Unparticle Physics and Higgs Sector
In summary: I'm a little lost. Can you help me out with an idea, how to show this breaking of scale invariance exactly?
Tack
Hi!
That's my first thread and I apologize for my bad English, but there's a question in my mind that makes me crazy...
At the moment I'm working on Unparticle Physics especially on the coupling between the SM Higgs sector and the unparticle sector.
There is a paper by Fox, Rajaraman and Shirman called "Bounds on Unparticles from the Higgs Sector" (arXiv:0705.3092), where they say that once the Higgs acquires a vev, the Higgs Operator introduces a scale into the Conformal Theory and the theory will become non-conformal at a certain scale.
That kind of makes sense to me, but I can't figure out a strikt mathematically statement for that phenomenon.
Maybe someone can help me out with a Idea, how to show this breaking of scale invariance exactly.
I thank you!
Tack
Mmm, what are you looking for exactly?
You have a coupling HHO that relates the standard model to the unparticle sector via the Higgs, that we are interested in studying in the infrared. Once you turn on a vev, you introduce a mass scale into the theory and will deform the conformal diagram by exactly the contributions of this 'relevant' operator (in principle there could be many operators that also break conformal invariance, but here they are studying a simple toy model where O is unique).
So are you asking about the renormalization group aspects (eg why you flow away from the fixed point in this case) or why a scale is introduced when you turn on the vacuum expectation value? Or maybe you want to show something more explicitly, like noninvariance under scale transformations?
Either way the necessary (but probably not sufficient) material can be found in a textbook on conformal field theory, like Di Francesco. But as far as I can see, the answer is more or less manifest.
Ok, what I'm looking for is, why I introduce a mass scale when I turn on a vev.
Isn't that the same? I thought, when I introduce a mass scale, the coupling gets energy dependent and it flows away from the fixed point...
Hmmm... I think tomorrow I will look for a textbook...
Thanks a lot!
"Ok, what I'm looking for is, why I introduce a mass scale when I turn on a vev."
The Higgs mechanism gets turned on, and you will now have mass term(s) present. This mechanism spontaneously breaks the conformal symmetry and the rest follows.
"Isn't that the same? I thought, when I introduce a mass scale, the coupling gets energy dependent and it flows away from the fixed point..."
Correct!
Thank you!
Ok, I understand what happens, when I turn on the vev, but not exactly why. When I have a SM Lagrangian I know what happens. I introduce a Higgs potential, decompose it and see immediately the mass dependence. But now, I have this operator coupling HHO and I don't know how to show the mass dependence mathematically. My problem is to handle these Operators mathematically... :confused:
Demystifier said:
This paper
http://lanl.arxiv.org/abs/0707.0893
may (or may not) be relevant.
Thanks, but I've read all these Unparticle/Higgs papers and they all just say, "when the Higgsfield gets a vev, the conformal symmetry is broken"...
Related to Unparticle Physics and Higgs Sector
1. What is Unparticle Physics?
Unparticle physics is a theoretical concept in particle physics that proposes the existence of a new type of matter that does not fit into the traditional categories of particles such as electrons, protons, and neutrons. This type of matter is thought to be scale-invariant, meaning its properties do not change at different energy scales.
2. How is Unparticle Physics different from traditional particle physics?
Unparticles are unique in that they do not have a definitive mass, charge, or spin like traditional particles. Instead, they are described by a non-integer dimension, which is determined by the interaction between particles and unparticles. This theory was first proposed by physicist Howard Georgi in 2007.
3. What is the Higgs sector in particle physics?
The Higgs sector is a key concept in the Standard Model of particle physics. It refers to the field and particle known as the Higgs boson, which is responsible for giving mass to other particles. The Higgs sector also includes a number of other particles and interactions that are essential for understanding the fundamental forces of nature.
4. How are Unparticle Physics and the Higgs sector related?
Unparticle physics and the Higgs sector are both areas of interest in particle physics, but they are not directly related. The Higgs sector is a well-established part of the Standard Model, while unparticle physics is a more recent and still theoretical concept. However, some theories suggest that the Higgs boson and unparticles may interact, leading to potential new discoveries in particle physics.
5. What are the potential implications of studying Unparticle Physics and the Higgs sector?
Studying unparticle physics and the Higgs sector could provide a deeper understanding of the fundamental building blocks of matter and the forces that govern them. It could also lead to new discoveries and advancements in technology, such as more efficient energy production or improved medical treatments. However, further research and experimentation are needed to fully understand the potential implications of these areas of study.
  • Beyond the Standard Models
9K
13K
11K
