Unlimited Energy From a Single Cable?
In summary, TYCO says that they manufacture enough cabling products to span the globe more than six times. They claim that this is impractical, but what do you think?
Gnophos
This is crazy, but bear with me. Let's say the next mission to the Moon brings a cable. One that's still attached to Earth. They anchor it on the lunar surface.
As the bodies move in relation to each other, the cable is tugged by the Moon's incredible mass through a station on Earth that uses the movement to turn gears and such and generate energy. With F = ma, and the m being so huge, that's some serious force without having any significant effect on the Moon.
Is this physically possible?
The distance to the Moon is an average of 384K km and varies from about 363K km to 405K km.
TYCO says: Manufactured 860 million feet (about 280K km) of cabling products - enough to span the globe more than six times. (http://www.tyco.com/livesite/Page/Tyco/Careers/University+Recruiting/Fast+Facts )
According to my math, TYCO's cables alone (for one year, I believe) make up 70% of the distance to the Moon at its farthest from Earth.
Is this totally impractical? What do you think?
calculate how much that cable would weight and how much fuel would be needed to bring that sucker to the moon in the first place. Maby the cable wouldn't be able to support its own weight either. Imagine all the tons of weight haning on it.
NASA did an experiment with a simple probe on a tether that was intended to generate electricity by traveling through the Earth's magnetic field while in orbit. They didn't even get all the cable unwound before it shorted out and burnt the cable/tether and they lost the probe.
Just a few satellites in low-earth orbit could generate enough power for us for the forseeable future, but the challenges are not small even at the short distance to orbit. See threads on space elevators and the "can this satisfy the power needs" threads and you'll see that even getting a few miles into the sky means some careful planning on the tethers.
From a practical standpoint, I can see this being a logistical nightmare, and probably our money would be better spent on refining the use of solar and wind energy, etc. I was just wondering for the halibut if it would work.
Are you forgetting that the moon is not in a geosychronus orbit around the earth? How do you propose to prevent the cable from wrapping around the earth?
Zz.
Regardless of the logistical problems of such a scheme, the idea itself is so incredibly expensive and dangerous as to not warrent more than a passing mention.
Sure, it IS possible, but a lot of things are "possible"
What about laying a cable on the surface of the moon itself, If the Earth's magnetic field is very strong at that range.
It isn't. Magnetic fields get weaker with distance. Quickly.
Also remember that there is no such thing as free energy. The space thether takes energy from the satellite's gravitational potential energy.
That's not quite true. At least, not in an open system.
There is a such thing as tapping into an energy that is otherwise being wasted. Solar energy, for example, is about as free as it is possible to get. So is electricity driven from the Earth's magnetic field.
I think its more to do with the definition of "free" in free energy.
Science would hold neither created/destroyed and there would always need to be a source, but popular view and usage of the term seems to do more with "no-cost" in completely monetary terms.
Of course, if there is a financial investment to construct something to tap into an otherwise under-utilized source of energy, its only logical to ask how much time does it take for the investment to pay for itself to provide this no-cost "free" energy. Otherwise, even the layperson definition is simply bad accounting. :smile:
I was more talking in thermodynamic terms of free. Not even solar energy is free for us to "keep" - when we're done with it we eject it into the atmosphere in the form of heat - which in turns radiates to space.
Also, remember that a permament magnet (such as the Earth) is not by any means a source of energy. Remember that magnetic braking only works by inducing an eddy current in a conducting plate, producing ohmic heating. This heat does not come from the magnet. It comes from the fact that whatever you are trying to slow down has kinetic energy. The fact that the object looses kinetic energy proves that this is where it comes from.
This is even comparable to dropping a ball to the ground - it does not fall because energy is taken from the gravitational field, but because of the ball's potential energy, which you put into it by lifting it. Otherwise you'd ask yourself how many times you can drop the ball before you have used up all the gravity.
FAQ: Unlimited Energy From a Single Cable?
How does the single cable generate unlimited energy?
The single cable uses advanced technology to harness and convert energy from renewable sources such as solar, wind, and geothermal into electricity. This electricity can then be stored and distributed through the cable, providing a continuous source of unlimited energy.
Is the technology safe for the environment?
Yes, the technology used in the single cable is environmentally friendly and does not produce any harmful emissions or waste. It utilizes renewable energy sources and does not require the burning of fossil fuels, making it a sustainable and safe energy option.
What is the capacity of the single cable?
The capacity of the single cable depends on various factors such as the length of the cable, the type of renewable energy sources used, and the technology used for energy conversion. However, it is designed to provide a significant amount of energy that can power entire communities.
Can the single cable be used in all locations?
The single cable can be used in most locations with access to renewable energy sources. It is a versatile technology that can be installed on land, in the ocean, and even in remote areas. However, feasibility studies and proper planning are necessary to determine the most suitable locations for installation.
What are the potential benefits of using the single cable?
The use of the single cable can have numerous benefits, including reducing carbon emissions, providing a reliable and continuous source of energy, and reducing dependence on fossil fuels. It can also improve energy access in remote areas and contribute to the development of a sustainable future for our planet.
