- #36
Ken G
- 549
The "equivalence" of what? You have already said there is a convenience issue that is not equivalent. I've already agreed there is a formal equivalence.my_wan said:In fact the every result we obtain with any choice of coordinates is the same "artifact". We may even derive transforms to prove the equivalence.
I am saying that if there is a logical basis for taking one origin (the source of gravity, roughly), then one should expect a certain non-coincidental convenience to attach to that choice, making it non-arbitrary. I should think that would be noncontroversial enough, given how often we do it. If one has a logically based convenience that attaches to a certain choice, I do not call that an "artifact", I call it a logicaly based convenience-- as for comoving coordinates and the Cosmological Principle. What is controversial in that statement?The convenience is the only pure artifact. To say that defining one of an infinite number of physically equivalent choices has a logical basis borders on giving (x, y, z, t)=0 absolute meaning.
The way I would say that same thing is, the Cosmological Principle is all that is real, the convenience of comoving coordinates stem from that.The convenience is all that is real about it.
It would require entering into undemonstrable philosophy to claim prior knowledge of "what is reasonable". I wait for experiment to tell me that.It could actually be argued that the Cosmological principle is needed under most reasonable assumptions about the Universe.
I can agree there-- we are fortunate not to have to.In fact the hardest thing to explain theoretically would be a failure of the Cosmological principle.
Personally, not sure at all. One would only look for higher-order than dipole variations though, a la Occam's razor.Even so how sure can you be that the Hubble flow wouldn't appear isotropic regardless of our peculiar motion such that any apparent anisotropy is simply a doppler shift.
What I'm saying is that there are two ways to think of space. One is that space is really there, and the other is that we made it up in our minds to explain various observations. I realize that at some level everything we talk about is made up in our minds, but what I mean by "made up in our minds" is that we have no direct measurements that correspond to what we have made up-- it always requires some construction. Proper time, for example, is directly measurable between two causally connected events. Proper distance is not. So when dealing with distance, we need to invent indirect measures, like timing light. I admit that we need a concept of "infinitesmal distance" to calibrate a clock, but we don't have any way to measure cosmological distances that are not indirect, so require a model to interpret the measurement, and that is why there are so many different and essentially arbitrary distance measurements. I take that as a major clue that space is not "real" the way proper time is. It simply is not directly measurable, you measure something else and use it to infer a distance, so the latter concept is just invented.If by "real" you mean what we measure then the most straightforward definition is proper distance, which is consistent with the operational definition that kdv gave. This could even be communicated to a distant civilization using Planks constant as a standard.
Then we may talk about the symmetries as real-- not the "space". The usual concept of space is what I am talking about, not the replacement of that concept with more precise groups of symmetries. The latter I am fine with calling real-- as I said, we measure something else and invent a concept of space to make sense of it. Space is a theory.The presents of an observers alone dictates the means of measurement. They may not all generally agree on distances but they can agree on the symmetries of their disagreements and all will agree that spatial separation exist. These symmetries are non-arbitrary.
I am saying that "proper distance" is a made up concept, as it is by definition not directly measurable. It is also a theory. A useful one, like many theories are, but we made it up because we can't measure it. We can measure time.Question: Are you claiming here that the Hubble flow does not constitute a change of "proper" distance with time?
I am repeating the standard descriptions that I am criticizing as being only pictures-- how many times have you heard it stated that cosmological redshifts are "not due to relative motion"? Many, over here.Here you seem to be referring to comoving coordinates to say "not moving relative to each other".
That is the argument I am presenting, yes. A coordinate system where there is no relative motion is as arbitrary as one where there is, even if some real effect makes it more convenient.Again this is an arbitrary coordinate system of convenience and presumably disagrees but does not conflict with the notion of proper distance.
That isn't proper distance, it's proper time in distance units. Is that all you mean by proper distance? Again, note it is not directly measurable, you measure a time and decide to multiply by c, for whatever reason. Even if you choose units where c=1, you are still measuring a time and calling it a distance.If a two way light signal sent tomorrow takes longer to return than one sent today its proper distance has increased even though its comoving distance might not have.
It sounds like you are claiming that if successive light pulses take longer to return, that means space is expanding. That doesn't sound very reasonable at all, given that pulses to the Voyager spacecraft also do that. My objection to kdv was never anything other than the claim that mean cosmological redshifts are categorically caused by the expansion of space. I said that this was a coordinate choice, and Hurkyl pointed out that when "expanding space" is used technically it actually means something different than what kdv seemed to mean (it really meant "gravitational redshift", in essence). Hence the only way to refute my objection is for kdv to say that Hurkyl's limited meaning was all he really intended, in which case I would say, that could have been made more clear.You would have a case on pure technicality if kdv hadn't provided an operation definition that happen to be consistent with proper distance.
You have claimed two things, it seems, one is that distance can be defined to be a light travel time (that sounds like a time to me, but you did call it an operational definition so I must accept it), and the other is that distance is the way to determine "how much space there is". Combining those claims suggests that space is expanding between us and the Voyager spacecraft -- after all, there's more space between us, the space must have expanded. Those are all the aspects of kdv's position that you have cited, are they not? What did I leave out?His definition of "existing space" is simply the inverse of your definition of time.
I agree that we certainly like to imagine that the one-way speed of light is a constant, so we do indeed make up a concept of distance that is inferred from light travel times. I do not think that tells us anything at all about "what is happening to space" in our solar system, other than the very useful picture that it is being compressed laterally and stretched radially as it is sucked into the Sun.I agree this definition of "existing space" is a purely an "artifact" of the chosen definition. Yet it is a particularly useful one if we consider sending long range probes.
No, it isn't any kind of definition at all. It is a convenience stemming logically from a fact.You argue that this operational definition is invalid yet you argue that placing the sun at the center of our solar system is not "pure artifact". The sun centered solar system is itself a purely operational definition.
The parallel you draw actually makes my argument. Had kdv said that the coordinate-generated concept of "existing space" was nothing but a convenience stemming logically from a fact (the Cosmological Principle), I would have agreed completely. Indeed, that is just what I said.It is no more nor any less valid than kdv's operational definition of "existing space".
Except that it is only true if we adopt the axiom that the one-way speed of light is constant. But more to the point, you seem to be using the term "operational definition" to mean "coordinate choice". If the operational definition requires a certain (albeit elegant) coordinate choice, how are you distinguishing the coordinates from the definition? All I've said is that it is a coordinate choice, so if your argument will be that this is the same thing as an operational definition, you are simply creating a semantic identity.All observers may not agree on how much but all observers will agree that there is some space between you and I, inversely identical to time. Sounds like a reasonable operational definition of "existing space" to me.
