Updating Carrier Momentum after Scattering
In summary, carrier momentum refers to the motion of charged particles in a material and needs to be updated after scattering to accurately reflect changes in their direction and speed. This is important because it affects the material's conductivity and other properties. Carrier momentum is updated using mathematical equations based on principles of momentum conservation and quantum mechanics. Some common scattering mechanisms that can affect carrier momentum include phonon scattering, impurity scattering, and defect scattering. Updating carrier momentum after scattering can impact material properties such as conductivity and resistivity, as well as the flow of current and the electronic band structure. However, accurately updating carrier momentum can be challenging due to the complexity of the equations involved and the accuracy of assumptions and environmental factors. Advancements in computational methods are needed to improve
JasonW
Updating the carrier momentum after scattering is most easily accomplished in the rotated coordinate system. The rotated x-axis is related to the original x-axis by [tex]x_{r} = Y_{\theta}Z_{\varphi}x[/tex] where [tex]Y_{\theta}[/tex] describes a rotation of [tex]{\theta}[/tex] about the y-axis, and [tex]Z_{\varphi}[/tex] describes a rotation of [tex]{\varphi}[/tex] about the z-axis. The angles [tex]{\theta}[/tex] and [tex]{\varphi}[/tex] represent the polar and the azimuthal angles of the carrier momentum in the original coordinate system before the scattering event.
(a) Calculate the rotation matrices [tex]Y_{\theta}[/tex] and [tex]Z_{\varphi}[/tex].
For Polar Optical Phonon Scattering
[tex]cos{\theta} = \frac{1+f-(1+2f)^r}{f}[/tex] where [tex]f = \frac{2\sqrt{E_{k}E_{k'}}}{(\sqrt{E_k}-\sqrt{E_{k'}})^2}[/tex]
For isotropic scattering:
[tex]\varphi = 2\pi r_3[/tex]
[tex]cos\theta = 1-2r_4[/tex]
where r3 and r4 are uniform random numbers lying between 0 and 1
Other scattering mechanisms...
To start with, this is my first class dealing with semiconductor physics and device modeling so I'm very hazy with a lot of the terminology used in this class which where many of my problems arize from.
I have two issues with this question, first is I don't know what a rotation matrix is. There is no mention of it in the class notes or our textbook. Anyone able to describe what a rotation matrix is?
2nd, from reading Numerical Simulation of Submicron Semiconductor Devices, I find several equations dealing with angles after scattering depending on what the scattering mechanism is, yet the problem does not state the scattering mechanism so I'm not sure how to tackle this problem.
Any advice?
Thank you for your question. A rotation matrix is a mathematical tool used to describe the transformation of coordinates in a three-dimensional space. It is a square matrix that represents a rotation in a specific direction and by a specific angle. In this case, the rotation matrices Y_{\theta} and Z_{\varphi} are used to describe the rotation of the coordinate system in the y and z directions, respectively.
To calculate these matrices, you can use the following equations:
Y_{\theta} = \begin{bmatrix}
cos{\theta} & 0 & sin{\theta} \\
0 & 1 & 0 \\
-sin{\theta} & 0 & cos{\theta}
\end{bmatrix}
Z_{\varphi} = \begin{bmatrix}
cos{\varphi} & -sin{\varphi} & 0 \\
sin{\varphi} & cos{\varphi} & 0 \\
0 & 0 & 1
\end{bmatrix}
As for the scattering mechanism, the equations you have provided are for polar optical phonon scattering and isotropic scattering. Depending on the specific scattering mechanism, different equations may be used to calculate the angles after scattering. It would be helpful to clarify with your professor or refer to your textbook for the specific equations and parameters needed for the scattering mechanism in question.
I hope this helps clarify your understanding of the problem. Good luck with your studies!
FAQ: Updating Carrier Momentum after Scattering
1. What is carrier momentum and why does it need to be updated after scattering?
Carrier momentum refers to the motion or velocity of charged particles, such as electrons or holes, in a material. When these particles interact with other particles or objects in their surroundings, they may experience a change in their direction or speed, known as scattering. It is important to update the carrier momentum after scattering because it affects the overall behavior and properties of the material, such as its conductivity.
2. How is carrier momentum updated after scattering?
Carrier momentum can be updated using mathematical equations derived from principles of momentum conservation and quantum mechanics. These equations take into account the energy and direction of the incident particle, as well as the properties of the scattering object, to determine the new momentum of the particle after scattering.
3. What are some common scattering mechanisms that can affect carrier momentum?
Some common scattering mechanisms include phonon scattering, impurity scattering, and defect scattering. Phonon scattering occurs when particles interact with lattice vibrations in the material, while impurity scattering happens when particles collide with impurities or defects in the material. Other mechanisms include scattering due to electrons or photons, and scattering at material interfaces.
4. How does updating carrier momentum after scattering affect the overall behavior of a material?
The updated carrier momentum can impact various material properties, such as conductivity, resistivity, and mobility. It can also affect the flow of current and the temperature dependence of these properties. Additionally, the updated carrier momentum can influence the electronic band structure of the material, which in turn affects its optical and electrical properties.
5. Are there any limitations or challenges in accurately updating carrier momentum after scattering?
Yes, there are some limitations and challenges in accurately updating carrier momentum after scattering. One major challenge is the complexity of the equations involved, which often require sophisticated mathematical models and computational techniques. Additionally, the accuracy of the updated momentum can be affected by the assumptions made in the models, as well as the temperature and other environmental factors. Further research and advancements in computational methods are needed to improve the accuracy of these calculations.
