Unsteady flow of water being discharged from a tank
In summary, the water rocket can attain an altitude by modeling the thrust phase. The water mass decreases with time, and neglecting losses in the system results in an approximation for the instantaneous exit velocity. The approximation can be used to simulate the process step by step in time.
John Most
I am currently modeling the altitude that a water rocket can attain. In order to do this i am first modeling the the thrust phase.
Due to the water mass decreasing with time (the same goes for the pressure - it decreases over time as the water is expelled out of the nozzle).
This is an unsteady drainage problem in which the bottle is filled with water and pressurized to around 6 Bar. I cannot use Bernoulli's equation as this only describes a steady flow process. The same applies for Torricelli's v = sqrt(2gh).
Does anyone know how i go about modeling this unsteady flow problem?
You'll need some approximations. Neglecting losses in the system and using energy conservation to find the instantaneous exit velocity should give a reasonable approximation. Then simulate it step by step in time.
Likes John Most
Can you tell us more about the dimensions of the bottle and the fractional fill of water and gas?
Likes John Most
The bottle is a standard 2L coke bottle (as restricted to in my mini-thesis project). The diameter is constantly changing, but for the sake of easy explaining i can use MatLab later to iterate each step at a different height. I am not sure of the ratio of water to air yet, as i was first wanting to create the model and then use an optimization approach to determine what the best ratio would be in terms of thrust.
I saw an answer you left 2 years ago (URL below) where you replied to someone about an unsteady tank draining problem. I think the only difference there is obviously the area changing and the pressurized air.
https://physics.stackexchange.com/q...rnoulli-and-continuity-equation/423973#423973
Any help will be greatly appreciated and reduce a lot of stress.
I commented instead of replying, so just making sure you get notified.
Since you have gauge pressures on the order of bars, you don't have to account for hydrostatic pressure variations. So Bernoulli gives you $$v=\sqrt{\frac{2p}{\rho}}$$where p is the gauge pressure. Bernoulli can be used directly because the transient variation in velocity at a given location in the bottle is going to be negligible compared to the acceleration of the fluid in approaching the bottle opening (which is much smaller in cross section than the main bottle diameter). So the flow approaching the opening can be considered quasi static. Anyway, this is the approximation I would use, at least to get started.
I agree completely that the variation in velocity at a point in the bottle is considered negligible compared to the acceleration of the fluid approaching the nozzle. This is in fact what I did in my previous model. However, when I took this to my Professor, he did not appreciate any "assumptions and short cuts". This is most likely a case of 'killing an ant with a bazooka' - yet i have no choice but to model it considering a fully transient flow.
Currently I am working with what you wrote out with the link above (the unsteady tank drainage problem) and trying to add to equation 8 the rate at which work from pressure is being done on the water. Would this be correct in the difference between that problem and mine? Then I will just run the process at certain y-intervals with the change in area.
Sorry for the inconvenience of not being able to use a quasi-static approach. The accuracy of transient flow for this approach does not seem worth the complexity of modeling it as transient, but sadly it must be done.
If your professor doesn't want you to use any approximations and shortcuts, then you better follow the motion of each and every molecule, and include the gravitational pull of Jupiter (to say nothing of viscous effects).
If you want to include the transcience in your problem, for a cylinder like a 2L bottle, you can write $$A\frac{dp}{dz}=\rho A \frac{dv}{dt}$$ for the differential force balance on the portion of liquid up to the convergence (where v is the lower axial velocity in the larger area region). So, $$p_{hi}-p_{conv}=\rho h\frac{dv}{dt}=\rho h\frac{d^2h}{dt^2}$$where h is the distance from the gas surface to the convergence. From the convergence on, $$p_{conv}=\frac{1}{2}\rho (V^2-v^2)$$where V is the velocity out the exit hole: ##V=vA/A_x=\frac{A}{A_x}\frac{dh}{dt}##.
This neglects the transient in the converging section.
If your professor wants it more accurate than this, I suggest using computational fluid dynamics.
Likes John Most
Thank you so much for your help, it is seriously appreciated.
I only have one more question and then I should be sorted. I am currently setting up a transient energy balance on the entire inner bottle control volume. So far i have:
The rate at which gravitational work is being done on the water + the rate at which the work from pressure is being done on the water = the rate of change of kinetic energy of water + the rate of kinetic energy leaving the bottle.
Firstly, is the above statement accurate? If so, for the change in pressure you wrote above (considering the water until it reaches convergence), how would i write it in terms of energy?
Sadly, I am not allowed to model it in CFD. It would have been really interesting to compare to my theoretical model.
Again, thank you for your help. You will undoubtedly be acknowledged in my Thesis.
I think your energy balance looks OK. I think it should lead to basically the same equation I presented. In my judgment, there is no need to consider gravitational work because of the high pressures involved, which would be sufficient to support a column of water 60 m high.
Likes John Most
Related to Unsteady flow of water being discharged from a tank
1. What is unsteady flow of water from a tank?
Unsteady flow of water from a tank refers to the movement of water that is not consistent or continuous. This means that the rate of water discharge from the tank varies over time.
2. What causes unsteady flow of water from a tank?
There are several factors that can cause unsteady flow of water from a tank, including changes in the water level, changes in the cross-sectional area of the outlet, and changes in the velocity of the water.
3. How is unsteady flow of water from a tank measured?
Unsteady flow of water from a tank can be measured using various techniques such as flow meters, pressure sensors, and ultrasonic sensors. These devices help to record the changes in flow rate over time.
4. What are the implications of unsteady flow of water from a tank?
Unsteady flow of water from a tank can have significant implications for the design and operation of water systems. It can affect the efficiency of water distribution and can also cause damage to pipelines and other infrastructure.
5. How can unsteady flow of water from a tank be controlled?
Unsteady flow of water from a tank can be controlled by implementing flow control measures such as using flow regulators, adjusting the outlet size and shape, and increasing the storage capacity of the tank. Computer models can also be used to predict and manage unsteady flows.
  • Mechanical Engineering
