Unraveling the Mystery of Observation & Wave Function Collapse
In summary, the conversation discusses the role of observation in an experiment where particles are shot through two slits and then recorded on a screen. The detectors that were used to determine which slit the particles went through were found to affect the results, leading to the collapse of the wave function. However, there are other explanations for this phenomenon, including the concept of quantum decoherence and various interpretations of quantum mechanics. The delayed choice quantum eraser experiment is also mentioned, which provides evidence that the interference pattern does not depend on when the particles were detected, but rather on whether the slit information can be determined. The detectors themselves are not the cause of the change in pattern, as shown by the experiment.
Jbeats245
Hi, I've done a lot of personal research on the internet trying to understand what exactly is happening in this experiment but I keep seeing contrasting information about what the role of observation actually had on the experiment.
What I understand is that when they try to figure out which slit the particles actually went through before they appear on the screen, the wave function collapses because the detectors use light to read its position and that affects the particles somehow.
How do the detectors actually affect the position of the particle?
Certain explanations like in this video assert that when the detectors were turned on but the data wasn't collected then the wave function still didn't collapse. He thinks its the fact that someone is consciously interpreting the experiment that affects the results. I'm pretty sure that's false but I really don't know why.
Edit:
Or do the detectors even affect the outcome? according to this video the delayed choice quantum eraser experiment proves that it wasn't the detector that collapsed the wave function.
According to http://www.highexistence.com/the-fallacy-of-delayed-choice-and-the-quantum-eraser/,
"The big mind**** here is that an interference patterns appears even when the which-slit information is removed in the far future! It is as if the electron knows that IN THE FUTURE the information about which slit it went through will be erased, and decides to act differently in the present moment!"
Does science have explanations for these phenomena other than the natural assumption that it must be the act of conscious observers affecting the results of the experiment?
Actually, we don't know how measurement causes wavefunctions to collapse, if indeed they do collapse. At the moment, it's just a convenient description. It is probably does not require consciousness to happen (though I suppose I can't really justify that "probably"). There is something called "quantum decoherence" where a quantum system being entangled with its environment causes its wavefunction to evolve (unitarily) in a manner that looks kind of like wavefunction collapse—but it's not the same thing, and doesn't really address the fundamental issue of how a quantum state goes from a superposition of states to an eigenstate. It's called the measurement problem and at the moment all we have are number of proposed resolutions from a variety of different possible interpretations of quantum mechanics.
In response to your edit: the mysterious nature of wavefunction collapse notwithstanding, the article containing the quotation in your edit (which you didn't actually link to, FYI) can probably be safely dismissed as garbage. Quantum physics is a fully causal theory, and suggesting the quantum eraser experiment requires the future to affect the present is utter nonsense.
Hey thanks for the replies! I fixed my post if you want to take a look at the article.
Are you familiar with the delayed choice quantum eraser experiment? I haven't taken a good look at it yet because my brain is really fried tonight from trying to understand all of this. Does the experiment prove that the detectors were not the cause of the change in pattern?
It is evidence that the formation of the interference pattern does NOT depend on WHEN either particle was detected. It only depends on whether the slit a particle goes through can be determined or not. If it can, then no interference pattern will appear. If it cannot, then an interference pattern WILL appear.
I am familiar with the delayed choice experiment—but I don't really understand your question. I glanced at your article, and a word of advice: if you ever read anything about quantum physics that cites the movie "What the Bleep Do We Know?" you would advised to stop reading and not waste your time.
Yea but doesn't it also mean that the detectors themselves aren't what's causing the change in pattern? In the double slit experiment when they put detectors in front of the 2 slits to see which slit it went through it made a clump pattern and went through one slit. In this experiment, they didn't do anything to see beforehand which slit it went through. They shot entangled particles at different detectors which eventually showed a pattern that changed depending on if we could know which slit it went through. It was the actual act of measurement that changed the result, not the way we measured it, right?
Also, to be clear, the detector at D0 showed a pattern that wasn't discernible until you corresponded each photon to it's entangled partner at a different detector that had it's own pattern as shown in the photo, right?
I think you're right. Each particle goes through one of two identical detectors, one where the "which path" info is erased and one where it's not. The first path still creates an interference pattern even though it still went through a detector. This proves that the detector isn't doing something funky to the particle to collapse the wave function, no?
The light doesn't go "through" the detector, its path ends at the detector. By detector I mean the sensor that records the light.
Related to Unraveling the Mystery of Observation & Wave Function Collapse
1. What is observation in the context of quantum mechanics?
Observation in quantum mechanics refers to the act of measuring or detecting a quantum system, which causes the system to collapse into a single defined state. This is known as wave function collapse.
2. What is the role of the observer in wave function collapse?
The observer plays a crucial role in wave function collapse as their act of measurement or observation causes the quantum system to collapse into a single defined state. This is known as the observer effect.
3. How does wave function collapse affect the behavior of particles?
Wave function collapse can affect the behavior of particles by causing them to exhibit either wave-like or particle-like behavior, depending on whether they are being observed or not. This is known as the wave-particle duality of quantum systems.
4. Are there any theories or explanations for wave function collapse?
There are several theories and explanations for wave function collapse, including the Copenhagen interpretation, which states that the wave function represents the probability of a particle's position until it is observed, and the many-worlds interpretation, which suggests that the wave function collapse creates parallel universes for each possible outcome of the observation.
5. How is the mystery of observation and wave function collapse being studied and researched?
The mystery of observation and wave function collapse is being studied and researched through experiments and theoretical models in quantum mechanics. Scientists are also exploring new technologies and techniques, such as quantum computing, to further understand the nature of observation and wave function collapse.
