I Unravelling Structure of a Symmetric Matrix
thatboi
Hey guys,
I was wondering if anyone had any thoughts on the following symmetric matrix:
$$\begin{pmatrix}
0.6 & 0.2 & -0.2 & -0.6 & -1\\
0.2 & -0.2 & -0.2 & 0.2 & 1\\
-0.2 & -0.2 & 0.2 & 0.2 & -1\\
-0.6 & 0.2 & 0.2 & -0.6 & 1\\
-1 & 1 & -1 & 1 & -1
\end{pmatrix}
Notably, when one solves for the eigenvalues and eigenvectors of this matrix, one finds that for the largest magnitude eigenvalues, the eigenvectors demonstrate an oscillatory behavior (the elements within the eigenvector switch between positive and negative), whereas for the smallest magnitude eigenvalue, the eigenvectors have a "nicer" behavior. This most likely has to do with the alternative +/- 1 in the matrix but I can't quite figure it out.
thatboi said:
Hey guys,
$$\begin{pmatrix}
\end{pmatrix}
I think this hypothesis can be easily tested.
Right, so the last row contributes to the eigenvalue in the sense that it gives the last entry of the resultant column vector when the matrix is multiplied by the eigenvector. So if the eigenvector also has entries that alternates signs, then the dot product between the eigenvector and the last row will result in a "coherent" sum and thus produce a larger number than compared to a different eigenvector with a different configuration of signs. Is this the right way to think about it?
I meant to test it experimentally, by modifying the "suspected" elements and observing how the eigenvectors are affected.
Sure, I already did some modifications and it seemed to match what I said above (for example if I put a negative sign on only the second element of the last column and second element of the last row, then the eigenvector corresponding to the largest magnitude eigenvalue only has a negative sign on the second element as well). I was just wondering if there was any more intuition/structure in the matrix beyond what I said above.
If you described how you generated that matrix, sometimes there are underlying reasons why certain eigenvectors exist.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
