Upper bound for first excited state - variational principle
lua
Find the upper bound of the first excited energy eigenstate in the quartic potential using variational principle.
Time-independent Schrodinger equation:
-\frac{\hbar}{2m}\frac{\partial^2 \psi}{\partial x^2}+\alpha x^{4} \psi=E \psi
Dimensionless time-independent Schrodinger equation
-\frac{1}{2}\frac{\partial^2 \psi}{\partial u^2}+(u^{4} - e) \psi=0
Variational principle:
E_{1}\leqslant \int_{-\infty }^{\infty }\psi^{*}(x)H\psi(x)dx
I'm solving problem number 5 from https://ocw.mit.edu/courses/8-05-quantum-physics-ii-fall-2013/resources/mit8_05f13_ps2/.
(a) Here I got:
\beta = \frac{\hbar^{\frac{1}{3}}}{(\alpha m)^\frac{1}{6}}
and:
E = \left ( \frac{\alpha \hbar^4}{m^2} \right )^\frac{1}{3}e
(b) Using Scilab I found that for the ground state energy:
e_{0}=0.667986
(c) A candidate wavefunction for the variational principle is:
\psi _{1}=Axe^{-\frac{ax^2}{2}}
(It is chosen to be orthogonal to ##\psi _{0}##.)
Here I got that upper bound for the first excited state is:
h_{1}=\frac{3}{4}\left ( 10^{\frac{1}{3}} + \frac{5}{100^{\frac{1}{3}}} \right )=2.423
(d) But here, by using shooting method, I got that:
e_{1}=4.696
or, the upper bound is less than the actual energy of the first excited state.
I'm not sure what went wrong.
I have to mention that I checked this for the ground state energy. By using the trial wave function:
\psi _{0}=Be^{-\frac{ax^2}{2}}
I got the upper bound for the ground state energy:
h_{0}=\frac{1}{4}\left ( 6^{\frac{1}{3}} + \frac{3}{36^{\frac{1}{3}}} \right )=0.68142
and exact ground state energy obtained by using the shooting method is:
e_{1}=0.667986
which is OK: exact value of the ground state energy is little bellow the upper bound.
The Scilab source follows:
//Solve a second order differential equation
//Y’’= 2(x^4-e)y, y(0)=1 and y’(0)=0
//e0=0.6679863 - dimensionless gruound state energy
funcprot(0)
function dy=f(x, y)
dy(1)=y(2);
dy(2)=2*(x^4-0.6679863)*y(1);
endfunction
x0=0;
xmax=10;
x=x0:0.1:xmax;
y0=1;
dy0=0;
y=ode([y0;dy0],x0,x,f);
clf;
plot(x,y(1,:),"r")
plot(x,y(2,:),"g")
xtitle("$\frac{d^2 y}{dx^2} =2*(x^4-0.6679863)*y $","x","f(x,y)");
legend("x","dy/dx")
What is ##\psi(0)## for the first excited state?
Does ##\psi'(0) = 0## for the first excited state?
Oh!
I did't think of that at all. Thank you!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
