introduce complex values. However, there are some special cases where a unitary matrix can have all real entries, such as the identity matrix or certain rotation matrices.
10K
  • Linear and Abstract Algebra
  • Quantum Physics
