UPS, Marine Battery, as Sump Pump backup
In summary, a UPS will back up the electric sump pump. You would need six deep cycle marine batteries to provide backup power for 48 hours assuming the pump runs once every 30 minutes for 30 seconds during that time.
UPSrecycler
Hey there! I'm an IT guy and found this forum through searching on replacing UPS batteries with deep cycle 12v marine batteries. The reason I was looking is I happen to have 4 spare Compaq rack mount UPSs with dead batteries taking up space in my basement. I was thinking of putting in a backup sump pump in case of a power outage, and then thought "wait a minute, a UPS will back up the existing electric sump pump".
While I know regular UPS batteries are really just meant for systems to have a few minutes for a graceful shutdown, I want to set this up so it will be able to run a sump pump on and off for several hours after a power outage.
The average time to drain the sump is about 30 seconds. It's a 6.5amp 115v pump. The batteries that the UPS is supposed to use are these. http://www.apc.com/shop/us/en/products/APC-Replacement-Battery-Cartridge-23/P-RBC23
How many 12v Deep Cycle marine batteries would I have to use to guarantee 48 hours of service assuming the pump runs once every 30 minutes for 30 seconds during that time?
From what I just read, if anyone can figure this out you folks can. I don't just want the answer, so if you can provide the math you use to get it I'd LOVE that for future projects. Thanks in advance!
:welcome:
6.5 amps * 115 V = 747 Watts
Lets say 800 watts from the DC side. 800/12V = 66 amps. That's comparable to the starter current to start an engine.
In 30 seconds that draws 0.55 amp-hours. Round it to 0.6 amp-hours per cycle of the pump. 2 cycles per hour, 96 cycles in 48 hours, so 96*0.6 = 58 amp-hours is your total requirement.
A group 31 marine battery, is nominally rated at 220 amp-hours, but it should not be discharged more than 25% for maximum lifetime.
So say, 55 amp hours useful capacity.
These numbers are rough, so 58 versus 55 sounds like a nearly exact match.
I pay $110 for a group 31 marine battery flooded battery. But those need ventilation. A gel cell or AGM battery is sealed and needs no ventilation but they cost more (just saw an AGM one for $139 online. That's a good price).
The marine battery may be bigger and heavier than your old battery.
Group 31 size:
Length: 12 15/16 in.
Width: 6 3/4 in.
Height: 9 3/8 in.
Weight: 69 pounds
Your sump could probably run for 96 hours on this battery, but doing so would drastically reduce the lifetime of the battery.
One thing to check, is the efficiency of your DC to AC inverter. Those calculations assume 93% efficient. If the inverter is significantly less efficient than that, you need still more batteryGood luck
Likes jim hardy
Watch out for starting current (locked rotor current) of the pump motor, it could be five to ten times the running current. UPS's usually have protection built-in that causes them to shut down and require a manual restart after an overload. A sanity test would be to connect the UPS to your car battery using good quality, heavy duty, jumper cables and see if the pump will start under load.
If the UPS can't handle the pump, there are inverters available (at least in the US) for automotive and Recreational Vehicle (RV) usage up to a few thousand watts. Cost is in the $100 - $200USD range for a 1KW unit. These often have a delayed overload shutdown specifically to allow motor starting.
Just an associated story about prevention versus recovery. The building I'm in recently had a flooding problem. In February we had a record-breaking rain storm. The building fortunately had a battery backup system to keep the lights, heating, phones, Internet access, etc running. When the first floor flooded, the power was shut off there and the 10 apartments evacuated. The rest of the building went to battery backup. NOT connected to the backup were the elevator, door locks, gate to the parking lot...or the sump pumps. Some apartments had four feet of water. After 3 weeks of repairing the damage, some people returned to their apartments. Then a second storm hit. Same results. The apartment manager mentioned that the second flood "got the attention" of the owner. Sump pumps were added, drainage plumbing was modified, etc. Glad I'm on the second floor!
Likes jim hardy
Here's something else to consider:
from http://batteryuniversity.com/learn/article/absorbent_glass_mat_agm
As with all gelled and sealed units, AGM batteries are sensitive to overcharging. A charge to 2.40V/cell (and higher) is fine; however, the float charge should be reduced to between 2.25 and 2.30V/cell (summer temperatures may require lower voltages).
Battery University is a good place for learning battery technology.
There speaks a yachting man! Ten times that for many car engines.
Buying anything with 'Marine" written on the side tends to hurt your bank account - as does something involving data systems integrity. There are deep cycle batteries in SUVs and Winnebagos and they are probably cheapest of the lot. It's just a matter of reading the battery spec and manufacturers usually have accurate data sheets. Just buying something a bit bigger than you need could possibly be the cheapest solution for a static application.
One power failure in a blue moon could be coped with and it may not matter if it knackers a cheaper battery (a disposable lifeboat, if you like) but one failure a week would be a different matter.
Related to UPS, Marine Battery, as Sump Pump backup
1. What is a UPS and how does it work?
A UPS (Uninterruptible Power Supply) is a device that provides backup power to electrical equipment in case of a power outage or interruption. It works by converting alternating current (AC) power from the wall outlet to direct current (DC) power, which is then stored in a battery. When a power outage occurs, the UPS switches to battery power to keep the equipment running.
2. What is a marine battery and why is it used as a sump pump backup?
A marine battery is a type of lead-acid battery designed for use in marine environments. It is used as a sump pump backup because it is designed to withstand harsh conditions and provide reliable power for extended periods of time. In case of a power outage, the marine battery can power the sump pump, preventing flooding and damage to the property.
3. How long can a UPS marine battery power a sump pump?
The duration of backup power provided by a UPS marine battery will depend on the size and capacity of the battery, as well as the power consumption of the sump pump. Generally, a fully charged marine battery can power a sump pump for several hours, giving enough time for the power to be restored or for a backup generator to be connected.
4. Can a UPS marine battery be used as a primary power source for a sump pump?
No, a UPS marine battery is not designed to be a primary power source for a sump pump. It is meant to be used as a backup in case of a power outage. It is important to have a reliable and continuous power source for a sump pump to function properly and prevent potential damage from flooding.
5. How should a UPS marine battery be maintained for optimal performance?
To ensure optimal performance, a UPS marine battery should be regularly checked and maintained. This includes keeping the battery clean and dry, checking the charge level and topping it up if necessary, and replacing the battery when it reaches the end of its lifespan. It is also important to regularly test the UPS and battery to ensure they are functioning properly in case of an emergency.
  • Electrical Engineering
16K
10K
52K
