Volantis92
- 3
Hey guys,
some insight to the following problem I have here would be helpful.
I need to see if a conveyor is worth upgraded (i.e. see what the output Tonne/per hour is) from a belt 745mm wide, idler pulley 800mm wide... to a 800mm belt and 850mm wide idler pulley.
Lets assume the length of the conveyor is 17m
I have a conveyor with 3 idlers on an angle of 45 deg, and assuming an angle of repose of 25 deg.
currently there is a 18KW motor on there, and let's assume the idler pulley barrel is 300mm. I want to upgrade to a 30KW motor.
How do I go about working out the max possible T p/hr?
i assume i need the speed of the motor, get velocity. Find the volume of the material over the conveyor length?
Any help is appreciated.
Cheers
Cheers
