Unstable molecules - is the instability relative to environment?
In summary, the stability of molecules is often relative to their environment. In areas of complete vacuum, molecules that are highly unstable on Earth could potentially be highly stable. However, even in environments with molecules present, there is a point where the least energy would be achieved if the molecule dissociated into individual atoms. This is seen in cases such as persistent radicals and phosphorescence. The definition of space as a vacuum depends on the volume being considered, with some areas containing many molecules and others containing only a few or even none.
Simfish
Unstable molecules - is the instability "relative" to environment?
There are many highly unstable chemical configurations. Most chemicals, after all, would prefer to move from high-energy states to low-energy states. This is usually possible due to the presence of a reaction pathway that makes this possible.
But what if there was no possible reaction pathway? On Earth, those reaction pathways are almost always possible. But in space, you might have no possible reaction pathway, so many molecules that are highly unstable on Earth - could conceivably be highly stable in space. In areas of almost complete vacuums, you could conceivably have molecules that are *extremely* ionic. Do those molecules even exist?
Of course, in every environment, there is a point where the least energy would be achieved if the molecule simply dissociated into individual atoms rather than maintain itself.
Chemistry news on Phys.org
You don't need to go into space, it works even on Earth. For example free radicals are usually very reactive, but in some cases steric hindrance makes them quite stable. They are called then "persistent radicals".
Same about phosphorescence. To emit energy molecule has to go one from energy state to another. Sometimes these transitions are "forbidden" - for example they require change in multiplicity - so the excited molecule is quite stable.
I have one question, When we mean complete vacuum, do we mean the absence of everything therein inside that space or just a few chosen things...(I am not referring to existence of Ether or not..)
Coz space is not vacuum... you have many galaxies in it.. So how is it vacuum?
And if there is a vacuum, then how can things be stably floating in vacuum, what about pressure inside a vacuum chamber.. If it is a vacuum, then it must have been filled...at some point in time..
And well if you take the chemical reaction into vacuum, u would not have vacuum but your experiment...
Dont we have X-Rays traveling though space.. (well forgot it is part of the big baggage called light, including radio waves and microwaves)
Well I am not trying to reply to your experiment.. but would only like to know how we define space as a vacuum.. and how we define space as being something apart from the many galaxies in it.
Another quick question... In the atom, is there any space left between the protons and neutrons, in the electron cloud region, well if there is space and nothing is there.. or there are tight spaces where nothing fills, is that vacuum too. Just a thought!??!??
Merry Christmas or well wishing everyone a wonderful year ending...
It is all about the volume you are interested in. Take a cubic meter of space - in some places it will contain many moles of substances, in some places it will contain single molecules. The less, the better vacuum.
http://en.wikipedia.org/wiki/Outer_space#Intergalactic
However, whether or not a molecule is considered "unstable" is relative to its environment. In a high-pressure, high-temperature environment, a molecule may be considered stable due to the presence of many reaction pathways. But in a low-pressure, low-temperature environment, that same molecule may be highly unstable and prone to dissociation. Therefore, the instability of a molecule is relative to its environment and can vary depending on the conditions present. This is an important consideration for scientists when studying and predicting chemical reactions in different environments.
Related to Unstable molecules - is the instability relative to environment?
1. What are unstable molecules?
Unstable molecules are molecules that are not in a stable form and can easily break apart or react with other molecules.
2. How do unstable molecules affect the environment?
The instability of molecules can lead to chemical reactions that can have both positive and negative effects on the environment. For example, some unstable molecules can contribute to air pollution while others are essential for sustaining life.
3. Is the instability of molecules relative to the environment?
Yes, the instability of molecules can be relative to the environment they are in. Factors such as temperature, pressure, and the presence of other molecules can affect the stability of a molecule.
4. Can unstable molecules be stabilized?
In some cases, unstable molecules can be stabilized through various methods such as changing the environment, adding stabilizing agents, or altering the molecular structure.
5. Are all unstable molecules harmful?
No, not all unstable molecules are harmful. Some unstable molecules are essential for biological processes and others can be used in beneficial reactions, such as in medicine or industry.
