MHB Unknown's question at Yahoo Answers regarding the perimeter of a rectangle
The problem involves finding the dimensions of a rectangle with consecutive odd integer lengths that yield a perimeter of at least 35 cm. By defining the lengths as 2n-1 and 2n+1, the perimeter formula simplifies to P = 8n. Setting the inequality 8n ≥ 35 leads to n being at least 5, resulting in dimensions of 9 cm and 11 cm for the rectangle. This configuration provides a perimeter of 40 cm, while the next smallest odd integers yield a perimeter of only 32 cm. Thus, the smallest rectangle meeting the criteria has dimensions of 9 cm and 11 cm.
MarkFL
MHB
Here is the question:
The dimensions of a rectangle are consecutive odd integers.
Find the smallest such rectangle with a perimeter of at least 35 cm.
Can you explain please.
It includes inequalities I think..
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: unknown's question at Yahoo! Answers regarding the perimeter of a rectangle
Hello unknown,
Let's let one pair of parallel sides, the smaller pair have length $2n-1$ and the other pair, the larger pair, have length $2n+1$, where $n$ is a natural number. We know they are both odd, because $2n$ must be even, and so adding/subtracting $1$ from an even number results in an odd number. We know they are consecutive odd numbers because their difference is $2$:
$$(2n+1)-(2n-1)=2n+1-2n+1=2$$
So, let's draw a diagram of our rectangle:
We see the perimeter $P$, which is the sum of the lengths of the four sides is:
$$P=(2n+1)+(2n-1)+(2n+1)+(2n-1)=8n$$
We are told that this perimeter must be at least 35 (measures in cm), so we may write:
$$8n\ge35$$
Dividing through by $8$, we find:
$$n\ge\frac{35}{8}=4+\frac{3}{8}$$
Since $n$ is a natural number (a positive integer), we may then conclude we must have:
$$n=5$$
And so the two larger sides have length:
$$2(5)+1=11$$
And the smaller sides have length:
$$2(5)-1=9$$
This gives us a perimeter of $40\text{ cm}$. If we take the next smallest pair of consecutive integers, namely $7$ and $9$, we find the perimeter would be $32\text{ cm}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
