A Upper indices and lower indices in Einstein notation
The discussion centers on the confusion surrounding the use of upper and lower indices in the context of the cross product and Einstein notation. It explains that the different index positions for vectors a and b in the cross product arise from the relationship between vector spaces and their duals. In Euclidean space, vectors and dual vectors can be directly associated, but this changes in curved spacetime, necessitating a distinction between coordinate and dual bases. The notation reflects the transformation laws for components and basis vectors, with upper indices representing contravariant components and lower indices representing covariant components. A deeper understanding of these concepts is essential for clarity in applying Einstein notation.
GGGGc
I have read some text about defining the cross product. It can be defined by both a x b = epsilon_(ijk) a^j b^k e-hat^i and a x b = epsilon^(ijk) a_i b_j e-hat^k
why the a and b have opposite indice positions with the epsilon? How to understand that physically?
This is the text i read
PeroK said:
I've already checked that, but I'm still confused about when to use upper or lower indices, do you have some examples? Thanks for answering my question!
You really need a textbook or lecture notes, as there is a lot to say on this. The basic idea comes from the notaion of a dual vector space. In Euclidean space, the dual space can be associated directly with the original space, so there is no need for a distinction. And, generally a vector is written as a sum of its components in any coordinate basis:
$$\mathbf a = \sum_{i = 1}^n a_i\mathbf e_i$$Where ##\mathbf e_i## are the basis vectors. When we come to curved spacetime, the dual space can no longer be directly associated with the original space. Therefore, we have a coordinate basis and a dual basis and a vector is expressed in terms of the basis and a dual vector in terms of the dual basis. (Note that this concept extends to tensors of any rank.) The Einstien notation not only dropped the summation symbol, but used upper indices to represent components of a vector and lower indices to represent the basis vectors. This is because the components obey the contravariant transformation law and the basis vectors obey the covariant transformation law (you better check I've got that the right way round!). So, we write:
$$\mathbf a = a^{\alpha}\mathbf e_{\alpha}$$Conversely, the components of a dual vector (also known as a one-form) obey the covariant transformation law and the basis dual vectors obey the contravariant law. So, for a dual vector, we write:$$\mathbf w = w_{\alpha}\mathbf \theta^{\alpha}$$Where ##\mathbf \theta^{\alpha}## are the basis dual vectors.
That should get you started, but whatever you are studying should go into the Einstein notation in sufficient depth.
Likes GGGGc and berkeman
Thank you so much for your explanation! I'm quite clear now!
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
