Usage of the Rearrangement Inequality in a trigonometric expression
In summary: B \cos C}{\sin B \sin C}=\sum_{cyc}\cot B \cot C =1.\]In summary, the use of Rearrangement Inequality in this proof is valid and it helps to establish the given inequality. I hope this explanation helps you understand the concept better.
lfdahl
MHB
749
In a proof, I encountered the following expressions:
\[\sum_{cyc}\frac{\cos^2 A}{\sin B \sin C}\geq \sum_{cyc}\frac{\cos B \cos C}{\sin B \sin C}=\sum_{cyc}\cot B \cot C =1\]
My question is concerned with the validity of the inequality.
The inequality is based on the use of the Rearrangement Inequality (RI). Can anyone help me understand exactly how the RI is used here?
Thankyou in advance.
Mathematics news on Phys.org
Thank you for bringing up this question. The use of Rearrangement Inequality in this proof is indeed valid and can be explained as follows:
Firstly, let's define the Rearrangement Inequality. It states that if we have two sequences of real numbers \(\{a_1,a_2,...,a_n\}\) and \(\{b_1,b_2,...,b_n\}\) such that \(a_1\geq a_2\geq...\geq a_n\) and \(b_1\geq b_2\geq...\geq b_n\), then the following inequality holds:
\[a_1b_1+a_2b_2+...+a_nb_n\geq a_1b_{\sigma(1)}+a_2b_{\sigma(2)}+...+a_nb_{\sigma(n)},\]
where \(\sigma\) is any permutation of the numbers \(\{1,2,...,n\}\).
Now, let's apply this inequality to the given expressions in the proof. We have the sequences \(\{\cos^2 A, \cos B \cos C, \cot B \cot C\}\) and \(\{\frac{1}{\sin B \sin C},\frac{1}{\sin B \sin C},\frac{1}{\sin B \sin C}\}\). We can see that \(\cos^2 A \geq \cos B \cos C \geq \cot B \cot C\) and \(\frac{1}{\sin B \sin C} \geq \frac{1}{\sin B \sin C} \geq \frac{1}{\sin B \sin C}\). Therefore, by the Rearrangement Inequality, we have:
\[\sum_{cyc}\frac{\cos^2 A}{\sin B \sin C}\geq \sum_{cyc}\frac{\cos B \cos C}{\sin B \sin C}= \sum_{cyc}\cot B \cot C.\]
Finally, since \(\sum_{cyc}\cot B \cot C = 1\) (as you have correctly pointed out in your post), we can conclude that:
FAQ: Usage of the Rearrangement Inequality in a trigonometric expression
How is the Rearrangement Inequality used in a trigonometric expression?
The Rearrangement Inequality is used to rearrange the terms in a trigonometric expression in order to simplify it or prove a certain mathematical statement. It states that for any two sequences of real numbers, if one is arranged in ascending order and the other in descending order, the sum of the products of their corresponding terms will be greater than or equal to the sum of the products of any other possible arrangement of terms.
Can the Rearrangement Inequality be used in all trigonometric expressions?
Yes, the Rearrangement Inequality can be used in any trigonometric expression that involves sequences of real numbers. However, it is most commonly used in expressions involving trigonometric functions such as sine, cosine, and tangent.
What are the steps to apply the Rearrangement Inequality in a trigonometric expression?
The steps to apply the Rearrangement Inequality in a trigonometric expression are as follows:
  1. Identify the sequences of real numbers within the expression.
  2. Arrange one sequence in ascending order and the other in descending order.
  3. Multiply the corresponding terms from each sequence and find the sum of these products.
  4. Repeat this process for all possible arrangements of terms.
  5. Compare the sums of products and determine if the Rearrangement Inequality holds true.
What is the significance of using the Rearrangement Inequality in trigonometric expressions?
The Rearrangement Inequality allows for a more efficient and elegant way to simplify or prove mathematical statements involving trigonometric expressions. It also provides a useful tool for comparing and analyzing different arrangements of terms in an expression.
Can the Rearrangement Inequality be used to solve trigonometric equations?
No, the Rearrangement Inequality is not typically used to directly solve trigonometric equations. However, it can be used as a tool to support the solution of a trigonometric equation by simplifying or proving certain mathematical statements within the equation.
9K
