- #36
hutchphd
- 6,667
- 5,747
Here's a nice very short compendium on magnetic brakes:
https://www.thompsonrd.com/OSEE-brakes.pdf
Is there a significant length of chain hanging off the backside of the capstan? I assume its piled in the bottom but hanging vertically between there and the capstan.anorlunda said:By the way, this video illustrates the chain runaway scenario on a micro scale. It doesn't help much in our discussion other than to illustrate how the distributed masses and momenta play roles. Note that inertia of the ascending portion of the chain is also significant.
Somebody hasn't been studying their history. The last stand of the USS Missouri in 2012 teaches us how to deploy an anchor in an emergency.russ_watters said:I don't understand what you are saying here: why would the anchor brake need to stop the ship? ...and why as soon as it touches bottom?
I guess the question is how large, and durable does it need to be to limit the decent velocity to a safe range. I imagine one of the sea anchors fixed to the anchor with a small buoy on top to keep it upright.anorlunda said:As Russ Waters said, a "sea anchor." I don't think you can make one rugged enough to survive. Runaway can start both before and after the anchor hits bottom.
Chain is stored as low as possible to keep the ship's center of gravity low. So if sea level is 0, chain is stored at 0 to -15 feet. The hawse pipe where chain leaves the ship is almost at the top deck, +50-70 feet, anchoring depth of water on the continental shelf is typically 100 feet, so yes, the ascending part is a significant fraction.erobz said:Is there a significant length of chain hanging off the backside of the capstan? I assume its piled in the bottom but hanging vertically between there and the capstan.
anorlunda said:This video is better. The capstan wheel is visible. The chain stops several times. The men on the brake are seen turning the wheel to loosen the brake for minutes. Finally, runaway begins. Here are significant events in the video.
There is so much dust in the air, that the men can not be seen trying to tighten the brake after runaway begins. However, I think they may need to turn that wheel the other direction for 3 to 4 minutes before the brake starts braking again. But the chain is lost in less than 1 minute.
I also found some data from the USS Nimitz. I'm going to try to estimate chain velocity from the videos, and then calculate braking power needed to prevent a runaway.
Agree. But it the accident is repeated so often, year after year, on different ships with different operators, that we must look at system design flaws.Dullard said:When the chain stops due (presumably) to the anchor reaching bottom, they continue to back off the brake. When motion resumes, they are backed-off so far that they don't have a prayer of catching up.
I agree. In fact, I suspect that a single 360 degree turn of that wheel controls the full range from full brake to no brake.Dullard said:The braking mechanism shouldn't be able to back off so far.
Agree again. In fact that's what I'm going to explore next. I'm thinking something like a torque converter. The key to success is the shape of the brake force versus speed curve.Dullard said:A hydraulic speed limiter might be simple enough to prevent the 'out-of-control' situation from ever happening.
The thing is mounted on the bow of ships and got permanent battering of water, salt and every harm seas can offer.Dullard said:I can imagine simple, reliable solutions
This. But I would change it slightly to say BIG hammer and BIG wrench.Rive said:The thing is mounted on the bow of ships and got permanent battering of water, salt and every harm seas can offer.
I think it's a requirement that maintenance could be done by excess amount of grease only and field repair is by hammer and wrench
Initial V | 25 | m/s |
Final V | 5 | m/s |
Delta V | 20 | m/s |
Period | 2 | s |
Avg Acceleration | 10 | m / s^2 |
len | 30 | m |
weight | 269 | kg/m |
total mass | 8070 | kg |
Initial K.E. | 2521875 | Joules |
Final K.E. | 100875 | Joules |
Power | 1210500 | joules/sec |
MW Power | 1.2105 | MW |
HP Power | 1622 | Hp |
That's true. Ocean sailors must deal with salt and corrosion all the time. We use bronze alloys or for many objects. For example, the windlass I used to raise anchor chain on my sailboat was 100% bronze, lubricated with special water resistant grease.Rive said:The thing is mounted on the bow of ships and got permanent battering of water, salt and every harm seas can offer.
I’ve got the illness that shall remain unnamed. It’s starting to wear on me. Last night my fever broke long enough I program that solution. So I’m a little more foggy than usual.anorlunda said:Here's my thinking. I would use a water brake as a velocity limiter, or as a runaway preventer.
https://en.wikipedia.org/wiki/Water_brake
And this video,
https://en.wikipedia.org/wiki/File:Tech-Talk_Animation_on_How_Water-Brakes_Work.webm
The torque is controlled by the flow of cooling water. I would use a flyball governor to monitor capstan wheel RPM, and use the governor to control flow of water to the brake. The goal is to provide a soft limit to capstan wheel RPM; and to do it mechanically with no aux power.
The harder question is the required rating. I'm not sure how to calculate that. So partially arbitrarily, I'll choose the case of decelerating 30 feet of chain from 25 to 5 m/s velocity within 2 seconds. Here are the calculations using @erobz 's numbers
Initial V 25m/s Final V 5m/s Delta V 20m/s Period 2s Avg Acceleration 10m / s^2 len 30m weight 269kg/m total mass 8070kg Initial K.E. 2521875Joules Final K.E. 100875Joules Power 1210500joules/sec MW Power 1.2105MW HP Power 1622Hp
I tried to find a 1.5 MW water brake on alibaba.com, but I find nothing similar. Perhaps I'm using the wrong search terms.
