Is the Big Bang Theory Just a Pseudo-Issue?
  • Thread starter Priyank
  • Tags
    Universe
In summary: January 2014)In the standard model of cosmology, the universe is expanding and the matter in it is cooling and becoming dark. However, at extremely high densities, gravity becomes dominated by quantum effects and repels instead of attracts. This repulsion causes the universe to bounce back in time, starting the expansion from the point where it stopped.
Priyank
32
The Big Bang Theory is right now the most acceptable theory for the creation of Universe...
But, as per the Law of Conservation of Matter, matter can neither be CREATED, nor be destroyed...
So, shall we conclude by saying that Universe existed earlier also and would tend to exist forever?
Space news on Phys.org
There are two issues that make the question ill-posed:
1. BB says nothing about the creation process. Its applicability stops short of the singularity that you end up with if you try and extrapolate the model too far back in time.
2. It's impossible to clearly define energy on the cosmological scales. If you can't even say what energy is, you can't say anything about its conservation or lack thereof.
Here's some further reading on these two points:
Re 1 - http://www.einstein-online.info/spotlights/big_bangs
Re 2 - http://www.preposterousuniverse.com/blog/2010/02/22/energy-is-not-conserved/ and http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
Priyank said:
... as per the Law of Conservation of Matter, matter can neither be CREATED, nor be destroyed...
In addition to what Bandersnatch said, be advised that this is a complete mis-statement of the law, which is actually called the Law of Conservation of Mass and says that MASS cannot be created or destroyed in a closed system. Matter gets destroyed all the time but the destruction results in no loss of mass since the radiation portion has energy which is equivlent to mass in this context.
The BB Theory doesn't give you any hint about the creation of the Universe... Even if you expand it up to inflation age, you have no information of what was there/what was happening before inflation. It could as well be some unknown state that had been existed forever, or maybe not ... The age of the Universe starts counting from the point where inflation stopped.
Priyank said:
...So, shall we conclude by saying that Universe existed earlier also and would tend to exist forever?
Sure.
Why shouldn't we take that as a working hypothesis and try to improve the cosmology model so it does not break down at the very start of expansion?
Why not take an improved model that does not fail and develop infinities, try to push back in time to a little bit BEFORE the start of expansion? Let's see what we find.
People are doing that. A good recent paper is the December one by Edward Wilson-Ewing and Yi-Fu Cai. It's comparatively simple and straightforward, but it is not popularization, it's professional research journal type. the title is "LambdaCDM Bounce Scenario"
You get a link to the "arXiv.org" PDF text to download or read online, if you google "LambdaCDM bounce"
LambdaCDM is the name of the standard cosmic model that essentially all cosmologists use. It fits the data amazingly well, but it breaks and gives meaningless results right at the start. So Cai and W-E use a slightly modified model where at extremely high energy density gravity is dominated by quantum effects and repels instead of attracts, so as you push back in time you get a bounce.. Or looked at the other way, there is a collapsing phase of the same universe with the same parameters, that rebounds and starts the expansion. CDM stands for "cold dark matter" and Lambda stands for the cosmological constant that appears in Einstein's GR equation (basic to cosmology)
You seem open to the idea. So you might enjoy the Cai&Wilson-Ewing paper. Just read the non-technical parts, if you like---the beginning introduction and the conclusions at the end.
If you google "LambdaCDM bounce" the first hit you get is
http://arxiv-web3.library.cornell.edu/abs/1412.2914v2
they just uploaded an expanded version two days ago, on 28 Jan. I wonder if it is the same as what you get when you click on the standard link for their december 2014 paper:
http://arxiv.org/abs/1412.2914
Mass isn't a conserved quantity, though. It's created and destroyed all the time in high-energy reactions and nuclear decays.
marcus said:
[to Priyank]...You seem open to the idea. So you might enjoy the Cai&Wilson-Ewing paper. Just read the non-technical parts, if you like---the beginning introduction and the conclusions at the end.
