Urine/seawater precipitation salts
In summary: For example, if the pipes are made of metal, then using an acid that is also a metal corrosion inhibitor would be appropriate. In summary, according to the speaker, the build up of salts on the sides of a boat toilet pipes is likely caused by the reaction of seawater with urine. The salts can be dissolved with an acid, but care must be taken to avoid corrosion of the pipes.
boatuser
A boat toilet ( called 'heads') uses seawater to flush the waste overboard or into a holding tank.
Over time there is a serious "furring up" of the waste pipes - not the inlet pipes - which implies that there are precipitation salts produced from the reaction of the seawater with, presumably, urine.
It is definitely hard and crystalline in structure and can be 'chipped' away with a screwdriver. The colour is a grey-brown.
In order to find a way of removing the build up of salats I need to know what the likely composition is!
Is there anyone here who has the chemistry knowledge to explain what reaction is ocurring and thus the most suitable chemical to re-dissolve them.
By the way - I would imagine that if the system was properly flushed each time, then only salt water would remain in the waste outlet pipe and furring up would not ocurr in the same way as it doesn't ocurr in the inlets. Unfortunately people are lazy when 'pumping out' and I suspect that what gets left is a dilute mixture of urine and seawater. I don't actually know if the pipe remains full or not; if not I guess it could simply be evaporation salts from the urine?
Chemistry news on Phys.org
The precipitation salts that form in a boat toilet are likely carbonates or bicarbonates of calcium, magnesium and/or sodium. When seawater reacts with urine, these ions can form insoluble salts (e.g. calcium carbonate or magnesium carbonate). These salts then precipitate out of solution and accumulate on the sides of the pipes. To remove these salts, you can use an acid to dissolve them. Acids such as hydrochloric acid, sulfuric acid, or phosphoric acid can all be used to dissolve the salts. Be sure to use the appropriate safety precautions when handling acids. Additionally, it is important to ensure that any acid used is compatible with the material of the pipes.
FAQ: Urine/seawater precipitation salts
1. What is the purpose of studying urine/seawater precipitation salts?
The study of urine/seawater precipitation salts is important for understanding the chemical reactions that occur in the human body and the environment. It can also provide valuable information about the health of individuals and the health of marine ecosystems.
2. How does urine/seawater precipitation occur?
Urine/seawater precipitation occurs when the concentration of dissolved salts in urine or seawater exceeds the solubility limit, causing the salts to form solid particles that precipitate out of solution.
3. What factors influence the formation of urine/seawater precipitation salts?
The formation of urine/seawater precipitation salts is influenced by various factors such as temperature, pH, concentration of salts, and presence of other substances that may act as catalysts or inhibitors.
4. Can urine/seawater precipitation salts be harmful?
In most cases, urine/seawater precipitation salts are not harmful and can be safely excreted from the body or diluted in the ocean. However, high concentrations of certain salts, such as calcium oxalate, can lead to kidney stones in humans and affect the growth of marine organisms.
5. How is the study of urine/seawater precipitation salts relevant to other fields of science?
The study of urine/seawater precipitation salts has implications in various fields of science, including chemistry, biology, environmental science, and medicine. It can help in the development of treatments for kidney stones and understanding the impact of human activities on marine ecosystems.
