Uranium deposit -- location techniques question
  • Thread starter girts
  • Tags
    Uranium
In summary: The technique of neutron activation analysis is used to find uranium deposits. Neutrons are used to see if there is uranium present. The technique is passive, meaning that there is no need for radiation exposure. U-235 has a higher cross-section for thermal neutrons, so it is more likely to react with them. The technique is used to explore geological formations bearing minerals.
girts
186
I read that one can find Uranium for its gamma radiation hence gamma can travel through even dense and thick stuff, but natural Uranium that hasn't gone through fission doesn't emit gamma correct, so I was reading how they find Uranium reserves underground and it says that they use a alpha emitter combined with beryllium which then undergoes spallation and produces neutrons, then it is said that they use these neutrons to see whether there is Uranium in the ground because if there is they can detect some delayed neutrons coming back from the induced fission of the neutrons that came out from the beryllium checking device.
Here is what I don't quite get, I suppose it is rarely when Uranium deposits simply lie close to ground, under grass or right on top of soil, I assume they are mostly rather deep below ground, now how do these neutrons penetrate deep enough to strike the U deposits and even get back some delayed fission neutrons, how come these neutrons simply don't get lost or scattered or else while they are traveling through the layers of rock and soil and other stuff in the ground?
Or do they "finetune" the neutron energies so that they don't interact with other elements but only either U 235 or U 2
Neutron activation analysis is an active technique. One can use an (α,n) source, or a fusion-based d+t source of neutrons. The neutrons can be thermalized with something like water or polyethylene. U-235 has a higher cross-section for thermal neutrons, so thermal neutrons would react with U-235. One would normally bore a tunnel, or take a coring sample and assay the rock above ground. The technique is used for exploring geological formations bearing minerals.
U deposits also incorporate beta- and gamma-emitting daughter products, which are detectable by Geiger/proportional counters. This would be a passive method.
http://hyperphysics.phy-astr.gsu.edu/hbase/Nuclear/radser.html
Some deposits are near the surface, but many are not. Where the uranium is deposited has a lot to do with hydrogeology.
Uranium is often found with other valuable elements, e.g., vanadium.
https://pubs.usgs.gov/bul/1009b/report.pdf
Related to Uranium deposit -- location techniques question
What is uranium deposit?
Uranium deposit is a natural occurrence of uranium in the Earth's crust. It is a radioactive element that is used as a fuel source for nuclear power plants.
How is uranium deposit formed?
Uranium deposit is formed through the process of radioactive decay of heavier elements such as thorium and radium. It can also be formed through the accumulation of uranium-rich sediments over millions of years.
What are the techniques used to locate uranium deposit?
The techniques used to locate uranium deposit include geophysical methods such as radiometric surveys, magnetic surveys, and electrical resistivity surveys. Other methods include soil and rock sampling, aerial surveys, and remote sensing techniques.
What are the most common locations for uranium deposit?
Uranium deposit can be found in a variety of geological settings, but the most common locations include sedimentary rocks, sandstones, and granites. It can also be found in association with other minerals such as copper, gold, and silver deposits.
Why is it important to locate uranium deposit?
Uranium deposit is important because it is a valuable source of nuclear fuel, which is used to generate electricity. It is also used in medical applications, such as in cancer treatments, and in various industrial processes.
  • Nuclear Engineering
  • Science Fiction and Fantasy Media
  • Other Physics Topics
  • Atomic and Condensed Matter
