Undergrad Units of q in Electric Field Equation
In the electric field equation E = (1/4πe₀)(q/r²)r̂, the unit of charge q is Coulombs in the SI system, while in cgs units, it is the electrostatic unit (esu). The equation changes in cgs to E = (q/r²)r̂, eliminating the 1/4πe₀ factor. The charge of an electron is approximately -1.6 x 10⁻¹⁹ C, and today, the elementary charge e is defined to set the base unit of charge. The discussion highlights the differences in unit systems and their implications for calculations in electric fields. Understanding these distinctions is crucial for accurate scientific computations.
Drakkith
Mentor
TL;DR
What Are the Units of q in the EField Equation?
Quick and possibly stupid question, but in the equation for calculating the electric field:
##{\mathbf E} = \frac{1}{4πe_0}\frac{q}{r^2} \hat {\mathbf r}##
What unit is ##q## in? Coulombs?
Although now that I think more on it I suppose it also depends on the units you're using to calculate the electric force on a charged particle, correct?
In SI, the unit of charge ##q## is Coulombs. There are other units for other systems.
How does the above equation change if we move to, say, cgs units?
In cgs the unit of charge is the electrostatic unit, or esu. The constant in Coulombs law is set equal to 1. Therefore, two charges each with charge 1 esu sitting 1 cm apart will feel a force between them of 1 dyne.
Note that in SI base units, the electric charge is As (Ampere seconds) from which 1 C = 1 As is derived.
Thanks all. For some reason I was thinking ##q## was in units of single electron/proton charges and I was in a rabbit hole of debugging my program because I thought it was acting wonky. No, I just didn't need to enter 1e20 for the amount of charge...
For an electron ##q=-e \simeq -1.6 \cdot 10^{-19} \text{C}##. Note that today ##e## is fixed by definition, i.e., it's used to define the base unit of charge, C (or for historical reasons rather of current, A).
To complement this answer, this means that the equation for the electric field in Gaussian units (cgs) is
$${\mathbf E} = \frac{q}{r^2} \hat {\mathbf r}$$
The factor ##1/4πe_0## is an artefact of the SI system of units.
Likes hutchphd, Drakkith and vanhees71
I recommend a chapter in Wangsness book, titled "Systems of Units: A Guide to the Perplexed."
It should be titled "Where do the 4πs go")
Likes vanhees71, Bystander and malawi_glenn
Give me a Ψ and I'll show you.
Get it? Because it's shaped like a fork?
  • Haha
Likes vanhees71 and hutchphd
Heaviside-Lorentz units rule! There you've the factors of ##4 \pi## at the right places and no idiosyncratic different units for the field components ##\vec{E}## and ##\vec{B}## :-).
The problem with the 'other' units is that you have to memorize the number 1.
  • · Replies 25 ·
  • · Replies 130 ·
13K
  • · Replies 51 ·
9K
