Unruh effect in full spacetime
  • I
  • Thread starter gerald V
  • Tags
    Spacetime
In summary, while the Unruh effect may seem to suggest that a real photon gas exists, that is not always the case.
gerald V
67
In the formula for the Unruh effect, temperature (of a photon gas mostly) is proportional to the acceleration of some classical observer. But how can that be? Temperature is a scalar, while acceleration is a vector.
The cause of the effect obviously preferres one spatial direction, and Rindler coordinates reflect that. I have looked into an article explaining the Unruh effect in some detail (https://arxiv.org/pdf/1304.2833.pdf). This article explicitely states to restrict itself to 1+1 – dimensional spacetime, and so do some other sources I found.
So, for the Unruh experiment taking place in our full spacetime, what is the distribution of the photons in 3-dimensional position space as well as in 3-dimensional momentum space?
In contrast, Hawking temperature appears as quite plausible to me. But I assume that for black holes which are not spherically symmetric, i.e. rotating ones, temperature varies over the latitude. Is that right?
Thank you in advance for any answers.
It's proportional to the magnitude of the acceleration.
The magnitude of a vector is a scalar.
Likes vanhees71 and Demystifier
Here is a simple analogy. Suppose that a body moves with constant velocity through a medium. Due to friction with the medium the body will be heated and, after a certain transient time, the body will have a constant temperature caused by velocity relative to the medium. Yet, velocity has a direction and temperature has not.
Thank you very much for these explanations. However, since I still have problems to comprehend the situation, please let me first try to check whether I understood correctly what the Unruh effect claims. Is it correct that it is claimed that for an observer in hyperbolic motion (having come from sufficiently far back in the past) in flat spacetime, apart from statistical fluctuations
- the situation is stationary
- the "warm gas" homogeneously fills all of 3-space
- at any point in 3-space, the momenta of the "molecules" making up the gas are isotropically distributed in 3-momentum space?
Yes.
No. The excitations exist only in the accelerated detector. (And I wouldn't call it a "gas".)
Yes, the momentum of excitations is distributed isotropically. (But I wouldn't call it "molecules".)
Careful there. While the mean number of particles registered by the detector is thermally distributed, that does not mean that a real photon gas at finite temperature exists. Other properties of Unruh radiation do not necessarily coincide with those of a real gas. For example, higher moments of the particle number distribution are not necessarily thermal.
Related to Unruh effect in full spacetime
What is the Unruh effect in full spacetime?
The Unruh effect in full spacetime is a phenomenon in quantum field theory that describes the creation of particles from vacuum fluctuations in an accelerating reference frame. It is named after physicist Bill Unruh who first proposed the concept in 1976.
How does the Unruh effect work?
The Unruh effect occurs when an observer is accelerating, causing the detection of particles that were not present in the vacuum state. This is due to the observer's acceleration, which creates a horizon that separates the observer from the rest of the universe. The horizon acts as a barrier, causing vacuum fluctuations to appear as particles to the accelerating observer.
What is the significance of the Unruh effect in full spacetime?
The Unruh effect is significant because it provides evidence for the connection between gravity and quantum mechanics. It suggests that the concept of spacetime is not static and that it can be influenced by an observer's acceleration. This has implications for our understanding of the universe and the nature of reality.
Can the Unruh effect be observed?
Currently, the Unruh effect has not been directly observed in a laboratory setting. However, there have been experiments that have indirectly demonstrated its effects. For example, the Hawking radiation observed by black holes is a manifestation of the Unruh effect.
What are the applications of the Unruh effect in full spacetime?
The Unruh effect has potential applications in various areas of physics, including quantum information, cosmology, and black hole thermodynamics. It also has implications for our understanding of the early universe and the behavior of particles in extreme environments. Additionally, it may have practical applications in developing new technologies such as quantum sensors and quantum computers.
  • Quantum Physics
  • Beyond the Standard Models
  • Quantum Physics
  • Quantum Physics
