Units of loudness of sound, being a subjective quantity
  • Thread starter Manraj singh
  • Tags
    Sound Units
In summary: Loudness is a sensation, and it is measured in decibels. Decibels are an absolute measure of a sound, and are the same for all people. It is a scale based on how a sound changes the air pressure, and is different for different frequencies.
Manraj singh
66
I am learning sound. My teachers and textbook say loudness of sound is a subjective quantity, it is different for every person, while intensity is the objective quantity. The first section says intensity is a measurable quantity, WHILE LOUDNESS IS JUST A SENSATION. On the very next page they have given the units of loudness of sound, decibel and phon. Don't the two contradict each other? If loudness of sound is just a sensation, how does it have units to measure it? This has completely boggled my mind. Please help
Decibels are an absolute measure of a characteristics of a sound. How your particular set of ears perceive a given decibel level is objective and can differ from mine.
While it may primarily be a subjective quantity, you can still take people and have them rate how loud a sound is and then take those results and assign a value to the measurements.
This is identical to how the magnitude system was initially developed to measure the brightness of different stars. For example, a magnitude 0.0 star is 2.5 times brighter than a magnitude 1.0 star, but the early magnitude system claimed it was only 2.0 times brighter since it looks only twice as bright to the eye.
Sound intensity (in decibels) is just a different scale for measuring the change in air pressure in a sound wave.
The scale for sound loudness is different for each person, and changes as the person gets older. The scale for loudness (in phons) was made by doing experiments with people, asking them to adjust to amplitude of sounds so that two sounds of different frequencies had the same loudness, or to adjust sounds at the same frequency so one was "twice as loud" as the other. The standard scale for loudness in phons is the average of those experiments on many people, and is defined as a set of curves relating phons to decibels.
(from http://hyperphysics.phy-astr.gsu.edu/hbase/sound/eqloud.html)
Note that the shape of the curves varies with the sound level, and the intensity (in dB) for equal loudness changes with the frequency of the sound.
FWIW there is a similar effect for the pitch of a sound as judged by humans, compared with the frequency as measured by the number of vibrations per second. Low pitched sounds appear to get lower as they get louder, high pitched sounds appear to get higher.
(from http://acousticslab.org/psychoacoustics/PMFiles/Module05.htm)
Thank you
Related to Units of loudness of sound, being a subjective quantity
What is the unit of loudness of sound?
The unit of loudness of sound is called decibel (dB). It is a logarithmic unit that measures the sound pressure level relative to a reference level.
How is loudness measured?
Loudness is measured using a sound level meter, which converts sound pressure into decibels. The measurement is typically taken at the listener's ear, but can also be measured at the source of the sound.
Is loudness a subjective quantity?
Yes, loudness is a subjective quantity because it is perceived differently by each individual. It depends on factors such as age, gender, and sensitivity to sound.
What is the reference level for loudness?
The reference level for loudness is 0 decibels, which is the threshold of human hearing. This means that any sound that is below 0 decibels is considered too quiet to be heard by the average human ear.
Can loudness be converted into a physical quantity?
No, loudness cannot be converted into a physical quantity because it is a subjective measure and does not have a direct relationship with physical properties of sound such as frequency or amplitude.
  • Other Physics Topics
