Unraveling Dirac's General Relativity Equation
In summary: The Lie derivative of a vector quantity is more familiar, but here pμ is a vector density and you get an additional term in that case involving bμ,μ.Yes, he did give an argument for his expression, but when reading it I was reminded of Nathaniel Bowditch's quote about Laplace: "I never came across one of Laplace's 'Thus it plainly appears' without feeling sure that I have hours of hard work before me to fill up the chasm and find out how it plainly appears." I felt the same way about Dirac's "the generalization is evidently".Dirac's equation for the mass 4-current is just a special case of the more general equation for the current in a volume of
dEdt
288
There's an equation from Dirac's book on General Relativity that I don't get at all. It isn't derived; instead it's treated as almost self-evident, when it isn't.
Dirac begins by defining ##p^\mu## to be the "mass 4-current" of a continuous distribution of matter (matter in this case really being matter, ie not including the E&M field). This is defined such that ##p^\mu=\rho_0 v^\mu##, where ##\rho_0## is the mass density of a particular element of matter in that element's rest frame, and ##v^\mu## is just the four-velocity of the matter at the same point. Basically, ##p^\mu## is just the mass flux, in the same way as ##J^\mu## is the charge flux.
Dirac is trying to derive the equations of motion for a distribution of matter using the action principle. He does this by first making "arbitrary variations in the position of an element of matter" and seeing how it affects ##p^\mu##. He then asserts that if each element of matter is displaced from ##x^\mu## to ##x^\mu +b^\mu##, where ##b^\mu## is small, then ##\delta p^\mu=(p^\nu b^\mu - p^\mu b^\nu),_{\nu}##.
As I stated at the beginning, he doesn't derive this equation. I was hoping that someone else could describe where this equation comes from. Thanks.
Well he does give an argument supporting this expression for δpμ but doesn't really derive it. However I believe the expression he winds up with is just the Lie derivative of pμ with respect to b.
(The Lie derivative of a vector quantity is more familiar, but here pμ is a vector density and you get an additional term in that case involving bμ.)
Could you explain why the Lie derivative of ##p^\mu## with respect to ##b^\mu## would give ##\delta p^\mu##? It isn't obvious to me, though granted I am still a novice to the mathematics of GR.
Dirac says, "Let us suppose each element of matter is displaced from zμ to zμ + bμ with bμ small. We must determine the change in pμ at a given point."
While according to Wikipedia, the Lie derivative is "the change of a tensor field along the flow of another vector field." Sounds like the same thing!
It can get a lot more formal from then on. Roughly, the idea is this. You do a point transformation, that is you actually pick up and move the points a small amount. (Dirac's "displacing the matter") You construct a new coordinate system x' in which each point now has the same coordinate values that it did in the original coordinate system x. We say the coordinate system has been dragged along. Likewise you drag along every scalar, vector and tensor quantity by saying when displaced it has the same components in x' that it originally had in x. Then these quantities have been dragged along also, and the Lie derivative is how much they have changed if you just look at them in x.
Using Dirac's notation bμ for the small displacement, the Lie derivative of a scalar s is bμμs. That is, the directional derivative of s along b. For each tensor index you get a correction term.
For a contravariant vector vμ the Lie derivative is bσσvμ - vσσbμ.
A covariant index has a similar correction term but with a plus sign.
For a density w there's a correction term: bμμw + w∂μbμ.
This is all explained in more detail in Wikipedia!
Likes 1 person
I understand your confusion and frustration with Dirac's approach to deriving the equations of motion for a distribution of matter in General Relativity. It is important to note that Dirac's approach is not the only way to derive these equations and there are other methods that may be more intuitive or easier to understand.
That being said, let's try to break down the equation ##\delta p^\mu=(p^\nu b^\mu - p^\mu b^\nu),_{\nu}## that you are having trouble with. This equation is essentially a statement of the conservation of mass, which is a fundamental principle in physics. It tells us that the change in the mass 4-current, ##\delta p^\mu##, is equal to the difference between the mass flux at a point, ##p^\nu##, and the mass flux at a nearby point, ##p^\mu##, multiplied by the displacement between these points, ##b^\mu##, and this is all summed over the four dimensions, denoted by the subscript ##\nu##.
To understand where this equation comes from, we need to look at Dirac's approach to deriving the equations of motion using the action principle. He starts by considering an element of matter at a point ##x^\mu## and then allows it to be displaced by a small amount, ##b^\mu##, in any direction. This displacement will affect the mass 4-current, ##p^\mu##, since the matter is now at a different position. To determine how this displacement affects ##p^\mu##, Dirac takes the derivative of ##p^\mu## with respect to the displacement ##b^\mu##, which gives us the equation ##\delta p^\mu=(p^\nu b^\mu - p^\mu b^\nu),_{\nu}##.
In simpler terms, this equation is essentially telling us that the change in the mass 4-current, ##\delta p^\mu##, is equal to the difference in the mass flux at two nearby points, multiplied by the displacement between these points. This is a fundamental principle in physics and is used in many different areas of science.
I hope this explanation helps to clarify where this equation comes from and how it relates to Dirac's approach to deriving the equations of motion in General Relativity. It is always important to question and seek understanding in scientific concepts, and I encourage you to continue exploring and learning about
Related to Unraveling Dirac's General Relativity Equation
1. What is Dirac's General Relativity Equation?
Dirac's General Relativity Equation, also known as the Dirac Equation, is a mathematical equation that describes the behavior of spin-1/2 particles in the presence of gravitational fields. It is an extension of Einstein's theory of general relativity and is used to describe the behavior of particles at high speeds, such as those found in quantum mechanics.
2. Why is it important to unravel Dirac's General Relativity Equation?
Unraveling Dirac's General Relativity Equation is important because it allows us to better understand the fundamental laws of the universe and the behavior of particles in extreme conditions. It also helps us to bridge the gap between Einstein's theory of general relativity and quantum mechanics, which are two of the most important theories in physics.
3. How is Dirac's General Relativity Equation different from Einstein's theory of general relativity?
Dirac's General Relativity Equation is an extension of Einstein's theory of general relativity, which only describes the behavior of objects with mass. Dirac's equation, on the other hand, also takes into account the behavior of spin-1/2 particles, which are fundamental particles that make up matter. This makes Dirac's equation more comprehensive and applicable in a wider range of situations.
4. What are the practical applications of understanding Dirac's General Relativity Equation?
Understanding Dirac's General Relativity Equation has many practical applications, such as in the fields of quantum mechanics, cosmology, and astrophysics. It can help us to better understand the behavior of particles in extreme conditions, such as black holes, and to make more accurate predictions about the behavior of the universe.
5. Is there ongoing research and developments related to Dirac's General Relativity Equation?
Yes, there is ongoing research and developments related to Dirac's General Relativity Equation. Scientists are constantly working to improve our understanding of this equation and its applications in different fields of physics. New developments and discoveries are being made all the time, which continue to shape our understanding of the universe.
