Upside Down Paper-Glass Water Experiment
The discussion centers on a physics problem involving a cylindrical glass filled with water, which is inverted and sealed with paper, preventing air from entering. The key equations relate the weight of the paper to the weight of the water that could have been in the glass, emphasizing that the mass of the paper must be less than or equal to the weight of the water that remains. Participants highlight the importance of understanding the process of inverting the glass and the dynamics of water escaping, noting that the volume of water that escapes (V) must be accounted for in calculations. One contributor shares their method of using a playing card to create a seal and manage water displacement effectively. The conversation underscores the need for careful consideration of air pressure and water dynamics in such experiments.
S-Ragnork1729
A cylindrical glass was filled with water to a height H. The glass had a total height of h and a radius r. The glass was then covered with a sheet of paper and turned upside down. The volume of water that escaped between the paper and the glass was V . When the paper was no longer held against the glass, it remained attached, while the remaining water stayed inside the glass. What is the maximum mass m of the paper? The air pressure is p, the gravitational acceleration is g, and the water’s density is ρ. The paper used was coated and did not absorb water. At the moment the paper was released, the temperatures of the air and water were the same.
$$F_{up} \geq F_{down}$$
$$F_{down} \leq F_{up} $$ $$\Longrightarrow mg \leq \rho g(h-H)\pi r^2 $$ $$\Longrightarrow m \leq \rho (h-H)\pi r^2 $$
S-Ragnork1729 said:
Homework Statement: A cylindrical glass was filled with water to a height H. The glass had a total height of h and a radius r. The glass was then covered with a sheet of paper and turned upside down. The volume of water that escaped between the paper and the glass was V . When the paper was no longer held against the glass, it remained attached, while the remaining water stayed inside the glass. What is the maximum mass m of the paper? The air pressure is p, the gravitational acceleration is g, and the water’s density is ρ. The paper used was coated and did not absorb water. At the moment the paper was released, the temperatures of the air and water were the same.
Relevant Equations: $$F_{up} \geq F_{down}$$
Decoding that, “the weight of the paper is less than or equal to the weight of the water that could have been put in the glass initially but wasn’t”.
Eh?
Start by answering this: how is it possible that any water stayed in the glass after turning the glass over and taking away whatever was supporting the paper?
I would like to see OP explain the process of inverting the glass and the final resulting equilibrium with words before trying to write down equations.
My understanding of the situation is that upright glass is sealed with a piece of paper at the rim. It is inverted and then some water is allowed to escape at the seal between paper and rim. Importantly, no outside air is allowed to enter as the water escapes.
The answer supplied by OP did not take account of the volume ##V## of water that was allowed to escape. Accordingly, it cannot be correct.
I have not personally attempted to invert a glass in this fashion. When I do it, I am always careful not to allow any air-filled head space. The expansion of air in the head space is undesirable. I generally use a playing card for the paper seal. The task is made easier if one presses gently on the center of the playing card under the inverted glass, squeezing a bit of water out before removing one's hand. That squeezed out water is the ##V## in the problem.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