Yes! I checked and the usual link already gets the new expanded version of the paper. Here is the brief one paragraph summary, with a link to the full PDF text:
A ΛCDM bounce scenario
Yi-Fu Cai, Edward Wilson-Ewing
(Submitted on 9 Dec 2014 (v1), last revised 28 Jan 2015 (this version, v2))
We study a contracting universe composed of cold dark matter and radiation, and with a positive cosmological constant. As is well known from standard cosmological perturbation theory, under the assumption of initial quantum vacuum fluctuations the Fourier modes of the comoving curvature perturbation that exit the (sound) Hubble radius in such a contracting universe at a time of matter-domination will be nearly scale-invariant. Furthermore, the modes that exit the (sound) Hubble radius when the effective equation of state is slightly negative due to the cosmological constant will have a slight red tilt, in agreement with observations. We assume that loop quantum cosmology captures the correct high-curvature dynamics of the space-time, and this ensures that the big-bang singularity is resolved and is replaced by a bounce. We calculate the evolution of the perturbations through the bounce and find that they remain nearly scale-invariant. We also show that the amplitude of the scalar perturbations in this cosmology depends on a combination of the sound speed of cold dark matter, the Hubble rate in the contracting branch at the time of equality of the energy densities of cold dark matter and radiation, and the curvature scale that the loop quantum cosmology bounce occurs at. Importantly, as this scenario predicts a positive running of the scalar index, observations can potentially differentiate between it and inflationary models. Finally, for a small sound speed of cold dark matter, this scenario predicts a small tensor-to-scalar ratio.
Comments: 14 pages, 8 figures, v2: Discussion extended and references added
The total mass-energy in a closed system is conserved. When the mass is destroyed, the radiant energy counts into the sum, right?
No. Definitely not. A nuclear decay will typically lower the mass-energy of a system, while many high-energy collisions will add to the mass-energy. In these systems, the mass-energy is converted to/from kinetic energy.
It is possible to say that energy is conserved locally. What this means is that it's possible to use equations such that the change in energy in an infinitesimally-small region is equal to the energy flowing into that region. The caveat here is that this only works reliably for flat space-time, but since you can always use coordinates where the local space-time is flat, this is always possible to do locally. This is why we generally consider energy to be conserved in reactions on the Earth: the space-time curvature is small, and regardless we typically deal with reactions that are tiny in size. Furthermore, we can write down a gravitational potential energy which allows us to account for the energy changes induced by gravity (this isn't always possible).
But when you've got a curved space-time, much of the time it's impossible to say that energy is conserved across the entire system, regardless of whether it's closed or not. As Bandersnatch pointed out, global energy conservation just doesn't work, because there isn't a unique definition of total energy for a curved space-time.
OK, I had this wrong. Thanks for straightening me out.
I think you are using two different definitions of "mass-energy".
The total energy stored in particle masses is not conserved, but the total energy in a closed system is, and seen as "closed box" the mass you would assign to this system in its rest frame stays the same even with nuclear decays. This is not an exotic model - we do this all the time when we talk about the mass of protons which is mainly QCD binding energy.
Yes, this is what I was talking about.
Another way to address this issue is to recognize it as a pseudo-issue, a remnant of our time-evolved 3D experience. If you understand a solution to Einstein's eqns provides a stress-energy tensor/spacetime metric pair for the spacetime manifold, then you're thinking in 4D rather than time-evolved 3D. Here is a nice quote:
Robert Geroch, General Relativity from A to B, University of Chicago Press, Chicago, 1978.
“There is no dynamics within space-time itself: nothing ever moves therein; nothing happens; nothing changes.”
With this view, the existence of the BB is no more mysterious than any other location on the spacetime manifold, e.g., me writing this post.
Related to Is the Big Bang Theory Just a Pseudo-Issue?
1. How do we know that the universe already existed?
Scientists have studied various aspects of the universe, including its age, expansion, and the cosmic microwave background, which all provide evidence that the universe has existed for billions of years. Additionally, the laws of physics and the observed celestial bodies also support the idea of a pre-existing universe.
2. What was the state of the universe before it existed?
It is currently unknown what existed before the universe. Some theories suggest that there may have been a previous universe that collapsed and expanded again, while others propose the concept of a multiverse, where our universe is just one of many parallel universes.
3. How did the universe come into existence?
The most widely accepted theory is the Big Bang theory, which proposes that the universe began as a singularity, a point of infinite density and temperature, and has been expanding and cooling ever since. However, there are still many unanswered questions and ongoing research about the exact cause of the Big Bang.
4. Can we ever fully understand the universe?
The universe is a vast and complex entity, and while we continue to make new discoveries and advancements in our understanding, it is unlikely that we will ever have a complete understanding of the universe. However, through scientific research and advancements, we can continue to deepen our understanding and knowledge of the universe.
5. Is the concept of an already existing universe compatible with religion?
This is a topic of much debate and speculation, and ultimately, it is up to individual interpretation and belief. Many religions have their own explanations for the existence of the universe, and some may see the idea of a pre-existing universe as compatible with their beliefs, while others may not. Ultimately, it is a personal perspective and belief.
  • Cosmology
