Python Updating a figure made using Plotly
  • Thread starter Thread starter Swamp Thing
    Figure
To update a Plotly graph in Python, specifically in Google Colab, the common method of using `f1.update_traces(y=[4,3,2,1])` does not reflect changes unless `f1.show()` is called, which generates a new plot instead of updating the existing one. Modifying the data directly with `f1.data[0].y = [4, 3, 2, 1]` appears to work, as confirmed by the output showing the updated 'y' values. However, the plot itself does not visually update to reflect these changes. It is noted that Google Colab may not support live updates of plots in the same manner as traditional Jupyter notebooks, leading to challenges in dynamically updating visualizations.
Swamp Thing
Insights Author
TL;DR Summary
I'm trying to update a plotly graph with new data:
Nothing happens.
After making a graph using Plotly in Python, I'd like to change the data. From the documentation (which is not very clear) it appears this is the code we need:
f1.update_traces( y=[4,3,2,1] )
(where f1 is the figure created previously).
But nothing happens when I run this.
In order to see the new data, I find that I need to do f1.show() after the above step. The problem with this is that it shows a new plot rather than changing the old one, so each time I change the data it goes into a new plot.
So I guess my big-picture question is, using Python in Google Colab, how can I change attributes (including data) of an existing plot in situ?
Technology news on Phys.org
You should be able to just modify the data in place:
Python:
Python:
I've tried that too.
Python:
f1.data[0].y=[7,6,5,9]
print(f1.data[0])
The output from the print statement shows that the 'y' array has been written into correctly:
Code:
Scatter({
    'uid': '289cc751-4c63-4126-8235-82c69798e9d6', 'x': [2, 3, 4, 5], 'y': [7, 6, 5, 9]
... but the plot doesn't reflect the change.
Are you using Python in a notebook? I'm using Google Colab, which perhaps doesn't support live updating of plots...
No it doesn't, at least not in the same way as a 'normal' Jupyter notebook does.
Likes Swamp Thing
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
10K
