MHB Upper Bounds and Tight Upper Bounds
  • Thread starter Thread starter Sudharaka
    Bounds
A tight upper bound, often represented as Θ, refers to a function that asymptotically matches the growth rate of another function, such as f(n) = n^3 + 2n^2, which has a tight upper bound of Θ(n^3). This is distinct from the supremum or least upper bound, as the function can increase indefinitely. In contrast, O(n^4) serves as an asymptotic upper bound, while Ω(n) represents an asymptotic lower bound. A tight bound effectively captures both upper and lower asymptotic behaviors. Understanding these distinctions clarifies the concept of tight upper bounds in mathematical analysis.
Sudharaka
MHB
Hi everyone, :)
What is a Tight Upper Bound? Is it the least upper bound? But then tight upper bound will be equivalent to the supremum. :confused:
Mathematics news on Phys.org
Sudharaka said:
Hi everyone, :)
Hi! :)
I think you are talking about the $\Theta$ bound.
It's a different type of bound.
Suppose we have the function $f(n) = n^3 + 2n^2$.
Its tight upper bound is $\Theta(n^3)$.
This is not a supremum (or least upper bound), since the function doesn't have one - it goes up to infinity.
The point it that it goes up asymptotically with $n^3$.
For instance $O(n^4)$ is an asymptotic upper bound, while $\Omega(n)$ is an asymptotic lower bound.
A tight bound is one that is both.
I like Serena said:
Hi! :)
Thanks much. That makes perfect sense now. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
