khurram usman
- 87
I will try to explain the issue I am having as clearly as possible without going into my coding or maths. I have my own and a MATLAB Central implementation pf standard LMS in MATLAB. Fixed step size. No normalization or other stuff.
I am trying to use it in a system identification setup. I generate a vector of gaussian numbers using "randn" and give the same vector as input and desired response to the LMS filter. Now the estimated weight vector at the end should be a "delta" channel and this is what I get. Then i tried upsampling and interpolating the input vector by an integer number and repeating the same thing. This time around the estimated channel is of the shape of an "Sinc". I gave the interpolated signal as the input and the desired response as before. No changes.
Then i also tried low pass filtering the input vector and repeating the same thing. Again a "Sinc". Has anyone observed this before or know something about this? Please point out my mistake. Any suggestions or a discussion is also welcome.