@erobz, @jrmichler , I'm not a M.E. Do my calculations appear correct?
I'm assuming that the runaway begins after the anchor touches bottom. Also assume that as soon as chain speed exceeds ship speed, the chain becomes nearly vertical, and the length of chain in motion remains constant.. But yes, I should include the K.E. of the ascending chain also; that would need about 50% more power.erobz said:I think you need to consider the mass of the anchor as well? Also the final mass of the chain will be the initial hanging mass + the anchor+ the additional 30 m of chain at 5 m/s. You also have to change the kinetic energy of the mass that is traveling vertically inside the ship.
So the anchor is on the bottom, but the chain hangs close to 30 m before it touches water correct?anorlunda said:I'm assuming that the runaway begins after the anchor touches bottom. Also assume that as soon as chain speed exceeds ship speed, the chain becomes nearly vertical, and the length of chain in motion remains constant.. But yes, I should include the K.E. of the ascending chain also; that would need about 50% more power.
Sorry to hear you're not well. Get well soon.
I considered that. These are incredible things - they can stop very, very, very heavy objects on a dime. However, I think in principle they suffer from the same problem as mechanical brakes - what do you do with the energy?hutchphd said:Here's a nice very short compendium on magnetic brakes:
A weakest chain link is supposed to be built into the chain near the end.jrmichler said:6) Design the system weak link. The existing weak link is the attachment of the chain to the ship. Remember that it's better to lose an anchor and chain than to pull the bow of the ship off.
Ship speed should be zero when dropping anchor.anorlunda said:I'm assuming that the runaway begins after the anchor touches bottom. Also assume that as soon as chain speed exceeds ship speed, the chain becomes nearly vertical, and the length of chain in motion remains constant.. But yes, I should include the K.E. of the ascending chain also; that would need about 50% more power.
Clearly I have no "feel" for this size force. That being said three things mitigate for magnetic brake in this circumstance:Vanadium 50 said:I considered that. These are incredible things - they can stop very, very, very heavy objects on a dime. However, I think in principle they suffer from the same problem as mechanical brakes - what do you do with the energy?
I like that. It's a rational way to rate the system based on a knowable worst case.jrmichler said:1) Assume a worst case hanging mass. The anchor is just above the bottom of the deepest water in which the ship will be anchored.
2) Assume a maximum allowable speed of drop at that point. This value may be iterated.
Music to an engineer's ears, fault tolerance and contingencies.jrmichler said:This system should allow both fast drops and controlled drops, and allows for operator error on the brake. This system will allow manual control of drops with a failed water brake. It will allow anchoring with a mechanical brake that failed in the open (unbraked) position by letting the chain run all the way out, then winching back to the desired length.
Yes. The last link is called "the bitter end". Often it is not attached to the ship at all. No attachment and a weak link are approximately the same thing.256bits said:A weakest chain link is supposed to be built into the chain near the end.
Yes, a water bath for cooling should be doable. I thought about both water brakes and magnetic brakes. Both may be viable.hutchphd said:Surely there is an effective way to exract heat when an unlimited cold bath is meters away...directly submerge the entire brake somehow?
No. That is discussed in #17.---256bits said:Ship speed should be zero when dropping anchor.
My stationary bicycle (only as a last resort) has magnetic drag. I think the adjustment is to move the magnet away. In any system I think it involves lowering the effective magnetic strength (and probably force it is quadratic in B). There are many simple ways to do this...I do not see it as a problem. The slope may be a little trickier but maybe it is as simple as radius of the disk? More thought required.anorlunda said:With magnetic brakes, how does one make the braking force adjustable, and the slope of force versus speed adjustable?
1. No, but salt water will interfere with the EM fields.hutchphd said:
- Water will not directly affect braking force by lubricating
- Heat is delivered throughout disk...not just the surface
A static B field? I will need to think about this, but I think it would just ad to the braking slightlyVanadium 50 said:1. No, but salt water will interfere with the EM fields.
I am not sure we are considering the same system. I am thinking about permanent magnets inducing eddy currents in a rotating disk. The braking is from the intrinsic conductivity (resistivity) of the disk (or drum)Vanadium 50 said:2. Heat is actually delivered by (and energy to) a dump resistor. The problem is what happens if the dump resistor overloads or otherwise fails.
If you use a flyball governor to move the magnets, then you have the adjustment of the slope and intercept of the force versus speed curve.hutchphd said:My stationary bicycle (only as a last resort) has magnetic drag. I think the adjustment is to move the magnet away. In any system I think it involves lowering the effective magnetic strength (and probably force it is quadratic in B). There are many simple ways to do this...I do not see it as a problem. The slope may be a little trickier but maybe it is as simple as radius of the disk? More thought required.
For the bicycle I think the fixed magnetic drag supplies a simulacrum of the air drag, although I simply think of it as a midievel rack so who cares. However I still enjoy the real two wheeled variety on early summer mornings...(not dead yet!)anorlunda said:If you use a flyball governor to move the magnets, then you have the adjustment of the slope and intercept of the force versus speed curve.
